[petsc-users] Element connectivity of a DMPlex
    Mark Adams
    mfadams at lbl.gov
    Wed May 21 02:42:51 CDT 2025
Hi Noam,
I think you want
https://urldefense.us/v3/__https://petsc.org/release/manualpages/DMPlex/DMPlexGetClosureIndices/__;!!G_uCfscf7eWS!f8v1_ty7e_mf4QhytGsCFXSd_APEy50GjoLrAL_o294K-EBz1Xa8kEDmeq3UmehbZvBL-u72r4GN6mjxAFf6Ljw$
Indices are ordered globally on the first process (0) first, the proc 1,
etc., so the global index is the local index + "my start index". You can
get this local start index in a number of ways, eg,
https://urldefense.us/v3/__https://petsc.org/main/manualpages/Mat/MatGetOwnershipRange__;!!G_uCfscf7eWS!f8v1_ty7e_mf4QhytGsCFXSd_APEy50GjoLrAL_o294K-EBz1Xa8kEDmeq3UmehbZvBL-u72r4GN6mjxh3g3zew$  if you have a
scalar matrix from the DM/section.
ps, we are at the PETSc annual meeting this week, so may be slow to respond
On Mon, May 19, 2025 at 6:58 PM Noam T. via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> I am trying to build the connectivity matrix for a mesh; i.e. the indices
> of the nodes that compose each cell.
> Example:
> 0-------1
> 3-------2
> the matrix would look like  [ [0, 3, 2], [2, 1, 0] ] (possibly different
> ordering).
> One option is using DMPlexGetTransitiveClosure, and accessing the last
> elements in the output "points", which contain the vertex indices.
> However, these indices are local per process (both for vertices and
> cells). Is it possible to get the global indices?
> I tried a mapping, as in example 14f (
> https://urldefense.us/v3/__https://petsc.org/release/src/ksp/ksp/tutorials/ex14f.F90.html__;!!G_uCfscf7eWS!f8v1_ty7e_mf4QhytGsCFXSd_APEy50GjoLrAL_o294K-EBz1Xa8kEDmeq3UmehbZvBL-u72r4GN6mjxUrZKlTM$
> <https://urldefense.us/v3/__https://petsc.org/release/src/ksp/ksp/tutorials/ex14f.F90.html__;!!G_uCfscf7eWS!ezMKlDED-8WxXpg_Elxus7WhYkZzCA5OmmLe6vHZGFoj4se5S5RD5ZgTrC3TYErx8znYKebSW-s0H0mt1_MEMAzpmFDwr0PH$>
> DM :: dm
> ISLocalToGlobalMapping :: ltog_map
> PetscInt, pointer :: ltog_idx(:)
> ! Create a dm from a mesh file
> DMGetLocalToGlobalMapping(dm,ltog_map,ierr)
> ISLocalToGlobalMappingGetIndices(ltog_map, ltog_idx, ierr)
> but the returned array ltog is empty (ISLocalToGlobalMappingGetSize()
> returns zero).  Are there other functions calls needed before being able
> to create this mapping? Or is this mapping simply not usable in this case?
> Is there perhaps better/simpler way to get this connectivity?
> Thank you.
> Noam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250521/cbfe2049/attachment.html>
