[petsc-users] setting correct tolerances for MG smoother CG at the finest level
Moral Sanchez, Elena
Elena.Moral.Sanchez at ipp.mpg.de
Tue Oct 14 11:45:44 CDT 2025
Unfortunately it did not print anything. Maybe something else is missing?
Elena
Sent: 14 October 2025 17:33:42
To: Moral Sanchez, Elena
Cc: petsc-users
Subject: Re: [petsc-users] setting correct tolerances for MG smoother CG at the finest level
Sorry, I was not clear, use the options
-mg_levels_ksp_convergence_test default -mg_levels_ksp_norm_type unpreconditioned
don't use the KSPSetConvergenceTest().
Barry
On Oct 14, 2025, at 10:03 AM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de> wrote:
Dear Barry,
Sorry for the delay in my answer.
I am using petsc4py. I tried to find an equivalent KSP method to replicate your line:
PetscCall(KSPSetConvergenceTest(mglevels[i]->smoothd, KSPConvergedSkip, NULL, NULL));
I tried to use KSP.setConvergenceTest ( https://urldefense.us/v3/__https://petsc.org/main/petsc4py/reference/petsc4py.PETSc.KSP.html*petsc4py.PETSc.KSP.setConvergenceTest__;Iw!!G_uCfscf7eWS!fGYp2C8AXd8R-o5y0VxH8O9NWrITZ01gW2020m422eI83rx2d-KAHjPnL_mOxjp3w6a7NTAAPW_romt6eQsC35r0T-_np009KNXy$ ). The first argument must be a callable but I am uncertain at what to pass to replicate KSPConvergedSkip.
Cheers,
Elena
From: Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>>
Sent: 10 October 2025 20:16:33
Cc: Mark Adams; petsc-users
Elana,
Were you able to try the options below?
Thanks for reporting the problem, since this is a problem others will face I have attempted to update/fix the PETSc code to make it absolutely clear when no convergence testing is done with https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/8777__;!!G_uCfscf7eWS!fGYp2C8AXd8R-o5y0VxH8O9NWrITZ01gW2020m422eI83rx2d-KAHjPnL_mOxjp3w6a7NTAAPW_romt6eQsC35r0T-_npzdcQwIT$
Barry
On Oct 7, 2025, at 10:53 AM, Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
I have to apologize again. What you are doing is so out of the ordinary (but there is nothing wrong with you doing it) that I totally lost this line of code
Please try the following, add the options
Barry
On Oct 7, 2025, at 4:12 AM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de<mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
The problem is that the fine grid solver is iterating past the prescribed tolerance. It iterates until the maximum number of iterations has been achieved.
Elena
From: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
Sent: 01 October 2025 13:25:14
To: Barry Smith
Cc: Moral Sanchez, Elena; petsc-users
Sorry to jump in, but what is the problem here? This looks fine to me, other than the coarse grid solver that I mentioned.
On Tue, Sep 30, 2025 at 9:27 AM Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
Would you be able to share your code? I'm at a loss as to why we are seeing this behavior and can much more quickly figure it out by running the code in a debugger.
Barry
You can send the code petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov> if you don't want to share the code with everyone,
On Sep 30, 2025, at 5:05 AM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de<mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
This is what I get:
Residual norms for mg_levels_1_ solve.
