[petsc-users] Seeking help in integration Petsc with NoahMP
Shatanawi, Sawsan Muhammad
sawsan.shatanawi at wsu.edu
Sat Sep 20 18:31:48 CDT 2025
Hello Matthew,
Thank you for getting back to me.
Yes, I called all the functions.
The thing is that when I write a simple print statement, the run crashes.
Here is the error message that I usually get:
Breakpoint 1, module_noahmp_hrldas_driver::land_driver_ini (ntime_out=0, wrfits=<error reading variable: Cannot access memory at address 0x0>, wrfite=<error reading variable: Cannot access memory at address 0x0>,
wrfjts=<error reading variable: Cannot access memory at address 0x0>, wrfjte=<error reading variable: Cannot access memory at address 0x0>) at module_NoahMP_hrldas_driver.f90:75
75 real(kind=kind_noahmp), allocatable :: BC_type_real(:,:,:), source_type_real(:,:,:)
Missing separate debuginfos, use: dnf debuginfo-install cyrus-sasl-lib-2.1.27-21.el9.x86_64 glibc-2.34-168.el9_6.20.x86_64 keyutils-libs-1.6.3-1.el9.x86_64 krb5-libs-1.21.1-8.el9_6.x86_64 libX11-1.7.0-9.el9.x86_64 libXau-1.0.9-8.el9.x86_64 libbrotli-1.0.9-6.el9.x86_64 libcom_err-1.46.5-5.el9.x86_64 libcurl-7.76.1-29.el9_4.1.x86_64 libevent-2.1.12-8.el9_4.x86_64 libidn2-2.3.0-7.el9.x86_64 libjpeg-turbo-2.0.90-7.el9.x86_64 libnghttp2-1.43.0-5.el9_4.3.x86_64 libpsl-0.21.1-5.el9.x86_64 libselinux-3.6-1.el9.x86_64 libunistring-0.9.10-15.el9.x86_64 libxcb-1.13.1-9.el9.x86_64 libxcrypt-4.4.18-3.el9.x86_64 libxml2-2.9.13-12.el9_6.x86_64 openssl-libs-3.2.2-6.el9_5.1.x86_64 systemd-libs-252-32.el9_4.7.x86_64 xz-libs-5.2.5-8.el9_0.x86_64 zlib-1.2.11-40.el9.x86_64
(gdb) n
77 write(6,*) "sawsan was here 1"
(gdb)
forrtl: severe (257): formatted I/O to unit open for unformatted transfers, unit 6, file /dev/pts/0
Image PC Routine Line Source
libpetsc.so.3.20. 0000155551029BA6 for__io_return Unknown Unknown
hrldas.exe 00000000006906E0 for_write_seq_lis Unknown Unknown
hrldas.exe 0000000000627135 Unknown Unknown Unknown
hrldas.exe 000000000040926D Unknown Unknown Unknown
hrldas.exe 000000000040921D Unknown Unknown Unknown
libc.so.6 000015554A8295D0 Unknown Unknown Unknown
libc.so.6 000015554A829680 __libc_start_main Unknown Unknown
hrldas.exe 0000000000409135 Unknown Unknown Unknown
[Inferior 1 (process 3244707) exited with code 01]
If I use print, the error will be forrtl: severe (257): formatted I/O to unit open for unformatted transfers, unit -1, file /dev/pts/0
I also attached the NoahMP driver module, where I initialize and finalize PETSc. I only added PETSc functions in the land part (and its different subroutines) of the NoahMP model.
Thank you for your help
Sawsan
Sent: Friday, September 19, 2025 3:55 AM
To: Shatanawi, Sawsan Muhammad <sawsan.shatanawi at wsu.edu>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; petsc-maint at mcs.anl.gov
Subject: Re: [petsc-users] Seeking help in integration Petsc with NoahMP
[EXTERNAL EMAIL]
On Thu, Sep 18, 2025 at 9:25 PM Shatanawi, Sawsan Muhammad via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello everyone,
I developed a groundwater module to be integrated within Noah-MP using the HRLDAS driver. For the numerical solver, I rely on PETSc. However, I am encountering an error that I do not fully understand.
To debug, I added print statements in the global NoahmpIOVarType.F90 module (This is the first module that needs to be read), but these statements did not appear in the output. This makes me wonder if I may have declared the PETSc variables incorrectly.
Are you calling the function you added?
Thanks,'
Matt
Could you please review my NoahmpIOVarType.F90 module and Makefile, let me know if the PETSc variables are declared in the correct place? I would greatly appreciate any guidance on this issue.
Thank you in advance
Best regards,
Sawsan Shatanawi:
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZzsHnjSM7RI5-q7hIbK0SgM6A8N3IdRaheTQ9rmAghDMLW0bwhvq6O0AGOXbHH9IgbGNKbLxmJpt0SVZihaWH-_CYUo3r-SluQ$ <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!JmPEgBY0HMszNaDT!sRIOL4qd53HAKzn-5-gYS_kMNcklfbcTtwipXKmqZFVGUd7LFV1K5jgHq0kXhIi1XQKPQrHUfvrTiwPvDOCb$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250920/169a0adf/attachment-0001.html>
Desc: module_NoahMP_hrldas_driver.F
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250920/169a0adf/attachment-0001.obj>
