[petsc-users] upgrading to 3.22.4
    Sanjay Govindjee
    s_g at berkeley.edu
    Thu Mar 20 23:37:34 CDT 2025
I am trying to upgrade my code to PETSc 3.22.4 (the code was last
updated to 3.19.4 or perhaps 3.18.1, I've lost track). I've been using
this code with PETSc for over 20 years.
To get my code to compile and link during this update, I only need to
make two changes; one was to use PetscViewerPushFormat instead of
PetscViewerSetFormat and the other was to use PETSC_NULL_INTEGER_ARRAY
in a spot or two.
When I run the code however, I am getting an error very early on during
a call to MatCreate near the beginning of the code.  The screen output says:
    [3]PETSC ERROR: matcreate_() at
    /Users/sg/petsc-3.22.4/gnug/src/mat/utils/ftn-auto/gcreatef.c:101
    Cannot create PETSC_NULL_XXX object
    [0]PETSC ERROR: matcreate_() at
    [1]PETSC ERROR: matcreate_() at
    [2]PETSC ERROR: matcreate_() at
I have a 4 processor run going.  I am running with
-on_error_attach_debugger but the debugger is giving me cryptic (at
least to me) output (the same for all 4 processes modulo the PID). Stack
traces seem to be unavailable :(
    lldb  -p 71963
    (lldb) process attach --pid 71963
    Process 71963 stopped
    * thread #1, queue = 'com.apple.main-thread', stop reason = signal
    SIGSTOP
         frame #0: 0x00007fff69d92746
    libsystem_kernel.dylib`__semwait_signal + 10
    libsystem_kernel.dylib`__semwait_signal:
    ->  0x7fff69d92746 <+10>: jae 0x7fff69d92750            ; <+20>
         0x7fff69d92748 <+12>: movq   %rax, %rdi
         0x7fff69d9274b <+15>: jmp    0x7fff69d9121d            ; cerror
         0x7fff69d92750 <+20>: retq
    Target 0: (feap) stopped.
    Executable module set to "/Users/sg/Feap/ver87/parfeap/feap".
    Architecture set to: x86_64h-apple-macosx-.
Does anyone have any hints as to what may be going on?  Note the program
starts normally and i can do stuff with the interactive interface for
the code -- even plotting the mesh etc. so I believe the input data has
been read in correctly.  The crash only occurs when I initiate the
formation of the matrix.
I am attaching the
/Users/sg/petsc-3.22.4/gnug/src/mat/utils/ftn-auto/gcreatef.c file in
case that offers some insight.
Note, I have been
-sanjay
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250320/d79625d0/attachment.html>
#include "petscsys.h"
#include "petscfix.h"
#include "petsc/private/fortranimpl.h"
/* gcreate.c */
/* Fortran interface file */
* This file was generated automatically by bfort from the C source
* file.
