[petsc-users] GCREATEF.C error
Sanjay Govindjee
s_g at berkeley.edu
Mon Mar 24 13:26:36 CDT 2025
I checked also that this is the first time that this part of the code is
entered. Before the call to MatCreate, all processes
are reporting Kmat is 0 (as is PETSC_NULL_MAT). All have the same
PETSC_COMM_WORLD of 0.
On 3/24/25 8:14 AM, Sanjay Govindjee wrote:
> Hi Barry,
> The call sequence happens across several routines. I believe it is as
> follows:
> call PetscInitialize(PETSC_NULL_CHARACTER, ierr)
> call MPI_Comm_rank(PETSC_COMM_WORLD, rank, ierr)
> call MPI_Comm_size(PETSC_COMM_WORLD, ntasks, ierr)
> Kmat = PETSC_NULL_MAT
> if(Kmat.eq.PETSC_NULL_MAT) then
> call MatCreate(PETSC_COMM_WORLD,Kmat,ierr)
> etc...
> Kmat itself is declared in a module
> module pfeapc
> # include <petsc/finclude/petscksp.h>
> use petscksp
> implicit none
> Vec :: rhs, sol, xvec
> Vec :: yvec, zvec
> Vec :: Mdiag, Msqrt
> Mat :: Kmat, Mmat, Pmat
> KSP :: kspsol
> end module pfeapc
> On Mon, Mar 24, 2025 at 7:15 AM Barry Smith <bsmith at petsc.dev> wrote:
> How do you declare and initialize the matrix in usolve.F
> before calling MatCreate()? You should not initialize it with any
> value before the call.
> Barry
>> On Mar 23, 2025, at 11:10 PM, Sanjay Govindjee via petsc-users
>> <petsc-users at mcs.anl.gov> wrote:
>> Barry,
>> I now have a compiled version of my code using the main
>> branch. When I run however I am getting an error in matcreate_(
>> ) when I try to solve (actually just set up the matrix). The
>> console window reports
>> [0]PETSC ERROR: matcreate_() at
>> /Users/sg/petsc-3.22.4main/gnu/ftn/mat/utils/gcreatef.c:14
>> Cannot create PETSC_NULL_XXX object
>> [3]PETSC ERROR: matcreate_() at
>> [2]PETSC ERROR: matcreate_() at
>> [1]PETSC ERROR: matcreate_() at
>> The debugger windows all report (modulo the pid):
>> (lldb) process attach --pid 90952
>> Process 90952 stopped
>> * thread #1, queue = 'com.apple.main-thread', stop reason =
>> signal SIGSTOP
>> frame #0: 0x00007fff69d92746
>> libsystem_kernel.dylib`__semwait_signal + 10
>> libsystem_kernel.dylib`__semwait_signal:
>> -> 0x7fff69d92746 <+10>: jae 0x7fff69d92750 ; <+20>
>> 0x7fff69d92748 <+12>: movq %rax, %rdi
>> 0x7fff69d9274b <+15>: jmp 0x7fff69d9121d ; cerror
>> 0x7fff69d92750 <+20>: retq
>> Target 0: (feap) stopped.
>> frame
>> The debugger reports for the stack:
>> (lldb) thread backtrace
>> signal SIGSTOP
>> * frame #0: 0x00007fff69d92746
>> frame #1: 0x00007fff69d15eea libsystem_c.dylib`nanosleep
>> + 196
>> frame #2: 0x00007fff69d15d52 libsystem_c.dylib`sleep + 41
>> frame #3: 0x0000000111acb04c
>> libpetsc.3.022.dylib`PetscSleep(s=10) at psleep.c:48:5
>> frame #4: 0x0000000111722961
>> libpetsc.3.022.dylib`PetscAttachDebugger at adebug.c:458:5
>> frame #5: 0x00000001162ec7c8
>> libpetsc.3.022.dylib`PetscAttachDebuggerErrorHandler(comm=0x000000011788fde8,
>> line=14, fun="matcreate_",
>> file="/Users/sg/petsc-3.22.4main/gnu/ftn/mat/utils/gcreatef.c",
>> num=62, p=PETSC_ERROR_INITIAL, mess="Cannot create
>> PETSC_NULL_XXX object", ctx=0x0000000000000000) at adebug.c:522:9
>> frame #6: 0x00000001162ecdb0
>> libpetsc.3.022.dylib`PetscError(comm=0x000000011788fde8,
>> line=14, func="matcreate_",
