[petsc-users] [GPU] Jacobi preconditioner
Barry Smith
bsmith at petsc.dev
Wed Oct 1 19:16:40 CDT 2025
Sorry about that. The current code is buggy anyways; I will let you know when I have tested it extensively so you can try again.
Barry
> On Oct 1, 2025, at 3:47 PM, LEDAC Pierre <Pierre.LEDAC at cea.fr> wrote:
> Sorry the correct error is:
> /export/home/catA/pl254994/trust/petsc/lib/src/LIBPETSC/build/petsc-barry-2025-09-30-add-matgetdiagonal-cuda/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu(3765): error: argument of type "int*" is incompatible with parameter of type "const PetscInt *"
> GetDiagonal_CSR<<<(int)((n + 255) / 256), 256, 0, PetscDefaultCudaStream>>>(cusparsestruct->rowoffsets_gpu->data().get(), matstruct->cprowIndices->data().get(), cusparsestruct->workVector->data().get(), n, darray);
> Pierre LEDAC
> Commissariat à l’énergie atomique et aux énergies alternatives
> Centre de SACLAY
> DES/ISAS/DM2S/SGLS/LCAN
> Bâtiment 451 – point courrier n°41
> F-91191 Gif-sur-Yvette
> +33 1 69 08 04 03
> +33 6 83 42 05 79
> De : LEDAC Pierre
> Envoyé : mercredi 1 octobre 2025 21:46:00
> À : Barry Smith
> Cc : Junchao Zhang; petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
> Objet : RE: [petsc-users] [GPU] Jacobi preconditioner
> Hi all,
> Thanks for the MR, there is a build issue cause we use --with-64-bit-indices:
> /export/home/catA/pl254994/trust/petsc/lib/src/LIBPETSC/build/petsc-barry-2025-09-30-add-matgetdiagonal-cuda/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu(3765): error: argument of type "PetscInt" is incompatible with parameter of type "const PetscInt *"
> Thanks,
> Pierre LEDAC
> Centre de SACLAY
> +33 1 69 08 04 03
> +33 6 83 42 05 79
> De : Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Envoyé : mercredi 1 octobre 2025 18:48:37
> À : LEDAC Pierre
> Objet : Re: [petsc-users] [GPU] Jacobi preconditioner
> I have finally created an MR that moves the Jacobi accessing of the diagonal to the GPU, which should improve the GPU performance of your code. https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/8756__;!!G_uCfscf7eWS!dzuxOoOUatxToc7TIXOe_lHWwFJf4p7OkCsU3kBG-UwhwYKWsW7nmw9g3sZmJq9UcS1KgnPvlIFK27vJGYCgWDc$
> Please give it a try and let us know if it causes any difficulties or, hopefully, improves your code's performance significantly.
> Sorry for the long delay, NVIDIA is hiring too many PETSc developers away from us.
> Barry
>> On Jul 31, 2025, at 6:46 AM, LEDAC Pierre <Pierre.LEDAC at cea.fr <mailto:Pierre.LEDAC at cea.fr>> wrote:
>> Thanks Barry, I agree but didn't dare asking for that.
>> Pierre LEDAC
>> Centre de SACLAY
>> +33 1 69 08 04 03
>> +33 6 83 42 05 79
>> Envoyé : mercredi 30 juillet 2025 20:34:26
>> À : Junchao Zhang
>> Cc : LEDAC Pierre; petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
>> We absolutely should have a MatGetDiagonal_SeqAIJCUSPARSE(). It's somewhat embarrassing that we don't provide this.
>> I have found some potential code at https://urldefense.us/v3/__https://stackoverflow.com/questions/60311408/how-to-get-the-diagonal-of-a-sparse-matrix-in-cusparse__;!!G_uCfscf7eWS!dzuxOoOUatxToc7TIXOe_lHWwFJf4p7OkCsU3kBG-UwhwYKWsW7nmw9g3sZmJq9UcS1KgnPvlIFK27vJar78Rs8$
>> Barry
>>> On Jul 28, 2025, at 11:43 AM, Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>> Yes, MatGetDiagonal_SeqAIJCUSPARSE hasn't been implemented. petsc/cuda and petsc/kokkos backends are separate code.
>>> If petsc/kokkos meet your needs, then just use them. For petsc users, we hope it will be just a difference of extra --download-kokkos --download-kokkos-kernels in configuration.
>>> --Junchao Zhang
>>> On Mon, Jul 28, 2025 at 2:51 AM LEDAC Pierre <Pierre.LEDAC at cea.fr <mailto:Pierre.LEDAC at cea.fr>> wrote:
>>>> Hello all,
>>>> We are solving with PETSc a linear system updated every time step (constant stencil but coefficients changing).
>>>> The matrix is preallocated once with MatSetPreallocationCOO() then filled each time step with MatSetValuesCOO() and we use device pointers for coo_i, coo_j, and coefficients values.
>>>> It is working fine with a GMRES Ksp solver and PC Jacobi but we are surprised to see that every time step, during PCSetUp, MatGetDiagonal_SeqAIJ is called whereas the matrix is on the device. Looking at the API, it seems there is no MatGetDiagonal_SeqAIJCUSPARSE() but a MatGetDiagonal_SeqAIJKOKKOS().
>>>> Does it mean we should use Kokkos backend in PETSc to have Jacobi preconditioner built directly on device ? Or I am doing something wrong ?
>>>> NB: Gmres is running well on device.
>>>> I could use -ksp_reuse_preconditioner to avoid Jacobi being recreated each solve on host but it increases significantly the number of iterations.
>>>> Thanks,
>>>> <pastedImage.png>
>>>> Pierre LEDAC
>>>> Centre de SACLAY
>>>> +33 1 69 08 04 03
>>>> +33 6 83 42 05 79
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251001/39f2d984/attachment.html>
