[petsc-users] Questions about PCEXOTIC
    Pierre Jolivet
    pierre at joliv.et
    Wed May 21 03:51:53 CDT 2025
> On 21 May 2025, at 10:41 AM, Edoardo Centofanti <edoardo.centofanti01 at universitadipavia.it> wrote:
> Dear all,
> I have some questions about the PCEXOTIC preconditioner:
> 1- While the type "wirebasket" seems clear to me, I do not understand what is meant as "one dof per face" in the documentation referring to "face" type. Is it intended as the interpolation on the centre of the face or some mean value?
> 2- Is it possible to change the overlap between the subdomains?
> 3- Are there any plans of extending the implementation to unstructured grids (DMPlex-like)? The current one seems to rely heavily on DMDA
> 4- Running some preliminary tests on GPU with a code of mine that works on CPU, I got the following error:
>  ** On entry to cusparseSpMM_bufferSize(): dimension mismatch, matA.num_rows (15405) != matC.num_rows (44955) with opA = CUSPARSE_OPERATION_NON_TRANSPOSE
> Is the preconditioner intended to run also on GPU or the error above comes from the fact that this feature has yet to be tested/fully implemented?
This preconditioner is very old and the code is barely maintained.
There is a newer implementation of the GDSW preconditioner in PCMG, see https://urldefense.us/v3/__https://petsc.org/release/manualpages/PC/PCMGSetAdaptCoarseSpaceType/__;!!G_uCfscf7eWS!ZDnv3udGFNlZEC_MRfLAqwvcvCObnaAjMCeyaW__UaecBvN3MkXrzOPwJJUSHXo80-xOQdLNnSf_nLmUd7bZxg$
Pierre
> Thank you in advance,
> Best,
> Edoardo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250521/b369c61b/attachment-0001.html>
