[petsc-users] Options database in petsc4py
SCOTTO Alexandre
alexandre.scotto at irt-saintexupery.com
Mon Oct 27 04:49:30 CDT 2025
In if this is a bug, I think the fix you proposed should also be applied to the destroy() method, as it does not clear the database either.
Alexandre.
De : Pierre Jolivet <pierre at joliv.et>
Envoyé : lundi 27 octobre 2025 10:36
À : SCOTTO Alexandre <alexandre.scotto at irt-saintexupery.com>
Cc : petsc-users at mcs.anl.gov
Objet : Re: [petsc-users] Options database in petsc4py
I would say this is a bug in petsc4py, the following diff should fix this.
I’m not sure why this if is there, as it’s perfectly valid to call PetscOptionsClear(NULL).
Pierre
diff --git a/src/binding/petsc4py/src/petsc4py/PETSc/Options.pyx b/src/binding/petsc4py/src/petsc4py/PETSc/Options.pyx
index 4db3c52f022..8a923a6dd8e 100644
--- a/src/binding/petsc4py/src/petsc4py/PETSc/Options.pyx
+++ b/src/binding/petsc4py/src/petsc4py/PETSc/Options.pyx
@@ -90,7 +90,6 @@ cdef class Options:
def clear(self) -> Self:
"""Clear an options database."""
- if self.opt == NULL: return
CHKERR(PetscOptionsClear(self.opt))
return self
On 27 Oct 2025, at 10:23 AM, SCOTTO Alexandre via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Dear PETSc Community,
In my developments, I am managing possibly several KSP solvers with options handled by the Options database. During my tests, I encountered the following behavior:
Code:
options = PETSc.Options("ksp_")
options.setValue("atol", 7e-8)
options.view()
options.clear()
options.view()
Output:
#PETSc Option Table entries:
-ksp_atol 7e-08 # (source: code)
#End of PETSc Option Table entries
It seems that the clear() method does not really clear the Option database. To ensure that the several KSP I deal with are set with their own options (without getting options from a KSP previously set), the only way I found was to explicitly call the delValue() method for all the option keys passed:
1. Iterate over a dictionary of options and use setValue(name, value)
2. Set the KSP with option database: KSP.setFromOptions()
3. Iterate over a the keys of the dictionary and use delValue(name) to effectively clear the option database.
Does it seem normal to you, is there something I am missing out?
Alexandre Scotto.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251027/f71805f4/attachment.html>
