[petsc-users] Problems with the null-space removal
    MIGUEL MOLINOS PEREZ
    mmolinos at us.es
    Thu May  8 13:13:20 CDT 2025
Hi Joe
I don’t think this function will work for me since it extract particles cell-wise. However, I think I can use this function as basis to build what I have in mind…
Miguel
On May 8, 2025, at 6:43 PM, Joseph Pusztay <josephpu at buffalo.edu> wrote:
Hi Miguel,
I believe what you may be looking for is DMSwarmGetCellSwarm which extracts the fields from the swarm for a specified cell
 https://urldefense.us/v3/__https://petsc.org/release/manualpages/DMSwarm/DMSwarmGetCellSwarm/__;!!G_uCfscf7eWS!cwnn3sRq7di9mEjZz_VPpuzbpto02sSR7pko8ndG7obAmHU1vHXnI8cShm67H2Js9wkWYo1ieIXb4e6qjjIOng$
Best,
Joe
From: MIGUEL MOLINOS PEREZ <mmolinos at us.es<mailto:mmolinos at us.es>>
Sent: Thursday, May 8, 2025 10:22 AM
To: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Joseph Pusztay <josephpu at buffalo.edu<mailto:josephpu at buffalo.edu>>
Subject: Re: [petsc-users] Problems with the null-space removal
You don't often get email from mmolinos at us.es<mailto:mmolinos at us.es>. Learn why this is important<https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!cwnn3sRq7di9mEjZz_VPpuzbpto02sSR7pko8ndG7obAmHU1vHXnI8cShm67H2Js9wkWYo1ieIXb4e7o0gso8g$ >
This function “ DMSwarmCreatreSubswarm” is published somewhere? I can’t find it in the main branch of PETSc.
Miguel
On May 6, 2025, at 9:03 AM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
Oh, so you want to turn off some Swarm nodes? Joe has a DMSwarmCreatreSubswarm() function somewhere. This might work.
This would be awesome!
Miguel
On 5 May 2025, at 21:43, Matthew Knepley <knepley at gmail.com> wrote:
On Mon, May 5, 2025 at 2:08 PM MIGUEL MOLINOS PEREZ <mmolinos at us.es<mailto:mmolinos at us.es>> wrote:
Hi Matt, thank you for your response!
The most likely thing is that the nullspace is slightly wrong, or the convergence test is not accounting for the nullspace somehow.
However, since so many equations are inactive, I would consider projecting the problem. I might either
1) Select a subset of the mesh to phrase the problem on. In you use DMPlex, you could use DMPlexFilter().
I’am using a DMSwarm mesh so I can’t use this function.
2) Use a constraint to get a subsystem for Newton using SNESVI. The SNESVIRS will project the linear system onto a subspace without the constraints.
I assume you meant SNESVINEWTONRSLS (former SNESVI).
This is a subtype of SNESVI as it is a particular implementation.
I’ve been digging on this approach. However,I don’t think this fits my problem since I can not define the list of active nodes using upper and lower limits like in:
The way I am thinking, you must have some test to determine what nodes are active. I was supposing that test depending on the solution at those nodes. If that is true, you can use that test as the constraint.
     Matt
<https://urldefense.us/v3/__https://petsc.org/release/src/snes/tutorials/ex9.c.html__;!!G_uCfscf7eWS!cwnn3sRq7di9mEjZz_VPpuzbpto02sSR7pko8ndG7obAmHU1vHXnI8cShm67H2Js9wkWYo1ieIXb4e4lWpaVMQ$ >
petsc.org<https://urldefense.us/v3/__https://petsc.org/release/src/snes/tutorials/ex9.c.html__;!!G_uCfscf7eWS!cwnn3sRq7di9mEjZz_VPpuzbpto02sSR7pko8ndG7obAmHU1vHXnI8cShm67H2Js9wkWYo1ieIXb4e4lWpaVMQ$ >
[X]<https://urldefense.us/v3/__https://petsc.org/release/src/snes/tutorials/ex9.c.html__;!!G_uCfscf7eWS!cwnn3sRq7di9mEjZz_VPpuzbpto02sSR7pko8ndG7obAmHU1vHXnI8cShm67H2Js9wkWYo1ieIXb4e4lWpaVMQ$ >
Miguel
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cwnn3sRq7di9mEjZz_VPpuzbpto02sSR7pko8ndG7obAmHU1vHXnI8cShm67H2Js9wkWYo1ieIXb4e5B3deHRA$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cwnn3sRq7di9mEjZz_VPpuzbpto02sSR7pko8ndG7obAmHU1vHXnI8cShm67H2Js9wkWYo1ieIXb4e4V5fp3Rw$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250508/7f5b5804/attachment-0001.html>
