[petsc-users] upgrading to 3.22.4
Sanjay Govindjee
s_g at berkeley.edu
Sun Mar 23 02:46:17 CDT 2025
For what its worth I have encountered a few more compile errors (and if
I exclude the failing-to-compile routines some link errors).
The link errors are:
Undefined symbols for architecture x86_64:
"_vecgetarrayreadf90_"
"_vecrestorearrayreadf90_",
The other compile errors are in a routine that starts with
# include <petsc/finclude/petscksp.h>
use petscksp
implicit none
The compile errors are as follows (It seems that some of the
declarations have moved around or have changed).
usolve.F:86:39:
86 | real*8 info(MAT_INFO_SIZE), nza,nzr,mal
| 1
Error: Symbol 'mat_info_size' at (1) has no IMPLICIT type; did you
mean 'mpi_win_size'?
usolve.F:186:39:
186 | mal = info(MAT_INFO_MALLOCS)
| 1
Error: Symbol 'mat_info_mallocs' at (1) has no IMPLICIT type; did
you mean 'mpi_info_null'?
usolve.F:184:44:
184 | nza = info(MAT_INFO_NZ_ALLOCATED)
| 1
Error: Symbol 'mat_info_nz_allocated' at (1) has no IMPLICIT type;
did you mean 'mpi_win_flavor_allocate'?
usolve.F:185:39:
185 | nzr = info(MAT_INFO_NZ_USED)
| 1
Error: Symbol 'mat_info_nz_used' at (1) has no IMPLICIT type; did
usolve.F:144:72:
183 | call MatGetInfo(Kmat, MAT_LOCAL, info, ierr)
| 1
Error: There is no specific subroutine for the generic 'matgetinfo'
at (1)
usolve.F:306:72:
306 | call
PCSetCoordinates(pc,ndm,numpn,hr(np(43)),ierr)
| 1
'pcsetcoordinates' at (1)
usolve.F:339:15:
339 | if(reason.gt.0 .and. echo) then
| 1
Error: Operands of comparison operator '.gt.' at (1) are
TYPE(ekspconvergedreason)/INTEGER(4)
usolve.F:341:52:
341 | write( *,*) ' CONVERGENCE: ',creason(reason),
| 1
Error: Array index at (1) must be of INTEGER type, found DERIVED
usolve.F:343:52:
343 | write(iow,*) ' CONVERGENCE: ',creason(reason),
| 1
usolve.F:345:19:
345 | elseif(reason.lt.0) then
| 1
Error: Operands of comparison operator '.lt.' at (1) are
usolve.F:346:62:
346 | write( *,*) ' NO CONVERGENCE REASON:
',nreason(-reason)
| 1
Error: Operand of unary numeric operator '-' at (1) is UNKNOWN
usolve.F:347:62:
347 | write(iow,*) ' NO CONVERGENCE REASON:
',nreason(-reason)
| 1
On 3/23/25 12:19 AM, Sanjay Govindjee wrote:
> Hi Barry,
> I have moved to main and rebuilt the PETSc libraries etc. Right now
> I am having trouble just getting my source code to compile. Plenty of
> subroutines with PETSc calls compile but a few are throwing errors and
> killing my compile. I suspect there will be more but if I can figure
> these hopefully I can debug the ones that will follow.
> -sanjay
> 'matmpibaijsetpreallocation' at (1)
> upremas.F:68:72:
> 68 | & ierr)
> | 1
> 'matseqbaijsetpreallocation' at (1)
> upremas.F:74:72:
> 74 | & ierr)
> | 1
> 'matmpiaijsetpreallocation' at (1)
> upremas.F:77:72:
> 77 | & ierr)
> | 1
> 'matseqaijsetpreallocation' at (1)
> parkv.F:58:25:
> 58 | PetscViewer Y_view
> | 1
> Error: Type name 'tpetscviewer' at (1) is ambiguous
> parkv.F:69:9:
> 69 | endif
> | 1
> Error: Expecting END SUBROUTINE statement at (1)
> parkv.F:72:9:
> 72 | endif
> | 1
> parkv.F:91:66:
> 91 | call
> PetscViewerASCIIOpen(PETSC_COMM_WORLD,"yvec.m",Y_view,
> | 1
> Error: Symbol 'y_view' at (1) has no IMPLICIT type; did you mean
> 'yvec'?
