[petsc-users] dyld[19098]: Library not loaded: @rpath/libHYPRE-2.32.0.dylib
    David Andrs
    andrsd at gmail.com
    Thu May  8 07:38:15 CDT 2025
Hi Juan,
I recently bumped into a similar issue (not with PETSc). It is a general
issue with the newest macOS where a duplicate rpath prevents you from
running the binary. The info is buried in the error message when you run
the binary. I saw people "fixing" the issue by downgrading Xcode to 16.2 -
if my memory serves well. Also you can inspect your binary via `otool -l`
to check for the duplicate entries and remove them via install_name_tool
(not a solution, but a diagnosing step). So, maybe check if this is the
problem you are running into.
Side note: conda environment has the same problem and users are advised to
update to the latest ld64 (from conda-forge).
With regards,
David
On Wed, May 7, 2025 at 10:27 PM Juan Salazar via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear PETSc users,
> I am probably doing something dumb, but since I recently updated macOS, I
> am getting the following errors when running `make check`: dyld[19098]:
> Library not loaded: @rpath/libHYPRE-2.32.0.dylib . I am also not able to
> compile codes that previously worked with petsc because of the same issues.
> The dylib is not linked, even tough it is in the path that apparently is
> searched.
> Below is my configure command
> ./configure --with-debugging=0 --download-cmake --download-hypre
> --download-parmetis --download-metis --download-ptscotch --download-mumps
> --download-scalapack --with-precision=double --with-shared-libraries=1
> --with-scalar-type=real --with-fc=mpifort --with-cc=mpicc --with-cxx=mpicxx
> CXX_LINKER_FLAGS=-Wl,-rpath,/opt/homebrew/lib CFLAGS="-g -O2 -fPIC"
> CXXFLAGS="-g -O2 -fPIC" FCFLAGS="-g -O2" FFLAGS="-g -O2"
> LDFLAGS="-Wl,-ld_classic -Wl,-commons,use_dylibs" MAKEFLAGS=w
> --download-bison
> Attached are the configure.log and make.log and check.log files.
> √ petsc-3.23.1 % mpifort --version
> GNU Fortran (Homebrew GCC 14.2.0_1) 14.2.0
> Copyright (C) 2024 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.  There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> √ petsc-3.23.1 % mpicc --version
> Apple clang version 17.0.0 (clang-1700.0.13.3)
> Target: arm64-apple-darwin24.4.0
> Thread model: posix
> InstalledDir:
> /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin
> √ petsc-3.23.1 % mpicxx --version
> Thread model: posix
> InstalledDir:
> macOS Sequoia 15.4.1 (24E263)
> Any help is much appreciated,
> Juan S.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250508/38123fd8/attachment.html>