0 KSP Residual norm 2.249726733143e+00
0 KSP unpreconditioned resid norm 2.249726733143e+00 true resid norm 2.249726733143e+00 ||r(i)||/||b|| 1.000000000000e+00
1 KSP Residual norm 1.433120400946e+00
1 KSP unpreconditioned resid norm 1.433120400946e+00 true resid norm 1.433120400946e+00 ||r(i)||/||b|| 6.370197677051e-01
2 KSP Residual norm 1.169262560123e+00
2 KSP unpreconditioned resid norm 1.169262560123e+00 true resid norm 1.169262560123e+00 ||r(i)||/||b|| 5.197353718108e-01
3 KSP Residual norm 1.323528716607e+00
3 KSP unpreconditioned resid norm 1.323528716607e+00 true resid norm 1.323528716607e+00 ||r(i)||/||b|| 5.883064361148e-01
4 KSP Residual norm 5.006323254234e-01
4 KSP unpreconditioned resid norm 5.006323254234e-01 true resid norm 5.006323254234e-01 ||r(i)||/||b|| 2.225302824775e-01
5 KSP Residual norm 3.569836784785e-01
5 KSP unpreconditioned resid norm 3.569836784785e-01 true resid norm 3.569836784785e-01 ||r(i)||/||b|| 1.586786844906e-01
6 KSP Residual norm 2.493182937513e-01
6 KSP unpreconditioned resid norm 2.493182937513e-01 true resid norm 2.493182937513e-01 ||r(i)||/||b|| 1.108215900529e-01
7 KSP Residual norm 3.038202502298e-01
7 KSP unpreconditioned resid norm 3.038202502298e-01 true resid norm 3.038202502298e-01 ||r(i)||/||b|| 1.350476241198e-01
8 KSP Residual norm 2.780214194402e-01
8 KSP unpreconditioned resid norm 2.780214194402e-01 true resid norm 2.780214194402e-01 ||r(i)||/||b|| 1.235800843473e-01
9 KSP Residual norm 1.676826341491e-01
9 KSP unpreconditioned resid norm 1.676826341491e-01 true resid norm 1.676826341491e-01 ||r(i)||/||b|| 7.453466755710e-02
10 KSP Residual norm 1.209985378713e-01
10 KSP unpreconditioned resid norm 1.209985378713e-01 true resid norm 1.209985378713e-01 ||r(i)||/||b|| 5.378366007245e-02
11 KSP Residual norm 9.445076689969e-02
11 KSP unpreconditioned resid norm 9.445076689969e-02 true resid norm 9.445076689969e-02 ||r(i)||/||b|| 4.198321756516e-02
12 KSP Residual norm 8.308555284580e-02
12 KSP unpreconditioned resid norm 8.308555284580e-02 true resid norm 8.308555284580e-02 ||r(i)||/||b|| 3.693139776569e-02
13 KSP Residual norm 5.472865592585e-02
13 KSP unpreconditioned resid norm 5.472865592585e-02 true resid norm 5.472865592585e-02 ||r(i)||/||b|| 2.432680161532e-02
14 KSP Residual norm 4.357870564398e-02
14 KSP unpreconditioned resid norm 4.357870564398e-02 true resid norm 4.357870564398e-02 ||r(i)||/||b|| 1.937066622447e-02
15 KSP Residual norm 5.079681292439e-02
15 KSP unpreconditioned resid norm 5.079681292439e-02 true resid norm 5.079681292439e-02 ||r(i)||/||b|| 2.257910357558e-02
Linear mg_levels_1_ solve converged due to CONVERGED_ITS iterations 15
0 KSP Residual norm 5.079681292439e-02
0 KSP unpreconditioned resid norm 5.079681292439e-02 true resid norm 5.079681292439e-02 ||r(i)||/||b|| 2.257910357559e-02
1 KSP Residual norm 2.934938644003e-02
1 KSP unpreconditioned resid norm 2.934938644003e-02 true resid norm 2.934938644003e-02 ||r(i)||/||b|| 1.304575618348e-02
2 KSP Residual norm 3.257065831294e-02
2 KSP unpreconditioned resid norm 3.257065831294e-02 true resid norm 3.257065831294e-02 ||r(i)||/||b|| 1.447760647243e-02
3 KSP Residual norm 4.143063876867e-02
3 KSP unpreconditioned resid norm 4.143063876867e-02 true resid norm 4.143063876867e-02 ||r(i)||/||b|| 1.841585387164e-02
4 KSP Residual norm 4.822471409489e-02
4 KSP unpreconditioned resid norm 4.822471409489e-02 true resid norm 4.822471409489e-02 ||r(i)||/||b|| 2.143580968499e-02
5 KSP Residual norm 3.197538246153e-02
5 KSP unpreconditioned resid norm 3.197538246153e-02 true resid norm 3.197538246153e-02 ||r(i)||/||b|| 1.421300729127e-02
