[petsc-users] Ordering of DoFs in submatrices with PCFieldsplit
Matthew Knepley
knepley at gmail.com
Tue Nov 18 10:23:27 CST 2025
On Tue, Nov 18, 2025 at 11:12 AM Blauth, Sebastian <
sebastian.blauth at itwm.fraunhofer.de> wrote:
> Dear PETSc developers and users,
> I have a question regarding the Fieldsplit preconditioner in PETSc. In
> particular, I want to know how the submatrices there are created from the
> parent matrix. The “obvious” way would be to take the DoF indices of the
> corresponding split and “renumber” them so that the DoFs in the submatrix
> have the same order as the ones of the parent matrix. I did not find any
> documentation on this and as it is at least possible that the DoFs are
> re-ordered, I wanted to ask this question. Obviously, in case the DoFs are
> re-ordered, how can I get the mapping between the DoFs of the parent and
> the submatrix?
Hi Sebastian,
Inside, we call MatCreateSubmatrix(), which takes an IS on each process,
and selects those global rows, in the order in which they appear in the IS,
into a new parallel matrix. PCFieldsplitSetIS() can be used to specify
those IS, so you can control the reordering. Does that make sense?
> The thing I am wanting to work on is implementing a pressure convection
> diffusion preconditioner with FEniCS for the incompressible Navier-Stokes
> equations.
The parent matrix is assembled via a mixed FEM and then I use PETSc to
> solve the system. I want to assemble the corresponding operators on the
> pressure space from a collapsed (i.e. sub-space of the mixed FEM) function
> space. However, FEniCS re-orders the DoFs there, but I can get a mapping
> between the DoFs so this should not be problematic. However, I am not sure
> if PETSc also does a re-ordering.
You can just create an IS with that reordering. What operator are you
planning on assembling on the pressure space? Have you seen
https://urldefense.us/v3/__https://arxiv.org/abs/1810.03315?__;!!G_uCfscf7eWS!ZFlvrtpVlFuXdYWcwujVNh1WjnSmuEKqsh1s3GCYbyN0_wNsVgBaJo3x-lWG3Iea3iQhp_iniM9QzDSr9iD3$
Matt
> Thanks a lot in advance and best regards,
> Sebastian
> Dr. Sebastian Blauth
> Fraunhofer-Institut für
> Techno- und Wirtschaftsmathematik ITWM
> Abteilung Transportvorgänge
> Fraunhofer-Platz 1, 67663 Kaiserslautern
> Telefon: +49 631 31600-4968
> https://urldefense.us/v3/__https://www.itwm.fraunhofer.de__;!!G_uCfscf7eWS!ZFlvrtpVlFuXdYWcwujVNh1WjnSmuEKqsh1s3GCYbyN0_wNsVgBaJo3x-lWG3Iea3iQhp_iniM9QzNhlmkaU$
> <https://urldefense.us/v3/__https://www.itwm.fraunhofer.de/__;!!G_uCfscf7eWS!f_qaoCRxX3prMgl6ev5fvSFQegVfZo84xW9eJTz7uYmLjZiyJFIlm1tlqYrM3LqjOpkEoMrIJZo6J63-23-atPBnJn4et_4R-UvZoWlBpHM$>
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZFlvrtpVlFuXdYWcwujVNh1WjnSmuEKqsh1s3GCYbyN0_wNsVgBaJo3x-lWG3Iea3iQhp_iniM9QzGRu26U1$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZFlvrtpVlFuXdYWcwujVNh1WjnSmuEKqsh1s3GCYbyN0_wNsVgBaJo3x-lWG3Iea3iQhp_iniM9QzPGY9jGb$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251118/4b7361fd/attachment-0001.html>
