[petsc-users] Fortran stubs 3.22.4
Wed Mar 26 13:29:04 CDT 2025
On Wed, Mar 26, 2025 at 1:51 PM Frank Bramkamp <bramkamp at nsc.liu.se> wrote:
> Dear PETSc Team,
> a user of our computer center reported a PETSC issue.
> He uses petsc version 3.22.4 with gcc compiler
> The problem arises with MatGetRow and MatRestoreRow.
> PETSC compiled properly but his Fortran application then cannot find those
> routines. It seems to work in version 3.22.2.  For me it also worked in
> 3.21.1
> calling those routines from fortran.
> It looks that the fortran stubs might have been broken for those two
> routines in version 3.22.4
> I will also test 3.22.4 now myself to confirm it or I can probably test a
> fixed version as well.
Hi Frank,
Yes, we have had that report. Barry has now completely rewritten the
Fortran bindings, replacing our old
binding generator, so that every exposed function should now have a
binding. This is a large change, but
should make everything much more maintainable. We plan to release 3.23 in a
week or two, and would advise
every Fortran user to upgrade, since this will be the standard going
forward. Does that timeline work for you?
     Matt
> Greetings, Frank Bramkamp
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YWfr-xc2NrmK8QCbpIUPpfzLuBVFIjQ6FDjpm9Iqv6mev-Y8WYiVtcGcK87_yJyOo3UR-RCvj05E0oOUsNmx$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YWfr-xc2NrmK8QCbpIUPpfzLuBVFIjQ6FDjpm9Iqv6mev-Y8WYiVtcGcK87_yJyOo3UR-RCvj05E0qLIO9cy$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250326/c0af2fbe/attachment.html>
