[petsc-users] Options database in petsc4py
SCOTTO Alexandre alexandre.scotto at irt-saintexupery.com
Mon Oct 27 04:23:50 CDT 2025
Dear PETSc Community,
In my developments, I am managing possibly several KSP solvers with options handled by the Options database. During my tests, I encountered the following behavior:
Code:
options = PETSc.Options("ksp_")
options.setValue("atol", 7e-8)
options.view()
options.clear()
options.view()
Output:
#PETSc Option Table entries:
-ksp_atol 7e-08 # (source: code)
#End of PETSc Option Table entries
It seems that the clear() method does not really clear the Option database. To ensure that the several KSP I deal with are set with their own options (without getting options from a KSP previously set), the only way I found was to explicitly call the delValue() method for all the option keys passed:
1.       Iterate over a dictionary of options and use setValue(name, value)
2.       Set the KSP with option database: KSP.setFromOptions()
3.       Iterate over a the keys of the dictionary and use delValue(name) to effectively clear the option database.
Does it seem normal to you, is there something I am missing out?
Alexandre Scotto.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251027/373a3570/attachment.html>
