[petsc-users] Custom matrix coloring for finite difference Jacobian
Barry Smith
bsmith at petsc.dev
Thu Sep 25 18:28:31 CDT 2025
Is this something you are still interested in having?
> On Sep 11, 2025, at 7:25 PM, Eirik Jaccheri Høydalsvik via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi,
> I have made a two-phase flow code which computes motion of two phases in one dimension, where the phases are allowed to intermix. This code relies on a finite difference Jacobian computed using the standard coloring I get from the DMDA object:
> da = PETSc.DMDA().create(
> dim=(N_vertical,),
> dof=3,
> stencil_width=1,
> I now want to add a variable for the interphase height L_z in addition to a velocity u_v, giving the velocity of the vapor flowing in to the interface. The interface will move throughout the grid, meaning that these two variables will not be coupled to a fixed set of grid cells, but will be coupled to different sets of three grid cells throughout the simulation.
> Questions:
> 1. Is it possible to create a custom coloring to efficiently compute the finite difference Jacobian including the interphase height and vapor velocity?
> 2. How do I revert to computing the full finite difference Jacobian with the purpose of testing if the interphase model works?
> Best regards,
> Sintef ER and NTNU EPT
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250925/41a1ca4f/attachment.html>