6 KSP Residual norm 3.461217019835e-02
6 KSP unpreconditioned resid norm 3.461217019835e-02 true resid norm 3.461217019835e-02 ||r(i)||/||b|| 1.538505529958e-02
7 KSP Residual norm 3.410193775327e-02
7 KSP unpreconditioned resid norm 3.410193775327e-02 true resid norm 3.410193775327e-02 ||r(i)||/||b|| 1.515825777899e-02
8 KSP Residual norm 4.690424294464e-02
8 KSP unpreconditioned resid norm 4.690424294464e-02 true resid norm 4.690424294464e-02 ||r(i)||/||b|| 2.084886233233e-02
9 KSP Residual norm 3.366148892800e-02
9 KSP unpreconditioned resid norm 3.366148892800e-02 true resid norm 3.366148892800e-02 ||r(i)||/||b|| 1.496247896783e-02
10 KSP Residual norm 4.068015727689e-02
10 KSP unpreconditioned resid norm 4.068015727689e-02 true resid norm 4.068015727689e-02 ||r(i)||/||b|| 1.808226602707e-02
11 KSP Residual norm 2.658836123104e-02
11 KSP unpreconditioned resid norm 2.658836123104e-02 true resid norm 2.658836123104e-02 ||r(i)||/||b|| 1.181848481389e-02
12 KSP Residual norm 2.826244186003e-02
12 KSP unpreconditioned resid norm 2.826244186003e-02 true resid norm 2.826244186003e-02 ||r(i)||/||b|| 1.256261102456e-02
13 KSP Residual norm 2.981793619508e-02
13 KSP unpreconditioned resid norm 2.981793619508e-02 true resid norm 2.981793619508e-02 ||r(i)||/||b|| 1.325402581380e-02
14 KSP Residual norm 3.525455091450e-02
14 KSP unpreconditioned resid norm 3.525455091450e-02 true resid norm 3.525455091450e-02 ||r(i)||/||b|| 1.567059251914e-02
15 KSP Residual norm 2.331539121838e-02
15 KSP unpreconditioned resid norm 2.331539121838e-02 true resid norm 2.331539121838e-02 ||r(i)||/||b|| 1.036365478300e-02
0 KSP Residual norm 2.421498365806e-02
0 KSP unpreconditioned resid norm 2.421498365806e-02 true resid norm 2.421498365806e-02 ||r(i)||/||b|| 1.000000000000e+00
1 KSP Residual norm 1.761072112362e-02
1 KSP unpreconditioned resid norm 1.761072112362e-02 true resid norm 1.761072112362e-02 ||r(i)||/||b|| 7.272654556492e-01
2 KSP Residual norm 1.400842489042e-02
2 KSP unpreconditioned resid norm 1.400842489042e-02 true resid norm 1.400842489042e-02 ||r(i)||/||b|| 5.785023474818e-01
3 KSP Residual norm 1.419665483348e-02
3 KSP unpreconditioned resid norm 1.419665483348e-02 true resid norm 1.419665483348e-02 ||r(i)||/||b|| 5.862756314004e-01
4 KSP Residual norm 1.617590701667e-02
4 KSP unpreconditioned resid norm 1.617590701667e-02 true resid norm 1.617590701667e-02 ||r(i)||/||b|| 6.680123036665e-01
5 KSP Residual norm 1.354824081005e-02
5 KSP unpreconditioned resid norm 1.354824081005e-02 true resid norm 1.354824081005e-02 ||r(i)||/||b|| 5.594982429624e-01
6 KSP Residual norm 1.387252917475e-02
6 KSP unpreconditioned resid norm 1.387252917475e-02 true resid norm 1.387252917475e-02 ||r(i)||/||b|| 5.728902967950e-01
7 KSP Residual norm 1.514043102087e-02
7 KSP unpreconditioned resid norm 1.514043102087e-02 true resid norm 1.514043102087e-02 ||r(i)||/||b|| 6.252505157414e-01
8 KSP Residual norm 1.275811124745e-02
8 KSP unpreconditioned resid norm 1.275811124745e-02 true resid norm 1.275811124745e-02 ||r(i)||/||b|| 5.268684640721e-01
9 KSP Residual norm 1.241039155981e-02
9 KSP unpreconditioned resid norm 1.241039155981e-02 true resid norm 1.241039155981e-02 ||r(i)||/||b|| 5.125087728764e-01
10 KSP Residual norm 9.585207801652e-03
10 KSP unpreconditioned resid norm 9.585207801652e-03 true resid norm 9.585207801652e-03 ||r(i)||/||b|| 3.958378802565e-01
11 KSP Residual norm 9.022641230732e-03
11 KSP unpreconditioned resid norm 9.022641230732e-03 true resid norm 9.022641230732e-03 ||r(i)||/||b|| 3.726057121550e-01
