[petsc-users] Options database in petsc4py
Mon Oct 27 05:26:42 CDT 2025
On Mon, Oct 27, 2025 at 10:24 AM SCOTTO Alexandre via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear PETSc Community,
> In my developments, I am managing possibly several KSP solvers with
> options handled by the Options database. During my tests, I encountered the
> following behavior:
> *Code*:
> options = PETSc.Options("ksp_")
> options.setValue("atol", 7e-8)
> options.view()
> options.clear()
> options.view()
> *Output*:
> #PETSc Option Table entries:
> -ksp_atol 7e-08 # (source: code)
> #End of PETSc Option Table entries
> It seems that the clear() method does not really clear the Option
> database. To ensure that the several KSP I deal with are set with their own
> options (without getting options from a KSP previously set), the only way I
> found was to explicitly call the delValue() method for all the option
> keys passed:
> 1.       Iterate over a dictionary of options and use setValue(name,
> value)
> 2.       Set the KSP with option database: KSP.setFromOptions()
> 3.       Iterate over a the keys of the dictionary and use delValue(name)
> to effectively clear the option database.
> Does it seem normal to you, is there something I am missing out?
That for pointing out this bug.
However, I don't think I would manage options this way. We normally give
each separate solver a new _prefix_, meaning a string that prefaces all its
options. That way they do not collide.
     Matt
> Regards,
> Alexandre Scotto.
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Yl5kWH4le9b9AulQe-MHUTGMJnJLSAUWTWCPTgED4vuWOpxiWWocOZMgkQeMjxEXM-FS5bHHbw1ItcybTP-F$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Yl5kWH4le9b9AulQe-MHUTGMJnJLSAUWTWCPTgED4vuWOpxiWWocOZMgkQeMjxEXM-FS5bHHbw1ItTjXdzbQ$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251027/2a20bf35/attachment.html>
