[petsc-users] GCREATEF.C error
Sanjay Govindjee
s_g at berkeley.edu
Sun Mar 23 22:10:08 CDT 2025
Barry,
I now have a compiled version of my code using the main branch. When
I run however I am getting an error in matcreate_( ) when I try to solve
(actually just set up the matrix). The console window reports
[0]PETSC ERROR: matcreate_() at
/Users/sg/petsc-3.22.4main/gnu/ftn/mat/utils/gcreatef.c:14 Cannot
create PETSC_NULL_XXX object
[3]PETSC ERROR: matcreate_() at
[2]PETSC ERROR: matcreate_() at
[1]PETSC ERROR: matcreate_() at
The debugger windows all report (modulo the pid):
(lldb) process attach --pid 90952
Process 90952 stopped
* thread #1, queue = 'com.apple.main-thread', stop reason = signal
SIGSTOP
frame #0: 0x00007fff69d92746
libsystem_kernel.dylib`__semwait_signal + 10
libsystem_kernel.dylib`__semwait_signal:
-> 0x7fff69d92746 <+10>: jae 0x7fff69d92750 ; <+20>
0x7fff69d92748 <+12>: movq %rax, %rdi
0x7fff69d9274b <+15>: jmp 0x7fff69d9121d ; cerror
0x7fff69d92750 <+20>: retq
Target 0: (feap) stopped.
frame
The debugger reports for the stack:
(lldb) thread backtrace
SIGSTOP
* frame #0: 0x00007fff69d92746
frame #1: 0x00007fff69d15eea libsystem_c.dylib`nanosleep + 196
frame #2: 0x00007fff69d15d52 libsystem_c.dylib`sleep + 41
frame #3: 0x0000000111acb04c
libpetsc.3.022.dylib`PetscSleep(s=10) at psleep.c:48:5
frame #4: 0x0000000111722961
libpetsc.3.022.dylib`PetscAttachDebugger at adebug.c:458:5
frame #5: 0x00000001162ec7c8
libpetsc.3.022.dylib`PetscAttachDebuggerErrorHandler(comm=0x000000011788fde8,
line=14, fun="matcreate_",
file="/Users/sg/petsc-3.22.4main/gnu/ftn/mat/utils/gcreatef.c",
num=62, p=PETSC_ERROR_INITIAL, mess="Cannot create PETSC_NULL_XXX
object", ctx=0x0000000000000000) at adebug.c:522:9
frame #6: 0x00000001162ecdb0
libpetsc.3.022.dylib`PetscError(comm=0x000000011788fde8, line=14,
func="matcreate_",
n=62, p=PETSC_ERROR_INITIAL, mess="Cannot create PETSC_NULL_XXX
object") at err.c:409:15
frame #7: 0x000000011233ecad
libpetsc.3.022.dylib`matcreate_(a=0x00000001165fdc74,
b=0x000000010fcde8c8, ierr=0x00007ffee0460308) at gcreatef.c:14:3
frame #8: 0x000000010f7cf072 feap`usolve_ at usolve.F:138:72
frame #9: 0x000000010f942de2 feap`presol_ at presol.f:181:72
frame #10: 0x000000010f8cb8d8 feap`pmacr1_ at pmacr1.f:555:72
frame #11: 0x000000010f8c60ad feap`pmacr_ at pmacr.f:614:72
frame #12: 0x000000010f86ae4f feap`pcontr_ at pcontr.f:1375:72
frame #13: 0x000000010fc1215e feap`main at feap87.f:173:72
frame #14: 0x00007fff69c4ecc9 libdyld.dylib`start + 1
frame #15: 0x00007fff69c4ecc9 libdyld.dylib`start + 1
Here is a peek at the frame stack:
frame #3: 0x0000000105c7104c libpetsc.3.022.dylib`PetscSleep(s=10)
at psleep.c:48:5
45
46 #if defined(PETSC_HAVE_SLEEP)
47 else
-> 48 sleep((int)s);
49 #elif defined(PETSC_HAVE__SLEEP) &&
defined(PETSC_HAVE__SLEEP_MILISEC)
50 else _sleep((int)(s * 1000));
51 #elif defined(PETSC_HAVE__SLEEP)
(lldb) up
frame #4: 0x00000001058c8961
455 while (left > 0) left = PetscSleep(left) - 1;
456 }
457 #else
-> 458 PetscCall(PetscSleep(sleeptime));
459 #endif
460 }
461 #endif
(lldb) up
frame #5: 0x000000010a4927c8
libpetsc.3.022.dylib`PetscAttachDebuggerErrorHandler(comm=0x000000010c7f1de8,
519 if (fun) (void)(*PetscErrorPrintf)("%s() at %s:%d
%s\n", fun, file, line, mess);
520 else (void)(*PetscErrorPrintf)("%s:%d %s\n", file,