12 KSP Residual norm 1.187709152046e-02
12 KSP unpreconditioned resid norm 1.187709152046e-02 true resid norm 1.187709152046e-02 ||r(i)||/||b|| 4.904852172597e-01
13 KSP Residual norm 1.084880112494e-02
13 KSP unpreconditioned resid norm 1.084880112494e-02 true resid norm 1.084880112494e-02 ||r(i)||/||b|| 4.480201712351e-01
14 KSP Residual norm 8.194750346781e-03
14 KSP unpreconditioned resid norm 8.194750346781e-03 true resid norm 8.194750346781e-03 ||r(i)||/||b|| 3.384165136140e-01
15 KSP Residual norm 7.614246199165e-03
15 KSP unpreconditioned resid norm 7.614246199165e-03 true resid norm 7.614246199165e-03 ||r(i)||/||b|| 3.144435819857e-01
0 KSP Residual norm 7.614246199165e-03
0 KSP unpreconditioned resid norm 7.614246199165e-03 true resid norm 7.614246199165e-03 ||r(i)||/||b|| 3.144435819857e-01
1 KSP Residual norm 5.620014684145e-03
1 KSP unpreconditioned resid norm 5.620014684145e-03 true resid norm 5.620014684145e-03 ||r(i)||/||b|| 2.320883120759e-01
2 KSP Residual norm 6.643368363907e-03
2 KSP unpreconditioned resid norm 6.643368363907e-03 true resid norm 6.643368363907e-03 ||r(i)||/||b|| 2.743494878096e-01
3 KSP Residual norm 8.708642393659e-03
3 KSP unpreconditioned resid norm 8.708642393659e-03 true resid norm 8.708642393659e-03 ||r(i)||/||b|| 3.596385823189e-01
4 KSP Residual norm 6.401852907459e-03
4 KSP unpreconditioned resid norm 6.401852907459e-03 true resid norm 6.401852907459e-03 ||r(i)||/||b|| 2.643756856440e-01
5 KSP Residual norm 7.230576215262e-03
5 KSP unpreconditioned resid norm 7.230576215262e-03 true resid norm 7.230576215262e-03 ||r(i)||/||b|| 2.985992605803e-01
6 KSP Residual norm 6.204081601285e-03
6 KSP unpreconditioned resid norm 6.204081601285e-03 true resid norm 6.204081601285e-03 ||r(i)||/||b|| 2.562083744880e-01
7 KSP Residual norm 7.038656665944e-03
7 KSP unpreconditioned resid norm 7.038656665944e-03 true resid norm 7.038656665944e-03 ||r(i)||/||b|| 2.906736079337e-01
8 KSP Residual norm 7.194079694050e-03
8 KSP unpreconditioned resid norm 7.194079694050e-03 true resid norm 7.194079694050e-03 ||r(i)||/||b|| 2.970920730585e-01
9 KSP Residual norm 6.353576889135e-03
9 KSP unpreconditioned resid norm 6.353576889135e-03 true resid norm 6.353576889135e-03 ||r(i)||/||b|| 2.623820432363e-01
10 KSP Residual norm 7.313589502731e-03
10 KSP unpreconditioned resid norm 7.313589502731e-03 true resid norm 7.313589502731e-03 ||r(i)||/||b|| 3.020274391264e-01
11 KSP Residual norm 6.643320423193e-03
11 KSP unpreconditioned resid norm 6.643320423193e-03 true resid norm 6.643320423193e-03 ||r(i)||/||b|| 2.743475080142e-01
12 KSP Residual norm 7.235443182108e-03
12 KSP unpreconditioned resid norm 7.235443182108e-03 true resid norm 7.235443182108e-03 ||r(i)||/||b|| 2.988002504681e-01
13 KSP Residual norm 4.971292307201e-03
13 KSP unpreconditioned resid norm 4.971292307201e-03 true resid norm 4.971292307201e-03 ||r(i)||/||b|| 2.052981896416e-01
14 KSP Residual norm 5.357933842147e-03
14 KSP unpreconditioned resid norm 5.357933842147e-03 true resid norm 5.357933842147e-03 ||r(i)||/||b|| 2.212652264320e-01
15 KSP Residual norm 5.841682994497e-03
15 KSP unpreconditioned resid norm 5.841682994497e-03 true resid norm 5.841682994497e-03 ||r(i)||/||b|| 2.412424917146e-01
Cheers,
Elena
Sent: 29 September 2025 20:31:26
Thanks. I missed something earlier in the KSPView
using UNPRECONDITIONED norm type for convergence test
Please add the options
-ksp_monitor_true_residual -mg_levels_ksp_monitor_true_residual
It is using the unpreconditioned residual norms for convergence testing but we are printing the preconditioned norms.