>> n=62, p=PETSC_ERROR_INITIAL, mess="Cannot create
>> PETSC_NULL_XXX object") at err.c:409:15
>> frame #7: 0x000000011233ecad
>> libpetsc.3.022.dylib`matcreate_(a=0x00000001165fdc74,
>> b=0x000000010fcde8c8, ierr=0x00007ffee0460308) at gcreatef.c:14:3
>> frame #8: 0x000000010f7cf072 feap`usolve_ at usolve.F:138:72
>> frame #9: 0x000000010f942de2 feap`presol_ at presol.f:181:72
>> frame #10: 0x000000010f8cb8d8 feap`pmacr1_ at pmacr1.f:555:72
>> frame #11: 0x000000010f8c60ad feap`pmacr_ at pmacr.f:614:72
>> frame #12: 0x000000010f86ae4f feap`pcontr_ at
>> pcontr.f:1375:72
>> frame #13: 0x000000010fc1215e feap`main at feap87.f:173:72
>> frame #14: 0x00007fff69c4ecc9 libdyld.dylib`start + 1
>> frame #15: 0x00007fff69c4ecc9 libdyld.dylib`start + 1
>> Here is a peek at the frame stack:
>> frame #3: 0x0000000105c7104c
>> 45
>> 46 #if defined(PETSC_HAVE_SLEEP)
>> 47 else
>> -> 48 sleep((int)s);
>> 49 #elif defined(PETSC_HAVE__SLEEP) &&
>> defined(PETSC_HAVE__SLEEP_MILISEC)
>> 50 else _sleep((int)(s * 1000));
>> 51 #elif defined(PETSC_HAVE__SLEEP)
>> (lldb) up
>> frame #4: 0x00000001058c8961
>> 455 while (left > 0) left = PetscSleep(left) - 1;
>> 456 }
>> 457 #else
>> -> 458 PetscCall(PetscSleep(sleeptime));
>> 459 #endif
>> 460 }
>> 461 #endif
>> (lldb) up
>> frame #5: 0x000000010a4927c8
>> libpetsc.3.022.dylib`PetscAttachDebuggerErrorHandler(comm=0x000000010c7f1de8,
>> 519 if (fun) (void)(*PetscErrorPrintf)("%s() at
>> %s:%d %s\n", fun, file, line, mess);
>> 520 else (void)(*PetscErrorPrintf)("%s:%d %s\n",
>> file, line, mess);
>> 521
>> -> 522 (void)PetscAttachDebugger();
>> 523 abort(); /* call abort because don't want to
>> kill other MPI ranks that may successfully attach to debugger */
>> 524 PetscFunctionReturn(PETSC_SUCCESS);
>> 525 }
>> (lldb) up
>> frame #6: 0x000000010a492db0
>> libpetsc.3.022.dylib`PetscError(comm=0x000000010c7f1de8,
>> 406 if (p == PETSC_ERROR_INITIAL && n !=
>> PETSC_ERR_MEMC) (void)PetscMallocValidate(__LINE__,
>> PETSC_FUNCTION_NAME, __FILE__);
>> 407
>> 408 if (!eh) ierr = PetscTraceBackErrorHandler(comm,
>> line, func, file, n, p, lbuf, NULL);
>> -> 409 else ierr = (*eh->handler)(comm, line, func,
>> file, n, p, lbuf, eh->ctx);
>> 410 PetscStackClearTop;
>> 411
>> 412 /*
>> (lldb) up
>> frame #7: 0x00000001064e4cad
>> libpetsc.3.022.dylib`matcreate_(a=0x000000010a7a3c74,
>> b=0x0000000104e3e8c8, ierr=0x00007ffeeb300308) at gcreatef.c:14:3
>> 11 PETSC_EXTERN void matcreate_(MPI_Fint *a, Mat *b,
>> PetscErrorCode *ierr)
>> 12 {
>> 13 PetscBool null_b = !*(void**) b ? PETSC_TRUE :
>> PETSC_FALSE;
>> -> 14 PETSC_FORTRAN_OBJECT_CREATE(b);
>> 15 CHKFORTRANNULLOBJECT(b);
>> 16 *ierr = MatCreate(MPI_Comm_f2c(*(a)), b);
>> 17 if (*ierr) return;
>> (lldb) up
>> frame #8: 0x000000010492f072 feap`usolve_ at usolve.F:138:72
>> 135 onnz => mr(np(246):np(246)+ilist(2,246)-1)
>> 136 dnnz => mr(np(247):np(247)+ilist(2,247)-1)
>> 137
>> -> 138 call MatCreate(PETSC_COMM_WORLD,Kmat,ierr)
>> 139 call
>> MatSetSizes(Kmat,numpeq,numpeq,PETSC_DETERMINE,
>> 140 & PETSC_DETERMINE,ierr)
>> 141 if(pfeap_bcin) call
>> MatSetBlockSize(Kmat,nsbk,ierr)
>> Sanjay Govindjee, PhD, PE
>> Horace, Dorothy, and Katherine Johnson Professor in Engineering
>> Distinguished Professor of Civil and Environmental Engineering