line, mess);
521
-> 522 (void)PetscAttachDebugger();
523 abort(); /* call abort because don't want to kill
other MPI ranks that may successfully attach to debugger */
524 PetscFunctionReturn(PETSC_SUCCESS);
525 }
(lldb) up
frame #6: 0x000000010a492db0
libpetsc.3.022.dylib`PetscError(comm=0x000000010c7f1de8, line=14,
func="matcreate_",
406 if (p == PETSC_ERROR_INITIAL && n != PETSC_ERR_MEMC)
(void)PetscMallocValidate(__LINE__, PETSC_FUNCTION_NAME, __FILE__);
407
408 if (!eh) ierr = PetscTraceBackErrorHandler(comm, line,
func, file, n, p, lbuf, NULL);
-> 409 else ierr = (*eh->handler)(comm, line, func, file, n,
p, lbuf, eh->ctx);
410 PetscStackClearTop;
411
412 /*
(lldb) up
frame #7: 0x00000001064e4cad
libpetsc.3.022.dylib`matcreate_(a=0x000000010a7a3c74,
b=0x0000000104e3e8c8, ierr=0x00007ffeeb300308) at gcreatef.c:14:3
11 PETSC_EXTERN void matcreate_(MPI_Fint *a, Mat *b,
PetscErrorCode *ierr)
12 {
13 PetscBool null_b = !*(void**) b ? PETSC_TRUE :
PETSC_FALSE;
-> 14 PETSC_FORTRAN_OBJECT_CREATE(b);
15 CHKFORTRANNULLOBJECT(b);
16 *ierr = MatCreate(MPI_Comm_f2c(*(a)), b);
17 if (*ierr) return;
(lldb) up
frame #8: 0x000000010492f072 feap`usolve_ at usolve.F:138:72
135 onnz => mr(np(246):np(246)+ilist(2,246)-1)
136 dnnz => mr(np(247):np(247)+ilist(2,247)-1)
137
-> 138 call MatCreate(PETSC_COMM_WORLD,Kmat,ierr)
139 call
MatSetSizes(Kmat,numpeq,numpeq,PETSC_DETERMINE,
140 & PETSC_DETERMINE,ierr)
141 if(pfeap_bcin) call
MatSetBlockSize(Kmat,nsbk,ierr)
Sanjay Govindjee, PhD, PE
Horace, Dorothy, and Katherine Johnson Professor in Engineering
Distinguished Professor of Civil and Environmental Engineering
779 Davis Hall
University of California
Berkeley, CA 94720-1710
Voice: +1 510 642 6060
FAX: +1 510 643 5264
s_g at berkeley.edu
https://urldefense.us/v3/__http://faculty.ce.berkeley.edu/sanjay__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLJDGn-rKw$
Books:
Introduction to Mechanics of Solid Materials
https://urldefense.us/v3/__https://global.oup.com/academic/product/introduction-to-mechanics-of-solid-materials-9780192866080__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLK6eJ2xMA$
Continuum Mechanics of Solids
https://urldefense.us/v3/__https://global.oup.com/academic/product/continuum-mechanics-of-solids-9780198864721__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLL3Y4t2YA$
Example Problems for Continuum Mechanics of Solids
https://urldefense.us/v3/__https://www.amazon.com/dp/1083047361/__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLIyAaK4Eg$
Engineering Mechanics of Deformable Solids
https://urldefense.us/v3/__https://www.amazon.com/dp/0199651647__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLLf5ewSKQ$
Engineering Mechanics 3 (Dynamics) 2nd Edition
https://urldefense.us/v3/__http://www.amazon.com/dp/3642537111__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLIJH2xWfA$
Engineering Mechanics 3, Supplementary Problems: Dynamics
https://urldefense.us/v3/__http://www.amzn.com/B00SOXN8JU__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLJV9YZdRA$
NSF NHERI SimCenter
https://urldefense.us/v3/__https://simcenter.designsafe-ci.org/__;!!G_uCfscf7eWS!d3a3dMZHNHbpo2pUZUkrJ_sVG2VKWJenpA8SfSld478I1qG5iDDI_A5HMLojdmimArbDAt-E50BvvLJMVyG6GQ$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250323/7f00c0c7/attachment.html>