Barry
On Sep 29, 2025, at 11:12 AM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de<mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
This is the output:
Sent: 29 September 2025 15:56:33
I asked you to run with
-ksp_monitor -mg_levels_ksp_monitor -ksp_converged_reason -mg_levels_ksp_converged_reason
you chose not to, delaying the process of understanding what is happening.
Please run with those options and send the output. My guess is that you are computing the "residual norms" in your own monitor code, and it is doing so differently than what PETSc does, thus resulting in the appearance of a sufficiently small residual norm, whereas PETSc may not have calculated something that small.
Barry
On Sep 29, 2025, at 8:39 AM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de<mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
Thanks for the hint. I agree that the coarse solve should be much more "accurate". However, for the moment I am just trying to understand what the MG is doing exactly.
I am puzzled to see that the fine grid smoother ("lvl 0") does not stop when the residual becomes less than 1e-1. It should converge due to the atol.
Sent: 29 September 2025 14:20:56
Cc: Barry Smith; petsc-users
Oh I see the coarse grid solver in your full solver output now.
You still want an accurate coarse grid solve. Usually (the default in GAMG) you use a direct solver on one process, and cousin until the coarse grid is small enough to make that cheap.
On Mon, Sep 29, 2025 at 8:07 AM Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de<mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
Hi, I doubled the system size and changed the tolerances just to show a better example of the problem. This is the output of the callbacks in the first iteration:
CG Iter 0/1 | res = 2.25e+00/1.00e-09 | 0.1 s
MG lvl 0 (s=884): CG Iter 0/15 | res = 2.25e+00/1.00e-01 | 0.3 s
MG lvl 0 (s=884): CG Iter 1/15 | res = 1.43e+00/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 2/15 | res = 1.17e+00/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 3/15 | res = 1.32e+00/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 4/15 | res = 5.01e-01/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 5/15 | res = 3.57e-01/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 6/15 | res = 2.49e-01/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 7/15 | res = 3.04e-01/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 8/15 | res = 2.78e-01/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 9/15 | res = 1.68e-01/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 10/15 | res = 1.21e-01/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 11/15 | res = 9.45e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 12/15 | res = 8.31e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 13/15 | res = 5.47e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 14/15 | res = 4.36e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 15/15 | res = 5.08e-02/1.00e-01 | 0.1 s
ConvergedReason MG lvl 0: 4
MG lvl -1 (s=524): CG Iter 0/15 | res = 8.15e-02/1.00e-01 | 3.0 s
ConvergedReason MG lvl -1: 3
MG lvl 0 (s=884): CG Iter 0/15 | res = 5.08e-02/1.00e-01 | 0.3 s
MG lvl 0 (s=884): CG Iter 1/15 | res = 2.93e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 2/15 | res = 3.26e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 3/15 | res = 4.14e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 4/15 | res = 4.82e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 5/15 | res = 3.20e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 6/15 | res = 3.46e-02/1.00e-01 | 0.3 s
MG lvl 0 (s=884): CG Iter 7/15 | res = 3.41e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 8/15 | res = 4.69e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 9/15 | res = 3.37e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 10/15 | res = 4.07e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 11/15 | res = 2.66e-02/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 12/15 | res = 2.83e-02/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 13/15 | res = 2.98e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 14/15 | res = 3.53e-02/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 15/15 | res = 2.33e-02/1.00e-01 | 0.2 s
CG Iter 1/1 | res = 2.42e-02/1.00e-09 | 5.6 s
MG lvl 0 (s=884): CG Iter 0/15 | res = 2.42e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 1/15 | res = 1.76e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 2/15 | res = 1.40e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 3/15 | res = 1.42e-02/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 4/15 | res = 1.62e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 5/15 | res = 1.35e-02/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 6/15 | res = 1.39e-02/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 7/15 | res = 1.51e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 8/15 | res = 1.28e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 9/15 | res = 1.24e-02/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 10/15 | res = 9.59e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 11/15 | res = 9.02e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 12/15 | res = 1.19e-02/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 13/15 | res = 1.08e-02/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 14/15 | res = 8.19e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 15/15 | res = 7.61e-03/1.00e-01 | 0.1 s
MG lvl -1 (s=524): CG Iter 0/15 | res = 1.38e-02/1.00e-01 | 5.2 s
MG lvl 0 (s=884): CG Iter 0/15 | res = 7.61e-03/1.00e-01 | 0.2 s
MG lvl 0 (s=884): CG Iter 1/15 | res = 5.62e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 2/15 | res = 6.64e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 3/15 | res = 8.71e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 4/15 | res = 6.40e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 5/15 | res = 7.23e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 6/15 | res = 6.20e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 7/15 | res = 7.04e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 8/15 | res = 7.19e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 9/15 | res = 6.35e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 10/15 | res = 7.31e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 11/15 | res = 6.64e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 12/15 | res = 7.24e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 13/15 | res = 4.97e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 14/15 | res = 5.36e-03/1.00e-01 | 0.1 s
MG lvl 0 (s=884): CG Iter 15/15 | res = 5.84e-03/1.00e-01 | 0.1 s
CG ConvergedReason: -3
For completeness, I add here the -ksp_view of the whole solver:
KSP Object: 1 MPI process
type: cg
variant HERMITIAN
maximum iterations=1, nonzero initial guess
tolerances: relative=1e-08, absolute=1e-09, divergence=10000.