>> 779 Davis Hall
>> University of California
>> Berkeley, CA 94720-1710
>> Voice: +1 510 642 6060
>> FAX: +1 510 643 5264
>> s_g at berkeley.edu
>> https://urldefense.us/v3/__http://faculty.ce.berkeley.edu/sanjay__;!!G_uCfscf7eWS!csm5TpwF50O4A3Fzpkjw2ykrUWpvpkp4Y9-ejUpCagaALLqiRXdNvemoAnv93KNM1WTv5sdI-36GWoIL-MAyXg$ <https://urldefense.us/v3/__http://faculty.ce.berkeley.edu/sanjay__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLJDGn-rKw$>
>> Books:
>> Introduction to Mechanics of Solid Materials
>> https://urldefense.us/v3/__https://global.oup.com/academic/product/introduction-to-mechanics-of-solid-materials-9780192866080__;!!G_uCfscf7eWS!csm5TpwF50O4A3Fzpkjw2ykrUWpvpkp4Y9-ejUpCagaALLqiRXdNvemoAnv93KNM1WTv5sdI-36GWoLbtM0llA$ <https://urldefense.us/v3/__https://global.oup.com/academic/product/introduction-to-mechanics-of-solid-materials-9780192866080__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLK6eJ2xMA$>
>> Continuum Mechanics of Solids
>> https://urldefense.us/v3/__https://global.oup.com/academic/product/continuum-mechanics-of-solids-9780198864721__;!!G_uCfscf7eWS!csm5TpwF50O4A3Fzpkjw2ykrUWpvpkp4Y9-ejUpCagaALLqiRXdNvemoAnv93KNM1WTv5sdI-36GWoKFxHALpw$ <https://urldefense.us/v3/__https://global.oup.com/academic/product/continuum-mechanics-of-solids-9780198864721__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLL3Y4t2YA$>
>> Example Problems for Continuum Mechanics of Solids
>> https://urldefense.us/v3/__https://www.amazon.com/dp/1083047361/__;!!G_uCfscf7eWS!csm5TpwF50O4A3Fzpkjw2ykrUWpvpkp4Y9-ejUpCagaALLqiRXdNvemoAnv93KNM1WTv5sdI-36GWoI4JfkbnQ$ <https://urldefense.us/v3/__https://www.amazon.com/dp/1083047361/__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLIyAaK4Eg$>
>> Engineering Mechanics of Deformable Solids
>> https://urldefense.us/v3/__https://www.amazon.com/dp/0199651647__;!!G_uCfscf7eWS!csm5TpwF50O4A3Fzpkjw2ykrUWpvpkp4Y9-ejUpCagaALLqiRXdNvemoAnv93KNM1WTv5sdI-36GWoLTK5LzXQ$ <https://urldefense.us/v3/__https://www.amazon.com/dp/0199651647__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLLf5ewSKQ$>
>> Engineering Mechanics 3 (Dynamics) 2nd Edition
>> https://urldefense.us/v3/__http://www.amazon.com/dp/3642537111__;!!G_uCfscf7eWS!csm5TpwF50O4A3Fzpkjw2ykrUWpvpkp4Y9-ejUpCagaALLqiRXdNvemoAnv93KNM1WTv5sdI-36GWoLqPKwRcg$ <https://urldefense.us/v3/__http://www.amazon.com/dp/3642537111__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLIJH2xWfA$>
>> Engineering Mechanics 3, Supplementary Problems: Dynamics
>> https://urldefense.us/v3/__http://www.amzn.com/B00SOXN8JU__;!!G_uCfscf7eWS!csm5TpwF50O4A3Fzpkjw2ykrUWpvpkp4Y9-ejUpCagaALLqiRXdNvemoAnv93KNM1WTv5sdI-36GWoJ-NLmpBQ$ <https://urldefense.us/v3/__http://www.amzn.com/B00SOXN8JU__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLJV9YZdRA$>
>> NSF NHERI SimCenter
>> https://urldefense.us/v3/__https://simcenter.designsafe-ci.org/__;!!G_uCfscf7eWS!csm5TpwF50O4A3Fzpkjw2ykrUWpvpkp4Y9-ejUpCagaALLqiRXdNvemoAnv93KNM1WTv5sdI-36GWoJSbEtJGA$ <https://urldefense.us/v3/__https://simcenter.designsafe-ci.org/__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLJMVyG6GQ$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250324/5d50cbb1/attachment-0001.html>