> parkv.F:65:72:
> 65 | call VecCreate (PETSC_COMM_WORLD, xvec, ierr)
> | 1
> Error: There is no specific subroutine for the generic 'veccreate'
> at (1)
> parkv.F:67:72:
> 67 | call VecSetFromOptions(xvec, ierr)
> | 1
> 'vecsetfromoptions' at (1)
> parkv.F:68:72:
> 68 | call VecDuplicate (xvec, yvec, ierr)
> | 1
> 'vecduplicate' at (1)
> parkv.F:71:72:
> 71 | call VecDuplicate (xvec, yvec, ierr)
> | 1
> parkv.F:85:72:
> 85 | call VecAssemblyBegin(xvec, ierr)
> | 1
> 'vecassemblybegin' at (1)
> parkv.F:86:72:
> 86 | call VecAssemblyEnd (xvec, ierr)
> | 1
> 'vecassemblyend' at (1)
> parkv.F:88:72:
> 88 | call MatMult (Kmat, xvec, yvec, ierr)
> | 1
> Error: There is no specific subroutine for the generic 'matmult'
> at (1)
> parkv.F:101:72:
> 101 | call VecGetOwnershipRange(yvec, starti, endi, ierr)
> | 1
> 'vecgetownershiprange' at (1)
> On 3/21/25 7:17 AM, Barry Smith wrote:
>> I have just pushed a major update to the Fortran interface to the
>> main PETSc git branch. Could you please try to work with main (to
>> become release in a couple of weeks) with your Fortran code as we
>> debug the problem? This will save you a lot of work and hopefully
>> make the debugging more straightforward.
>> You can send the same output with the debugger if it crashes in
>> the main branch and I can try to track down what is going wrong.
>> Barry
>>> On Mar 21, 2025, at 12:37 AM, Sanjay Govindjee via petsc-users
>>> <petsc-users at mcs.anl.gov> wrote:
>>> I am trying to upgrade my code to PETSc 3.22.4 (the code was last
>>> updated to 3.19.4 or perhaps 3.18.1, I've lost track). I've been
>>> using this code with PETSc for over 20 years.
>>> To get my code to compile and link during this update, I only need
>>> to make two changes; one was to use PetscViewerPushFormat instead of
>>> PetscViewerSetFormat and the other was to use
>>> PETSC_NULL_INTEGER_ARRAY in a spot or two.
>>> When I run the code however, I am getting an error very early on
>>> during a call to MatCreate near the beginning of the code. The
>>> screen output says:
>>> [3]PETSC ERROR: matcreate_() at
>>> /Users/sg/petsc-3.22.4/gnug/src/mat/utils/ftn-auto/gcreatef.c:101
>>> Cannot create PETSC_NULL_XXX object
>>> [0]PETSC ERROR: matcreate_() at
>>> [1]PETSC ERROR: matcreate_() at
>>> [2]PETSC ERROR: matcreate_() at
>>> I have a 4 processor run going. I am running with
>>> -on_error_attach_debugger but the debugger is giving me cryptic (at
>>> least to me) output (the same for all 4 processes modulo the PID).
>>> Stack traces seem to be unavailable :(
>>> lldb -p 71963
>>> (lldb) process attach --pid 71963
>>> Process 71963 stopped
>>> * thread #1, queue = 'com.apple.main-thread', stop reason =
>>> signal SIGSTOP
>>> frame #0: 0x00007fff69d92746
>>> libsystem_kernel.dylib`__semwait_signal + 10
>>> libsystem_kernel.dylib`__semwait_signal:
>>> -> 0x7fff69d92746 <+10>: jae 0x7fff69d92750 ; <+20>
>>> 0x7fff69d92748 <+12>: movq %rax, %rdi
>>> 0x7fff69d9274b <+15>: jmp 0x7fff69d9121d ; cerror
>>> 0x7fff69d92750 <+20>: retq
>>> Target 0: (feap) stopped.
>>> Executable module set to "/Users/sg/Feap/ver87/parfeap/feap".
>>> Architecture set to: x86_64h-apple-macosx-.
>>> Does anyone have any hints as to what may be going on? Note the
>>> program starts normally and i can do stuff with the interactive
>>> interface for the code -- even plotting the mesh etc. so I believe
>>> the input data has been read in correctly. The crash only occurs
>>> when I initiate the formation of the matrix.
>>> I am attaching the
>>> /Users/sg/petsc-3.22.4/gnug/src/mat/utils/ftn-auto/gcreatef.c file
>>> in case that offers some insight.
>>> Note, I have been
>>> -sanjay
>>> <gcreatef.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250323/4d4b757d/attachment-0001.html>
