[petsc-users] 回复: 回复: Floating point exception when save complex vector into a hdf5 file
Ye Changqing Ye_Changqing at outlook.com
Mon Mar 24 06:57:41 CDT 2025
Dear Mark,
As suggested, I did a fresh configuration on PETSc. The problem is still there. The attachment is the configure.log for your reference.
Best,
Changqing
发件人: Mark Adams <mfadams at lbl.gov>
发送时间: 2025年3月24日 19:14
收件人: Ye Changqing
抄送: petsc-users at mcs.anl.gov
主题: Re: [petsc-users] 回复: Floating point exception when save complex vector into a hdf5 file
Just to check, you want to delete the linux-oneapi-complex-opt directory and do a fresh build when you get errors like this and you might send your configure log.
On Mon, Mar 24, 2025 at 5:22 AM Ye Changqing <Ye_Changqing at outlook.com<mailto:Ye_Changqing at outlook.com>> wrote:
Dear all,
I reconfigured petsc with "--with-debugging=1". It throws more messages which I attached below.
Best,
Changqing
发件人: Ye Changqing <Ye_Changqing at outlook.com<mailto:Ye_Changqing at outlook.com>>
发送时间: 2025年3月24日 16:33
收件人: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
主题: Floating point exception when save complex vector into a hdf5 file
Dear PETSc developers,
I encountered a strange problem when I tried to save a DMDA vector into an hdf5 file, a floating point error was thrown. I can repeat the problem on the cluster. However, the same codes run fine on my local computer.
Below the .cxx file is the minimal working example, the .txt is the runtime error obtained from SLURM, and the .py file should tell the configure options that I used to build the library.
Any suggestions?
Best,
Changqing
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250324/675d57d9/attachment-0001.obj>