left preconditioning
PC Object: 1 MPI process
type: mg
type is MULTIPLICATIVE, levels=2 cycles=v
Cycles per PCApply=1
Not using Galerkin computed coarse grid matrices
Coarse grid solver -- level 0 -------------------------------
KSP Object: (mg_coarse_) 1 MPI process
type: cg
variant HERMITIAN
maximum iterations=15, nonzero initial guess
tolerances: relative=0.1, absolute=0.1, divergence=1e+30
PC Object: (mg_coarse_) 1 MPI process
type: none
linear system matrix = precond matrix:
Mat Object: 1 MPI process
type: python
rows=524, cols=524
Python: Solver_petsc.LeastSquaresOperator
Down solver (pre-smoother) on level 1 -------------------------------
KSP Object: (mg_levels_1_) 1 MPI process
type: cg
variant HERMITIAN
PC Object: (mg_levels_1_) 1 MPI process
type: none
type: python
rows=884, cols=884
Up solver (post-smoother) same as down solver (pre-smoother)
type: python
rows=884, cols=884
Regarding Mark's Email: What do you mean with "the whole solver doesn't have a coarse grid"? I am using my own Restriction and Interpolation operators.
Thanks for the help,
Elena
Sent: 28 September 2025 20:13:54
To: Barry Smith
Not sure why your "whole"solver does not have a coarse grid but this is wrong:
type: cg
variant HERMITIAN
maximum iterations=100, initial guess is zero
The coarse grid has to be accurate. The defaults are a good place to start: max_it=10.000, rtol=1e-5, atol=1e-30 (ish)
On Fri, Sep 26, 2025 at 3:21 PM Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
Looks reasonable. Send the output running with
On Sep 26, 2025, at 1:19 PM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de<mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
Dear Barry,
This is -ksp_view for the smoother at the finest level:
type: cg
variant HERMITIAN
maximum iterations=10, nonzero initial guess
type: none
type: python
rows=524, cols=524
And at the coarsest level:
type: cg
variant HERMITIAN
type: none
type: python
rows=344, cols=344
And for the whole solver:
type: cg
variant HERMITIAN
maximum iterations=100, nonzero initial guess
type: mg
type: cg
variant HERMITIAN
type: none
type: python
rows=344, cols=344
type: cg
variant HERMITIAN
type: none
type: python
rows=524, cols=524
type: python
rows=524, cols=524
Best,
Elena
Sent: 26 September 2025 19:05:02
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Send the output using -ksp_view
Normally one uses a fixed number of iterations of smoothing on level with multigrid rather than a tolerance, but yes PETSc should respect such a tolerance.
Barry
On Sep 26, 2025, at 12:49 PM, Moral Sanchez, Elena <Elena.Moral.Sanchez at ipp.mpg.de<mailto:Elena.Moral.Sanchez at ipp.mpg.de>> wrote:
I am using multigrid (multiplicative) as a preconditioner with a V-cycle of two levels. At each level, I am setting CG as the smoother with certain tolerance.
What I observe is that in the finest level the CG continues iterating after the residual norm reaches the tolerance (atol) and it only stops when reaching the maximum number of iterations at that level. At the coarsest level this does not occur and the CG stops when the tolerance is reached.
I double-checked that the smoother at the finest level has the right tolerance. And I am using a Monitor function to track the residual.
Do you know how to make the smoother at the finest level stop when reaching the tolerance?
Cheers,
Elena.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251014/4acba79e/attachment-0001.html>
