[petsc-users] Proper way for exception handling
Zou, Ling lzou at anl.gov
Wed Oct 1 13:42:26 CDT 2025
Thank you, Barry. I got a working code following your suggestion. See below.
-Ling
Date: Wednesday, October 1, 2025 at 11:36 AM
To: Zou, Ling <lzou at anl.gov>
Cc: PETSc <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Proper way for exception handling
No. Your callback function should not be returning a PETSC_ERR_NOT_CONVERGED since your function doesn't know anything about the status of the nonlinear solver and is not in the business of deciding if SNES is converging or not. What are you
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
•  You are right. I implemented the code as proposed in the email. It did not go the way I expected.
What are you trying to convey back to PETSc if your function is not "all good"?
There are generally two possibilities,
1) just give up and stop the entire program immediately, then return PETSC_ERR_USER
<- Not what I am looking for.
2) indicate that SNES solve is asking your function to be evaluated at a point that is not in the domain of your function. For example, say your function is the square root and x is -1. In this situation, depending on the exact nonlinear solver being used SNES may be able to continue to try to solve the nonlinear system by changing its x value.  To indicate this call SNESSetFunctionDomainError(snes); and then do a usual return PETSC_SUCCESS; If SNES can continue it will, if it cannot then IT will generate a negative SNESConvergedReason indicating that SNES did not converge.
<- Yes. This is what I am looking for. To provide some context, it is a flow problem solver that solves for pressure (p) and temperature (T) nonlinear variables. Density and other properties are evaluated based on p and T. In some case, p and T go out of the physical domain, e.g., negative value, equation of state package will throw an exception, instead of error out, because the code wants to try, for example, a smaller time step size.
Following your suggestion, the following code works now, thank you!
PetscErrorCode SNESFormFunction(SNES, Vec, Vec, void*);
double my_function();
  if (all_good) // e.g., pressure > 0
return 1;
  else // e.g., pressure < 0
throw 199;
return 0;
PetscErrorCode SNESFormFunction(SNES snes, Vec u, Vec r, void* ctx)
  Try
my_value = my_function();
  Catch (int err)
  // compute residuals
int main(int argc, char **argv)
  Initialize_PETSc();
  double dt = 1, dt_min = 0.001;
  while (dt > dt_min)
SNESSolve(AppCtx.snes, NULL, AppCtx.u);
SNESGetConvergedReason(AppCtx.snes, &(AppCtx.snes_converged_reason));
if (not_converged)
  dt *= 0.5;
  PetscFinalize();
Barry
On Oct 1, 2025, at 11:46 AM, Zou, Ling via petsc-users <petsc-users at mcs.anl.gov> wrote:
Although I haven’t tried yet. Does it make sense and should it work to change the code this way?
  if (all_good)
return 1;
  else
throw 199;
return 0;
  Try
  Catch (int err)
    return PETSC_ERR_NOT_CONVERGED;
  Initialize_PETSc();
  while (dt > dt_min)
if (not_converged)
  dt *= 0.5;
  PetscFinalize();
From: petsc-users <petsc-users-bounces at mcs.anl.gov<mailto:petsc-users-bounces at mcs.anl.gov>> on behalf of Zou, Ling via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Date: Wednesday, October 1, 2025 at 9:33 AM
To: PETSc <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Subject: [petsc-users] Proper way for exception handling
After updating to PETSc 3.23 (from a quite old version, ~3.8), I found that my old way of exception handling not working any more, on my Mac.
I would like to learn the proper way to handle exceptions in PETSc code.
Here is my pseudo code:
  if (all_good)
return 1;
  else
throw 199;
return 0;
  double my_value = my_function();
  Initialize_PETSc();
  while (dt > dt_min)
try
catch (int err)
  dt *= 0.5;
  PetscFinalize();
This piece of logic used to work well, but now giving me the following error:
Current time (the starting time of this time step) = 0..
        NL step =  0, SNES Function norm =  8.60984E+03
libc++abi: terminating due to uncaught exception of type int
Abort trap: 6
Q1: why this exception catch logic not working any more?
Q2: is there any good example of PETSc exception handling I can follow?
Best,
-Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251001/ba232650/attachment-0001.html>
