[petsc-users] VecSetValue
Sanjay Govindjee
s_g at berkeley.edu
Mon Mar 24 17:26:41 CDT 2025
My odessy to update my code to the main branch continues...I am now
encountering an error with VecSetValue:
[0]PETSC ERROR: VecSetValues() at
/Users/sg/petsc-3.22.4main/src/vec/vec/interface/rvector.c:926 Null
Pointer: Parameter # 4
This is on a single processor run -- I got tired of closing all those
debug windows. My call looks like
call VecSetValue(rhs, k-1, b(j), ADD_VALUES, ierr)
and the first two data types are Vec and integer, and for the third
real (kind=8) :: b(:) ! comes through the argument list for the
subroutine
vecsetvalue_ however seems to be receiving va=0x0000000000000000. I see
that formally the value is supposed to be PetscScalar; is that the
issue? The thread backtrace is below.
(lldb) process attach --pid 51640
Process 51640 stopped
* thread #1, queue = 'com.apple.main-thread', stop reason = signal
SIGSTOP
frame #0: 0x00007fff69d92746
libsystem_kernel.dylib`__semwait_signal + 10
libsystem_kernel.dylib`__semwait_signal:
-> 0x7fff69d92746 <+10>: jae 0x7fff69d92750 ; <+20>
0x7fff69d92748 <+12>: movq %rax, %rdi
0x7fff69d9274b <+15>: jmp 0x7fff69d9121d ; cerror
0x7fff69d92750 <+20>: retq
Target 0: (feap) stopped.
Executable module set to "/Users/sg/Feap/ver87/parfeap/feap".
Architecture set to: x86_64h-apple-macosx-.
(lldb) thread backtrace
SIGSTOP
* frame #0: 0x00007fff69d92746
frame #1: 0x00007fff69d15eea libsystem_c.dylib`nanosleep + 196
frame #2: 0x00007fff69d15d52 libsystem_c.dylib`sleep + 41
frame #3: 0x000000010a1fb04c
libpetsc.3.022.dylib`PetscSleep(s=10) at psleep.c:48:5
frame #4: 0x0000000109e52961
libpetsc.3.022.dylib`PetscAttachDebugger at adebug.c:458:5
frame #5: 0x000000010ea1c7c8
libpetsc.3.022.dylib`PetscAttachDebuggerErrorHandler(comm=0x0000000110e78de8,
line=926, fun="VecSetValues",
file="/Users/sg/petsc-3.22.4main/src/vec/vec/interface/rvector.c",
num=85, p=PETSC_ERROR_INITIAL, mess="Null Pointer: Parameter # 4",
ctx=0x0000000000000000) at adebug.c:522:9
frame #6: 0x000000010ea1cdb0
libpetsc.3.022.dylib`PetscError(comm=0x0000000110e78de8, line=926,
func="VecSetValues",
n=85, p=PETSC_ERROR_INITIAL, mess="Null Pointer: Parameter # %d") at
err.c:409:15
frame #7: 0x000000010a866bf2
libpetsc.3.022.dylib`VecSetValues(x=0x00007fdb53068450, ni=1,
ix=0x00007ffee6d74098, y=0x0000000000000000, iora=ADD_VALUES) at
rvector.c:926:3
frame #8: 0x000000010a82c1dc
libpetsc.3.022.dylib`vecsetvalue_(v=0x00000001093ca8f8,
i=0x00007ffee6d74098, va=0x0000000000000000,
mode=0x00007ffee6d74094, ierr=0x00007ffee6d74238) at zvectorf.c:20:11
frame #9: 0x0000000108ebbb48 feap`usolve_ at usolve.F:256:72
frame #10: 0x000000010904cd9c feap`psolve_ at psolve.f:232:72
frame #11: 0x0000000108fb7edc feap`pmacr1_ at pmacr1.f:667:72
frame #12: 0x0000000108fb20dd feap`pmacr_ at pmacr.f:614:72
frame #13: 0x0000000108f56e7f feap`pcontr_ at pcontr.f:1375:72
frame #14: 0x00000001092fe18e feap`main at feap87.f:173:72
frame #15: 0x00007fff69c4ecc9 libdyld.dylib`start + 1
(lldb) up
libsystem_c.dylib`nanosleep:
-> 0x7fff69d15eea <+196>: testl %eax, %eax
0x7fff69d15eec <+198>: jns 0x7fff69d15eb5 ; <+143>
0x7fff69d15eee <+200>: callq 0x7fff69d1e008 ; symbol stub for:
__error
0x7fff69d15ef3 <+205>: cmpl $0x3c, (%rax)
(lldb) up
libsystem_c.dylib`sleep:
-> 0x7fff69d15d52 <+41>: movl %eax, %ecx
0x7fff69d15d54 <+43>: xorl %eax, %eax
0x7fff69d15d56 <+45>: cmpl $-0x1, %ecx
0x7fff69d15d59 <+48>: jne 0x7fff69d15d85 ; <+92>
(lldb) up
frame #3: 0x000000010a1fb04c libpetsc.3.022.dylib`PetscSleep(s=10)
at psleep.c:48:5
45
46 #if defined(PETSC_HAVE_SLEEP)
47 else
-> 48 sleep((int)s);
49 #elif defined(PETSC_HAVE__SLEEP) &&
defined(PETSC_HAVE__SLEEP_MILISEC)
50 else _sleep((int)(s * 1000));
51 #elif defined(PETSC_HAVE__SLEEP)
(lldb) up
