[petsc-users] Reading -options_file
Satish Balay
balay.anl at fastmail.org
Thu Sep 18 14:59:32 CDT 2025
Perhaps you can try reproducing the issue with a petsc example and then check for differences with your code [or build process?]
Or you can check in debugger. [with a break point in PetscOptionsInsertString_Private - this is where "-options_file" is checked in the library]
Satish
balay at p1 /home/balay/petsc/src/ksp/ksp/tutorials (release =)
$ make ex1
mpicc -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -g3 -O0 -I/home/balay/petsc/include -I/home/balay/petsc/arch-linux-c-debug/include -Wl,-export-dynamic ex1.c -Wl,-rpath,/home/balay/petsc/arch-linux-c-debug/lib -L/home/balay/petsc/arch-linux-c-debug/lib -Wl,-rpath,/software/mpich-4.3.0/lib -L/software/mpich-4.3.0/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/15 -L/usr/lib/gcc/x86_64-redhat-linux/15 -lpetsc -llapack -lblas -lm -lX11 -lmpifort -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -lquadmath -o ex1
$ ./ex1
Norm of error 2.41202e-15, Iterations 5
$ cat options.lst
-ksp_monitor
$ ./ex1 -options_file options.lst
0 KSP Residual norm 7.071067811865e-01
1 KSP Residual norm 3.162277660168e-01
2 KSP Residual norm 1.889822365046e-01
3 KSP Residual norm 1.290994448736e-01
4 KSP Residual norm 9.534625892456e-02
5 KSP Residual norm 8.082545620881e-16
0 KSP Residual norm 3.535533905933e-01
1 KSP Residual norm 8.574929257125e-02
2 KSP Residual norm 2.272727272727e-02
3 KSP Residual norm 6.083103193616e-03
4 KSP Residual norm 1.629797545433e-03
5 KSP Residual norm 6.414906535963e-17
$ ./ex1 --options_file options.lst
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There is one unused database option. It is:
Option left: name:--options_file value: options.lst source: command line
On Thu, 18 Sep 2025, Riousset, Jeremy via petsc-users wrote:
> Hi,
> I’m updating a code from PETSc 3.4 to run with the latest PETSc. Here is my status:
> * I read the parameters via: mpiexec -n 1 bin/./M4 --options_file input/main.in
> * I’m not opening main.in correctly
> * None of the options are retrieved by e.g., PetscOptionsGetReal
> Do you have a suggestion to test what file the code is actually trying to access?
> Thanks
> Jeremy A. Riousset, Ph.D. (he, him, his)
> Associate Professor of Engineering Physics
> Physical Science
> 1 Aerospace Boulevard
> Daytona Beach, FL 32114
> +1 (386) 226-6407
> jeremy.riousset at erau.edu<mailto:jeremy.riousset at erau.edu>
> https://urldefense.us/v3/__https://orcid.org/0000-0003-1516-5337__;!!G_uCfscf7eWS!YiGxTKiNGs8EnS4pzFoO1YK18z4fx-sCtisUBloRO8dd6sUuh3kfUkimanAH5cJ-jgPhYw-Qk_8q8BBxAtPO0s_6$
> Embry-Riddle Aeronautical University
> Florida | Arizona | Worldwide
