[petsc-users] Fieldsplit and Fortran
TARDIEU Nicolas nicolas.tardieu at edf.fr
Tue Sep 16 11:02:30 CDT 2025
Dear Jose,
Thank you very much for you advice. The main branch indeed solved the problem I pointed out.
I can go to the next one  ;-)
Nicolas
Nicolas Tardieu
Ing PhD Computational Mechanics
EDF - R&D Dpt ERMES
PARIS-SACLAY, FRANCE
De : jroman at dsic.upv.es <jroman at dsic.upv.es>
Envoyé : lundi 15 septembre 2025 16:27
À : TARDIEU Nicolas <nicolas.tardieu at edf.fr>
Cc : petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Objet : Re: [petsc-users] Fieldsplit and Fortran
Expéditeur externe : Vérifier l’expéditeur avant de cliquer sur les liens ou pièces-jointes
External Sender : Check the sender before clicking any links or attachments
I would recommend trying in the development version (main branch) since it contains many fixes/changes to Fortran bindings. In particular, I think the issue you are reporting does not appear in main.
Jose
> El 15 sept 2025, a las 15:52, TARDIEU Nicolas via petsc-users <petsc-users at mcs.anl.gov> escribió:
> Dear PETSc Team,
> I am having difficulty upgrading the interface of our code to the new Fortran API (I am currently using v3.23.6).
> For instance, I cannot find a Fortran example demonstrating how to use PCFieldSplitGetSubKSP. I have therefore modified ksp/ps/tests/ex9.F90 to demonstrate the issues I am facing.
> I have provided some explanations in the test, but I would like to highlight one key point: the splits are generated automatically in the code based on the user's preferences. Therefore, I need to dynamically create sub-KSPs that are stored in a dedicated data structure (this explains the manipulations I am trying to set up in the test).
> Regards,
> Nicolas
> Nicolas Tardieu
> EDF - R&D Dpt ERMES
> Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
> Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
> ____________________________________________________
> This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
> If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
> E-mail communication cannot be guaranteed to be timely secure, error or virus-free.<ex9f.F90>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250916/0a00f372/attachment.html>