455 while (left > 0) left = PetscSleep(left) - 1;
456 }
457 #else
-> 458 PetscCall(PetscSleep(sleeptime));
459 #endif
460 }
461 #endif
(lldb) up
519 if (fun) (void)(*PetscErrorPrintf)("%s() at %s:%d
%s\n", fun, file, line, mess);
520 else (void)(*PetscErrorPrintf)("%s:%d %s\n", file,
line, mess);
521
-> 522 (void)PetscAttachDebugger();
523 abort(); /* call abort because don't want to kill
other MPI ranks that may successfully attach to debugger */
524 PetscFunctionReturn(PETSC_SUCCESS);
525 }
(lldb) up
err.c:409:15
406 if (p == PETSC_ERROR_INITIAL && n != PETSC_ERR_MEMC)
(void)PetscMallocValidate(__LINE__, PETSC_FUNCTION_NAME, __FILE__);
407
408 if (!eh) ierr = PetscTraceBackErrorHandler(comm, line,
func, file, n, p, lbuf, NULL);
-> 409 else ierr = (*eh->handler)(comm, line, func, file, n,
p, lbuf, eh->ctx);
410 PetscStackClearTop;
411
412 /*
(lldb) up
rvector.c:926:3
923 PetscValidHeaderSpecific(x, VEC_CLASSID, 1);
924 if (!ni) PetscFunctionReturn(PETSC_SUCCESS);
925 PetscAssertPointer(ix, 3);
-> 926 PetscAssertPointer(y, 4);
927 PetscValidType(x, 1);
928
929 PetscCall(PetscLogEventBegin(VEC_SetValues, x, 0, 0, 0));
(lldb) up
17 PETSC_EXTERN void vecsetvalue_(Vec *v, PetscInt *i,
PetscScalar *va, InsertMode *mode, PetscErrorCode *ierr)
18 {
19 /* cannot use VecSetValue() here since that uses
PetscCall() which has a return in it */
-> 20 *ierr = VecSetValues(*v, 1, i, va, *mode);
21 }
22
23 PETSC_EXTERN void vecsetvaluelocal_(Vec *v, PetscInt *i,
(lldb) up
253 if( k .gt. 0 ) then
254 j = j + 1
255 ! write(*,*) 'rank: ',rank,' k,j,b(j)
',k,j,b(j)
-> 256 call VecSetValue(rhs, k-1, b(j),
ADD_VALUES, ierr)
257 endif
258 end do
Sanjay Govindjee, PhD, PE
Horace, Dorothy, and Katherine Johnson Professor in Engineering
Distinguished Professor of Civil and Environmental Engineering
779 Davis Hall
University of California
Berkeley, CA 94720-1710
Voice: +1 510 642 6060
FAX: +1 510 643 5264
s_g at berkeley.edu
https://urldefense.us/v3/__http://faculty.ce.berkeley.edu/sanjay__;!!G_uCfscf7eWS!eYHZJmdbbAvMW_dwF5Gl5kuFLWS9Tllmp4OCyVBwo0hVI25qi3ZiV-maVgXQ7wmZ8dKjEGu1hb5u7w9azVgSHQ$
Books:
Introduction to Mechanics of Solid Materials
https://urldefense.us/v3/__https://global.oup.com/academic/product/introduction-to-mechanics-of-solid-materials-9780192866080__;!!G_uCfscf7eWS!eYHZJmdbbAvMW_dwF5Gl5kuFLWS9Tllmp4OCyVBwo0hVI25qi3ZiV-maVgXQ7wmZ8dKjEGu1hb5u7w_VG5HHMA$
Continuum Mechanics of Solids
https://urldefense.us/v3/__https://global.oup.com/academic/product/continuum-mechanics-of-solids-9780198864721__;!!G_uCfscf7eWS!eYHZJmdbbAvMW_dwF5Gl5kuFLWS9Tllmp4OCyVBwo0hVI25qi3ZiV-maVgXQ7wmZ8dKjEGu1hb5u7w9T8MhzbQ$
Example Problems for Continuum Mechanics of Solids
https://urldefense.us/v3/__https://www.amazon.com/dp/1083047361/__;!!G_uCfscf7eWS!eYHZJmdbbAvMW_dwF5Gl5kuFLWS9Tllmp4OCyVBwo0hVI25qi3ZiV-maVgXQ7wmZ8dKjEGu1hb5u7w_GqMlonw$
Engineering Mechanics of Deformable Solids
https://urldefense.us/v3/__https://www.amazon.com/dp/0199651647__;!!G_uCfscf7eWS!eYHZJmdbbAvMW_dwF5Gl5kuFLWS9Tllmp4OCyVBwo0hVI25qi3ZiV-maVgXQ7wmZ8dKjEGu1hb5u7w9troczOg$
Engineering Mechanics 3 (Dynamics) 2nd Edition
https://urldefense.us/v3/__http://www.amazon.com/dp/3642537111__;!!G_uCfscf7eWS!eYHZJmdbbAvMW_dwF5Gl5kuFLWS9Tllmp4OCyVBwo0hVI25qi3ZiV-maVgXQ7wmZ8dKjEGu1hb5u7w_g7GDa1w$
Engineering Mechanics 3, Supplementary Problems: Dynamics
https://urldefense.us/v3/__http://www.amzn.com/B00SOXN8JU__;!!G_uCfscf7eWS!eYHZJmdbbAvMW_dwF5Gl5kuFLWS9Tllmp4OCyVBwo0hVI25qi3ZiV-maVgXQ7wmZ8dKjEGu1hb5u7w97Vbz6Dw$
NSF NHERI SimCenter
https://urldefense.us/v3/__https://simcenter.designsafe-ci.org/__;!!G_uCfscf7eWS!eYHZJmdbbAvMW_dwF5Gl5kuFLWS9Tllmp4OCyVBwo0hVI25qi3ZiV-maVgXQ7wmZ8dKjEGu1hb5u7w_SCyLZOg$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250324/ba12d97f/attachment-0001.html>
