[petsc-users] PETSc using problem
hj2000 at mail.ustc.edu.cn hj2000 at mail.ustc.edu.cn
Sun May 11 10:38:47 CDT 2025
Dear Developer:
   I am a user of PETSc, and I am using SNESLineSearchSetPostCheck to perform some actions when the line search fails.
However, it seems that this function is only called when the line search is successful. Why is that? Do I need to do something else?
My PETSc version is 3.18.6. Below is my code.
        auto LineSearchPostCheck = []( SNESLineSearch ls, Vec x, Vec y, Vec w, PetscBool* changed_Y,
                                       PetscBool* changed_W, void* ) {
            SNESLineSearchReason lscnv;
            SNESLineSearchGetReason( ls, &lscnv );
            SNES snes = nullptr;
            SNESLineSearchGetSNES( ls, &snes );
            SNESConvergedReason cnv;
            SNESGetConvergedReason( snes, &cnv );
            double lambda = 0.0;
            SNESLineSearchGetLambda( ls, &lambda );
            PetscPrintf( MPI_COMM_WORLD, "lambda=%lf\n", lambda );
            if ( lscnv != SNES_LINESEARCH_SUCCEEDED || lambda < 1e-4 )
                VecWAXPY( w, -0.1, y, x );
                SNESLineSearchSetReason( ls, SNES_LINESEARCH_SUCCEEDED );
                *changed_W = PETSC_TRUE;
            return 0;
        SNESLineSearchSetPostCheck( ls, LineSearchPostCheck, nullptr);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250511/185321f3/attachment.html>
