[petsc-users] setting correct tolerances for MG smoother CG at the finest level
Mark Adams mfadams at lbl.gov
Mon Sep 29 07:20:56 CDT 2025
Oh I see the coarse grid solver in your full solver output now.
You still want an accurate coarse grid solve. Usually (the default in GAMG)
you use a direct solver on one process, and cousin until the coarse grid is
small enough to make that cheap.
On Mon, Sep 29, 2025 at 8:07 AM Moral Sanchez, Elena <
Elena.Moral.Sanchez at ipp.mpg.de> wrote:
> Hi, I doubled the system size and changed the tolerances just to show a
> better example of the problem. This is the output of the callbacks in the
> first iteration:
>     CG Iter 0/1 | res = 2.25e+00/1.00e-09 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 0/15 | res = 2.25e+00/1.00e-01 | 0.3 s
>         MG lvl 0 (s=884): CG Iter 1/15 | res = 1.43e+00/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 2/15 | res = 1.17e+00/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 3/15 | res = 1.32e+00/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 4/15 | res = 5.01e-01/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 5/15 | res = 3.57e-01/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 6/15 | res = 2.49e-01/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 7/15 | res = 3.04e-01/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 8/15 | res = 2.78e-01/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 9/15 | res = 1.68e-01/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 10/15 | res = 1.21e-01/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 11/15 | res = 9.45e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 12/15 | res = 8.31e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 13/15 | res = 5.47e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 14/15 | res = 4.36e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 15/15 | res = 5.08e-02/1.00e-01 | 0.1 s
>         ConvergedReason MG lvl 0: 4
>         MG lvl -1 (s=524): CG Iter 0/15 | res = 8.15e-02/1.00e-01 | 3.0 s
>         ConvergedReason MG lvl -1: 3
>         MG lvl 0 (s=884): CG Iter 0/15 | res = 5.08e-02/1.00e-01 | 0.3 s
>         MG lvl 0 (s=884): CG Iter 1/15 | res = 2.93e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 2/15 | res = 3.26e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 3/15 | res = 4.14e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 4/15 | res = 4.82e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 5/15 | res = 3.20e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 6/15 | res = 3.46e-02/1.00e-01 | 0.3 s
>         MG lvl 0 (s=884): CG Iter 7/15 | res = 3.41e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 8/15 | res = 4.69e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 9/15 | res = 3.37e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 10/15 | res = 4.07e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 11/15 | res = 2.66e-02/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 12/15 | res = 2.83e-02/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 13/15 | res = 2.98e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 14/15 | res = 3.53e-02/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 15/15 | res = 2.33e-02/1.00e-01 | 0.2 s
>     CG Iter 1/1 | res = 2.42e-02/1.00e-09 | 5.6 s
>         MG lvl 0 (s=884): CG Iter 0/15 | res = 2.42e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 1/15 | res = 1.76e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 2/15 | res = 1.40e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 3/15 | res = 1.42e-02/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 4/15 | res = 1.62e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 5/15 | res = 1.35e-02/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 6/15 | res = 1.39e-02/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 7/15 | res = 1.51e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 8/15 | res = 1.28e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 9/15 | res = 1.24e-02/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 10/15 | res = 9.59e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 11/15 | res = 9.02e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 12/15 | res = 1.19e-02/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 13/15 | res = 1.08e-02/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 14/15 | res = 8.19e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 15/15 | res = 7.61e-03/1.00e-01 | 0.1 s
>         MG lvl -1 (s=524): CG Iter 0/15 | res = 1.38e-02/1.00e-01 | 5.2 s
>         MG lvl 0 (s=884): CG Iter 0/15 | res = 7.61e-03/1.00e-01 | 0.2 s
>         MG lvl 0 (s=884): CG Iter 1/15 | res = 5.62e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 2/15 | res = 6.64e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 3/15 | res = 8.71e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 4/15 | res = 6.40e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 5/15 | res = 7.23e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 6/15 | res = 6.20e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 7/15 | res = 7.04e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 8/15 | res = 7.19e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 9/15 | res = 6.35e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 10/15 | res = 7.31e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 11/15 | res = 6.64e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 12/15 | res = 7.24e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 13/15 | res = 4.97e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 14/15 | res = 5.36e-03/1.00e-01 | 0.1 s
>         MG lvl 0 (s=884): CG Iter 15/15 | res = 5.84e-03/1.00e-01 | 0.1 s
>     CG ConvergedReason: -3
> For completeness, I add here the -ksp_view of the whole solver:
>     KSP Object: 1 MPI process
>       type: cg
>         variant HERMITIAN
>       maximum iterations=1, nonzero initial guess
>       tolerances: relative=1e-08, absolute=1e-09, divergence=10000.
