[petsc-users] Questions about PetscTabulation for finite element basis, and PetscViewerVTK for saving cell data
    Gong Yujie
    yc17470 at connect.um.edu.mo
    Mon May 26 03:45:40 CDT 2025
Dear PETSc developers,
I have a code that uses PETSc to solve the elasticity problem with the finite element discretization written by myself.  I found there is a part called "PetscTabulation" that stores the basis functions. I would like to inquire about this part that can I use this part for achieving high order element? In detail, how does the basis functions be evaluated and in which file can I find the basis functions? I'm thinking about using PetscTabulation and PetscQuadrature to achieve a high order element. Is this doable?
The next question is can I output a vector that the unknown is defined on each element (not point) using VecView? I think this question relates to the PetscViewer for VTK.
Thanks in advance for your help!
Best Regards,
Jerry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250526/b999e25b/attachment.html>
