[petsc-users] gpu cpu parallel
Wenbo Zhao
zhaowenbo.npic at gmail.com
Tue Nov 11 19:50:10 CST 2025
Dear all,
We are trying to solve ksp using GPUs.
We found the example, src/ksp/ksp/tutorials/bench_kspsolve.c, in which the
matrix is created and assembling using COO way provided by PETSc. In this
example, the number of CPU is as same as the number of GPU.
In our case, computation of the parameters of matrix is performed on CPUs.
And the cost of it is expensive, which might take half of total time or
even more.
We want to use more CPUs to compute parameters in parallel. And a smaller
communication domain (such as gpu_comm) for the CPUs corresponding to the
GPUs is created. The parameters are computed by all of the CPUs (in
MPI_COMM_WORLD). Then, the parameters are send to gpu_comm related CPUs via
MPI. Matrix (type of aijcusparse) is then created and assembled within
gpu_comm. Finally, ksp_solve is performed on GPUs.
I’m not sure if this approach will work in practice. Are there any
comparable examples I can look to for guidance?
Best,
Wenbo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251112/5ef23773/attachment.html>