>       left preconditioning
>       using UNPRECONDITIONED norm type for convergence test
>     PC Object: 1 MPI process
>       type: mg
>         type is MULTIPLICATIVE, levels=2 cycles=v
>           Cycles per PCApply=1
>           Not using Galerkin computed coarse grid matrices
>       Coarse grid solver -- level 0 -------------------------------
>         KSP Object: (mg_coarse_) 1 MPI process
>           type: cg
>         variant HERMITIAN
>           maximum iterations=15, nonzero initial guess
>           tolerances: relative=0.1, absolute=0.1, divergence=1e+30
>         PC Object: (mg_coarse_) 1 MPI process
>           type: none
>           linear system matrix = precond matrix:
>           Mat Object: 1 MPI process
>         type: python
>         rows=524, cols=524
>             Python: Solver_petsc.LeastSquaresOperator
>       Down solver (pre-smoother) on level 1 -------------------------------
>         KSP Object: (mg_levels_1_) 1 MPI process
>           type: cg
>         variant HERMITIAN
>         PC Object: (mg_levels_1_) 1 MPI process
>           type: none
>         type: python
>         rows=884, cols=884
>       Up solver (post-smoother) same as down solver (pre-smoother)
>         type: python
>         rows=884, cols=884
> Regarding Mark's Email: What do you mean with "the whole solver doesn't
> have a coarse grid"? I am using my own Restriction and Interpolation
> operators.
> Thanks for the help,
> Elena
> *From:* Mark Adams <mfadams at lbl.gov>
> *Sent:* 28 September 2025 20:13:54
> *To:* Barry Smith
> *Cc:* Moral Sanchez, Elena; petsc-users
> *Subject:* Re: [petsc-users] setting correct tolerances for MG smoother
> Not sure why your "whole"solver does not have a coarse grid but this is
> wrong:
>   type: cg
>     variant HERMITIAN
>   maximum iterations=100, initial guess is zero
> The coarse grid has to be accurate. The defaults are a good place to
> start: max_it=10.000, rtol=1e-5, atol=1e-30 (ish)
> On Fri, Sep 26, 2025 at 3:21 PM Barry Smith <bsmith at petsc.dev> wrote:
>>   Looks reasonable. Send the output running with
>>    -ksp_monitor -mg_levels_ksp_monitor -ksp_converged_reason
>> -mg_levels_ksp_converged_reason
>> On Sep 26, 2025, at 1:19 PM, Moral Sanchez, Elena <
>> Dear Barry,
>> This is -ksp_view for the smoother at the finest level:
>>   type: cg
>>     variant HERMITIAN
>>   maximum iterations=10, nonzero initial guess
>>   type: none
>>     type: python
>>     rows=524, cols=524
>> And at the coarsest level:
>>   type: cg
>>     variant HERMITIAN
>>   type: none
>>     type: python
>>     rows=344, cols=344
>> And for the whole solver:
>>   type: cg
>>     variant HERMITIAN
>>   maximum iterations=100, nonzero initial guess
>>   type: mg
>>       type: cg
>>         variant HERMITIAN
>>       type: none
>>         type: python
>>         rows=344, cols=344
>>       type: cg
>>         variant HERMITIAN
>>       type: none
>>         type: python
>>         rows=524, cols=524
>>     type: python
>>     rows=524, cols=524
>> Best,
>> Elena
>> *From:* Barry Smith <bsmith at petsc.dev>
>> *Sent:* 26 September 2025 19:05:02
>> *To:* Moral Sanchez, Elena
>> *Cc:* petsc-users at mcs.anl.gov
>> Send the output using -ksp_view
>> Normally one uses a fixed number of iterations of smoothing  on level
>> with multigrid rather than a tolerance, but yes PETSc should respect such a
>> tolerance.
>> Barry
>> On Sep 26, 2025, at 12:49 PM, Moral Sanchez, Elena <
>> Hi,
>> I am using multigrid (multiplicative) as a preconditioner with a V-cycle
>> of two levels. At each level, I am setting CG as the smoother with certain
>> tolerance.
>> What I observe is that in the finest level the CG continues iterating
>> after the residual norm reaches the tolerance (atol) and it only stops when
>> reaching the maximum number of iterations at that level. At the coarsest
>> level this does not occur and the CG stops when the tolerance is reached.
>> I double-checked that the smoother at the finest level has the right
>> tolerance. And I am using a Monitor function to track the residual.
>> Do you know how to make the smoother at the finest level stop when
>> reaching the tolerance?
>> Cheers,
>> Elena.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250929/7ca78a0a/attachment-0001.html>
