[petsc-users] solveBackward in parallel
Yin Shi
yin.shi1 at icloud.com
Sat Nov 22 05:58:57 CST 2025
Thank you very much for your reply. Given this, when using MUMPS in parallel, I can still get the factor matrix (using getFactorMatrix method of a PC object) and use it to do matrix multiplications (e.g., using matMult method of the factor matrix), correct? I also would like to confirm whether the factor matrix returned is really triangular and multiplying it with another matrix gives the intended result.
> On Nov 16, 2025, at 08:59, Barry Smith <bsmith at petsc.dev> wrote:
> It appears that only MATSOLVERMKL_CPARDISO provides a parallel backward solve currently.
> The only seperation of forward and backward solves in MUMPS appears to be provided with (from its users manual)
> A special case is the one
> where the forward elimination step is performed during factorization (see Subsection 3.8), instead of
> during the solve phase. This allows accessing the L factors right after they have been computed, with a
> better locality, and can avoid writing the L factors to disk in an out-of-core context. In this case (forward
>> On Nov 15, 2025, at 9:17 AM, Yin Shi via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Dear Developers,
>> In short, I need to explicitly use A.solveBackward(b, x) in parallel with petsc4py, where A is a Cholesky factored matrix, but it seems that this is not supported (e.g., for mumps and superlu_dist factorization solver backend). Is it possible to work around this?
>> In detail, the problem I need to solve is to generate a set of correlated random numbers (denoted by a vector, w) from an uncorrelated one (denoted by a vector n). Denote the covariance matrix of n as C (symmetric). One needs to first factorize C, C = L L^T, and then solve the linear system L^T w = n for w in parallel. Is it possible to reformulate this problem for it to be implemented using petsc4py?
>> Thank you!
>> Yin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251122/2464031c/attachment-0001.html>
