[petsc-users] Questions about PCEXOTIC
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu May 22 03:33:25 CDT 2025
GDSW is algebraic, not restricted to DMDA. Here is an example command line.
-pc_type mg -pc_mg_levels 2 -pc_mg_adapt_interp_coarse_space *gdsw*
-pc_mg_galerkin -mg_levels_pc_type jacobi
If you have a MATIS matrix, you can also turn on adaptivity (see for
example these tests).
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/ksp/tutorials/ex71.c*L727__;Iw!!G_uCfscf7eWS!dU8Plji5xR1NEXhvUg83_jf1O061HWdtZYZjkpWxufOe3ZueuCJ7WMjvMquhjDVHAspyVJpaem8_0EkiWRiVIYI6IyiGlDw$
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex12.c*L1799__;Iw!!G_uCfscf7eWS!dU8Plji5xR1NEXhvUg83_jf1O061HWdtZYZjkpWxufOe3ZueuCJ7WMjvMquhjDVHAspyVJpaem8_0EkiWRiVIYI6ndo6f0o$
Code setup is here
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/mg/gdsw.c__;!!G_uCfscf7eWS!dU8Plji5xR1NEXhvUg83_jf1O061HWdtZYZjkpWxufOe3ZueuCJ7WMjvMquhjDVHAspyVJpaem8_0EkiWRiVIYI6bWXW_Co$
Il giorno gio 22 mag 2025 alle ore 10:59 Edoardo Centofanti <
edoardo.centofanti01 at universitadipavia.it> ha scritto:
> Dear all,
> Thank you for your answers.
> Do you know which options are required for a typical use case of GDSW in
> PCMG? However, I imagine that only structured DMDA meshes can be employed
> with it.
> Best,
> Edoardo
> Il giorno mer 21 mag 2025 alle ore 16:52 Barry Smith <bsmith at petsc.dev>
> ha scritto:
>>   Thanks for your interest in this type of algorithm.
>>   As Pierre notes, the code is implemented only as a simple tutorial on
>> one particular "exotic" wire basket-type algorithm. We don't recommend this
>> implementation for more general algorithms or geometries.
>>   The face dof represents some sort of "average" of the face solution, it
>> is not a point value.
>>   Barry
>> On May 21, 2025, at 4:51 AM, Pierre Jolivet <pierre at joliv.et> wrote:
>> On 21 May 2025, at 10:41 AM, Edoardo Centofanti <
>> edoardo.centofanti01 at universitadipavia.it> wrote:
>> Dear all,
>> I have some questions about the PCEXOTIC preconditioner:
>> 1- While the type "wirebasket" seems clear to me, I do not understand
>> what is meant as "one dof per face" in the documentation referring to
>> "face" type. Is it intended as the interpolation on the centre of the face
>> or some mean value?
>> 2- Is it possible to change the overlap between the subdomains?
>> 3- Are there any plans of extending the implementation to unstructured
>> grids (DMPlex-like)? The current one seems to rely heavily on DMDA
>> 4- Running some preliminary tests on GPU with a code of mine that works
>> on CPU, I got the following error:
>>  ** On entry to cusparseSpMM_bufferSize(): dimension mismatch,
>> matA.num_rows (15405) != matC.num_rows (44955) with opA =
>> CUSPARSE_OPERATION_NON_TRANSPOSE
>> Is the preconditioner intended to run also on GPU or the error above
>> comes from the fact that this feature has yet to be tested/fully
>> implemented?
>> This preconditioner is very old and the code is barely maintained.
>> There is a newer implementation of the GDSW preconditioner in PCMG, see
>> https://urldefense.us/v3/__https://petsc.org/release/manualpages/PC/PCMGSetAdaptCoarseSpaceType/__;!!G_uCfscf7eWS!dU8Plji5xR1NEXhvUg83_jf1O061HWdtZYZjkpWxufOe3ZueuCJ7WMjvMquhjDVHAspyVJpaem8_0EkiWRiVIYI68ia6R0o$
>> <https://urldefense.us/v3/__https://petsc.org/release/manualpages/PC/PCMGSetAdaptCoarseSpaceType/__;!!G_uCfscf7eWS!ZDnv3udGFNlZEC_MRfLAqwvcvCObnaAjMCeyaW__UaecBvN3MkXrzOPwJJUSHXo80-xOQdLNnSf_nLmUd7bZxg$>
>> Thanks,
>> Pierre
>> Thank you in advance,
>> Best,
>> Edoardo
> Edoardo Centofanti
> Dipartimento di Matematica 'Felice Casorati'
> Università degli Studi di Pavia
> Tel. 0382985608  |  Ufficio A14  |  Via Ferrata 5, 27100 Pavia, Italy
> <https://urldefense.us/v3/__https://maps.google.com/?q=Via*20Ferrata*205,*2027100*20Pavia,*20Italy__;JSUlJSU!!G_uCfscf7eWS!Zmi6sdgeoCOMy1lkVGYn-ac5wvH3QEcOkYQ2VzdQgCqLY8nIVkX1oi_yt5S2vJDcF5BT8mmzOLmOUEK483D0v9_aZe01iy1b20hMoN_kNHg$>
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250522/373a8470/attachment-0001.html>
