[petsc-users] Petsc + nvhpc
Junchao Zhang
junchao.zhang at gmail.com
Thu Oct 16 11:30:43 CDT 2025
Hi, Herbert,
I don't have much experience on OpenACC and PETSc CI doesn't have such
tests. Could you avoid using nvfortran and instead use gfortran to compile
your Fortran + OpenACC code? If you, then you can use the latest petsc
code and make our debugging easier.
Also, could you provide us with a test and instructions to reproduce the
problem?
Thanks!
--Junchao Zhang
On Thu, Oct 16, 2025 at 5:07 AM howen via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear All,
> I am interfacing our CFD code (Fortran + OpenACC) to Petsc.
> Since we use OpenACC the natural choice for us is to use Nvidia´s nvhpc
> compiler. The Gnu compiler does not work well and we do not have access to
> the Cray compiler.
> I already know that the latest version of Petsc does not compile with
> nvhpc, I am therefore using version 3.21.
> I get good results on the CPU both in serial and parallel (MPI). However,
> the GPU implementation, that is what we are interested in, only work
> correctly for the serial version. In parallel, the results are different.
> Even for a CG solve.
> I would like to know, if you have experience with the Nvidia compiler. I
> am particularly interested if you have already observed issues with it.
> Your opinion on whether to put further effort into trying to find a bug I
> may have introduced during the interfacing is highly appreciated.
> Best,
> Herbert Owen
> Senior Researcher, Dpt. Computer Applications in Science and Engineering
> Barcelona Supercomputing Center (BSC-CNS)
> Tel: +34 93 413 4038
> Skype: herbert.owen
> https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYAAAAJ&hl=en__;!!G_uCfscf7eWS!aTIjTK-Fcr9yL0t3yY0n7IDAF_kAHNA6X3j7omFcZJel4Laq7RWEgItjDi9CSvwBIXaih6jOEqyr6gaPlp-TJZZrsWBw$
> <https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYAAAAJ&hl=en__;!!G_uCfscf7eWS!abuM7ozzUs7eISYBumHNxpvO2Tuy74KRM4-WWcunXHZVjQf1V032xQrCzTfC5vA_NM-35xMEZ9yJ8XK-3QFqjWBSWuUi$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251016/ac48ee90/attachment.html>
