[petsc-users] setting correct tolerances for MG smoother CG at the finest level
Barry Smith
bsmith at petsc.dev
Fri Sep 26 14:20:36 CDT 2025
Looks reasonable. Send the output running with
-ksp_monitor -mg_levels_ksp_monitor -ksp_converged_reason -mg_levels_ksp_converged_reason
> On Sep 26, 2025, at 1:19 PM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de> wrote:
> Dear Barry,
> This is -ksp_view for the smoother at the finest level:
> KSP Object: (mg_levels_1_) 1 MPI process
> type: cg
> variant HERMITIAN
> maximum iterations=10, nonzero initial guess
> tolerances: relative=0.1, absolute=0.1, divergence=1e+30
> left preconditioning
> using UNPRECONDITIONED norm type for convergence test
> PC Object: (mg_levels_1_) 1 MPI process
> type: none
> linear system matrix = precond matrix:
> Mat Object: 1 MPI process
> type: python
> rows=524, cols=524
> Python: Solver_petsc.LeastSquaresOperator
> And at the coarsest level:
> KSP Object: (mg_coarse_) 1 MPI process
> type: cg
> variant HERMITIAN
> maximum iterations=100, initial guess is zero
> PC Object: (mg_coarse_) 1 MPI process
> type: none
> type: python
> rows=344, cols=344
> And for the whole solver:
> KSP Object: 1 MPI process
> type: cg
> variant HERMITIAN
> maximum iterations=100, nonzero initial guess
> tolerances: relative=1e-08, absolute=1e-09, divergence=10000.
> PC Object: 1 MPI process
> type: mg
> type is MULTIPLICATIVE, levels=2 cycles=v
> Cycles per PCApply=1
> Not using Galerkin computed coarse grid matrices
> Coarse grid solver -- level 0 -------------------------------
> type: cg
> variant HERMITIAN
> type: none
> type: python
> rows=344, cols=344
> Down solver (pre-smoother) on level 1 -------------------------------
> type: cg
> variant HERMITIAN
> type: none
> type: python
> rows=524, cols=524
> Up solver (post-smoother) same as down solver (pre-smoother)
> type: python
> rows=524, cols=524
> Best,
> Elena
> From: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Sent: 26 September 2025 19:05:02
> To: Moral Sanchez, Elena
> Cc: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] setting correct tolerances for MG smoother CG at the finest level
> Send the output using -ksp_view
> Normally one uses a fixed number of iterations of smoothing on level with multigrid rather than a tolerance, but yes PETSc should respect such a tolerance.
> Barry
>> On Sep 26, 2025, at 12:49 PM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de <mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
>> Hi,
>> I am using multigrid (multiplicative) as a preconditioner with a V-cycle of two levels. At each level, I am setting CG as the smoother with certain tolerance.
>> What I observe is that in the finest level the CG continues iterating after the residual norm reaches the tolerance (atol) and it only stops when reaching the maximum number of iterations at that level. At the coarsest level this does not occur and the CG stops when the tolerance is reached.
>> I double-checked that the smoother at the finest level has the right tolerance. And I am using a Monitor function to track the residual.
>> Do you know how to make the smoother at the finest level stop when reaching the tolerance?
>> Cheers,
>> Elena.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250926/ac1bbf82/attachment-0003.html>
