[petsc-users] FAQ about fast interconnect
Jose E. Roman
jroman at dsic.upv.es
Mon Mar 31 04:04:20 CDT 2025
If you look at the top500 list, 50% of the machines have Infiniband and 37% Gigabit Ethernet. InfiniBand has a low latency of 3–5 microseconds, which is much lower than Ethernet's 20–80 microseconds. But Ethernet can be a cost-effective solution with reasonably good performance, provided that you configure the machine appropriately to minimize the software latency - by using a RoCE driver.
Jose
> El 31 mar 2025, a las 10:40, Klaij, Christiaan via petsc-users <petsc-users at mcs.anl.gov> escribió:
> The FAQ about the kind of parallel computers or clusters needed
> to use PETSc states:
> "any ethernet (even 10 GigE) simply cannot provide the needed performance."
> Does this statement still hold now that 100 GigE is common?
> The broader question is that we are buying a new cluster to run
> our in-house CFD solver ReFRESCO. Typical production runs involve
> meshes up-to a few hundred million cells with half a dozen to a
> dozen equations. Most of the time is spend in KSPSolve. What kind
> of interconnect should we consider?
> Chris <image916957.png>
> dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
> T +31 317 49 33 44 | C.Klaij at marin.nl | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!aONPw6PPgHjgXIh5u-tf1Buvha38iSHeSim-KXX_1xXxgi0QiRpkdyrmx7jTObbjT2wgz4dkcLzVv2W9IOitYnmE$ <image775640.png><image297572.png><image268268.png>
