[petsc-users] Error in configuring HDF5 with Cygwin on Windows by using Intel MPI
    Matthew Knepley
    knepley at gmail.com
    Thu May 15 08:35:04 CDT 2025
On Thu, May 15, 2025 at 9:16 AM 程奔 <ctchengben at mail.scut.edu.cn> wrote:
> Hello,
> Recently I try successfully to install PETSc with Cygwin and Visual Studio
> on Windows10 plateform(with external packages metis and parmetis).
> Now I want to use hdf5, so I re-configure the PETSc on the cygwin with Native
> Microsoft/Intel Windows Compilers.
> The softwares/packages used below:
> 1. PETSc: version 3.23.2
> 2. VS: version 2022
> 3. Intel MPI: download Intel oneAPI Base Toolkit and HPC Toolkit
> 4. Cygwin
> And the compiler option in configuration is:
> ./configure  --with-debugging=0  --with-cc=cl --with-fc=ifort
> --with-cxx=cl
> --with-blaslapack-lib=-L/cygdrive/g/Intel/oneAPI/mkl/2023.2.0/lib/intel64
> mkl-intel-lp64-dll.lib mkl-sequential-dll.lib mkl-core-dll.lib
>  --download-fblaslapack=/cygdrive/g/mypetsc/petsc-pkg-fblaslapack-e8a03f57d64c.tar.gz
> --with-mpi-include=/cygdrive/g/Intel/oneAPI/mpi/2021.10.0/include
> --with-mpi-lib=/cygdrive/g/Intel/oneAPI/mpi/2021.10.0/lib/release/impi.lib
> --with-mpiexec=/cygdrive/g/Intel/oneAPI/mpi/2021.10.0/bin/mpiexec
> -localonly
> --download-metis=/cygdrive/g/mypetsc/petsc-pkg-metis-8b194fdf0966.tar.gz
> --download-parmetis=/cygdrive/g/mypetsc/petsc-pkg-parmetis-f5e3aab04fd5.tar.gz
> --with-strict-petscerrorcode=0 --with-64-bit-indices
> --download-hdf5=/cygdrive/g/mypetsc/hdf5-1.14.3-p1.tar.bz2
> --download-zlib=/cygdrive/g/mypetsc/zlib-1.3.1.tar.gz
> However it return an error:
>            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
>        External package zlib does not support --download-zlib with
> Microsoft compilers
>        External package hdf5 does not support --download-hdf5 with
> Microsoft compilers
> The configure.log is attached.
> It seem that I can't use Microsoft/Intel Windows Compilers to install
> hdf5, and
>    Libraries built with Cygwin/GNU compilers are not compatible and
>    cannot be linked with Microsoft or Intel compilers.  But I do use
>    Intel compiler on the Visual studio.
> So I wrrit this email to report my problem and ask for your help that how
> can I use PETSc with hdf5 on the Windows.
1. You can build under WSL2, which is what I would recommend.
2. If you really want to use Windows compilers, you will have to build HDF5
yourself.
     Matt
> Looking forward your reply!
> sinserely,
> Cheng.
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YEvzHiQxBu4jH7P_5mh66tM7zYwZp9qXzbyMwybgRUfsrNT9wBHxgW8-2A69zpap_nYgRiP51tb3JrWE7kke$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YEvzHiQxBu4jH7P_5mh66tM7zYwZp9qXzbyMwybgRUfsrNT9wBHxgW8-2A69zpap_nYgRiP51tb3JhXaZZIN$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250515/b0959e1d/attachment.html>