#ifdef PETSC_USE_POINTER_CONVERSION
#if defined(__cplusplus)
extern "C" {
#endif
extern void *PetscToPointer(void*);
extern int PetscFromPointer(void *);
extern void PetscRmPointer(void*);
#endif
#else
#define PetscToPointer(a) (a ? *(PetscFortranAddr *)(a) : 0)
#define PetscFromPointer(a) (PetscFortranAddr)(a)
#define PetscRmPointer(a)
#endif
#include "petscmat.h"
#ifdef PETSC_HAVE_FORTRAN_CAPS
#define matcreate_ MATCREATE
#elif !defined(PETSC_HAVE_FORTRAN_UNDERSCORE) && !defined(FORTRANDOUBLEUNDERSCORE)
#define matcreate_ matcreate
#endif
#define matcreatefromoptions_ MATCREATEFROMOPTIONS
#define matcreatefromoptions_ matcreatefromoptions
#endif
#define matseterroriffailure_ MATSETERRORIFFAILURE
#define matseterroriffailure_ matseterroriffailure
#endif
#define matsetsizes_ MATSETSIZES
#define matsetsizes_ matsetsizes
#endif
#define matsetfromoptions_ MATSETFROMOPTIONS
#define matsetfromoptions_ matsetfromoptions
#endif
#define matxaijsetpreallocation_ MATXAIJSETPREALLOCATION
#define matxaijsetpreallocation_ matxaijsetpreallocation
#endif
#define matheaderreplace_ MATHEADERREPLACE
#define matheaderreplace_ matheaderreplace
#endif
#define matbindtocpu_ MATBINDTOCPU
#define matbindtocpu_ matbindtocpu
#endif
#define matboundtocpu_ MATBOUNDTOCPU
#define matboundtocpu_ matboundtocpu
#endif
#define matsetvaluescoo_ MATSETVALUESCOO
#define matsetvaluescoo_ matsetvaluescoo
#endif
#define matsetbindingpropagates_ MATSETBINDINGPROPAGATES
#define matsetbindingpropagates_ matsetbindingpropagates
#endif
#define matgetbindingpropagates_ MATGETBINDINGPROPAGATES
#define matgetbindingpropagates_ matgetbindingpropagates
#endif
/* Provide declarations for malloc/free if needed for strings */
#include <stdlib.h>
/* Definitions of Fortran Wrapper routines */
extern "C" {
#endif
PETSC_EXTERN void  matcreate_(MPI_Fint * comm,Mat *A, int *ierr)
PETSC_FORTRAN_OBJECT_CREATE(A);
 PetscBool A_null = !*(void**) A ? PETSC_TRUE : PETSC_FALSE;
CHKFORTRANNULLOBJECT(A);
*ierr = MatCreate(
	MPI_Comm_f2c(*(comm)),A);
// if C routine nullifed the object, we must set to to -2 to indicate null set in Fortran
if (! A_null && !*(void**) A) * (void **) A = (void *)-2;
PETSC_EXTERN void  matcreatefromoptions_(MPI_Fint * comm, char *prefix,PetscInt *bs,PetscInt *m,PetscInt *n,PetscInt *M,PetscInt *N,Mat *A, int *ierr, PETSC_FORTRAN_CHARLEN_T cl0)
  char *_cltmp0 = PETSC_NULLPTR;
/* insert Fortran-to-C conversion for prefix */
  FIXCHAR(prefix,cl0,_cltmp0);
*ierr = MatCreateFromOptions(
	MPI_Comm_f2c(*(comm)),_cltmp0,*bs,*m,*n,*M,*N,A);
  FREECHAR(prefix,_cltmp0);
PETSC_EXTERN void  matseterroriffailure_(Mat mat,PetscBool *flg, int *ierr)
CHKFORTRANNULLOBJECT(mat);
*ierr = MatSetErrorIfFailure(
	(Mat)PetscToPointer((mat) ),*flg);
PETSC_EXTERN void  matsetsizes_(Mat A,PetscInt *m,PetscInt *n,PetscInt *M,PetscInt *N, int *ierr)
*ierr = MatSetSizes(
	(Mat)PetscToPointer((A) ),*m,*n,*M,*N);
PETSC_EXTERN void  matsetfromoptions_(Mat B, int *ierr)
CHKFORTRANNULLOBJECT(B);
*ierr = MatSetFromOptions(
	(Mat)PetscToPointer((B) ));
PETSC_EXTERN void  matxaijsetpreallocation_(Mat A,PetscInt *bs, PetscInt dnnz[], PetscInt onnz[], PetscInt dnnzu[], PetscInt onnzu[], int *ierr)
CHKFORTRANNULLINTEGER(dnnz);
CHKFORTRANNULLINTEGER(onnz);
CHKFORTRANNULLINTEGER(dnnzu);
CHKFORTRANNULLINTEGER(onnzu);
*ierr = MatXAIJSetPreallocation(
	(Mat)PetscToPointer((A) ),*bs,dnnz,onnz,dnnzu,onnzu);
PETSC_EXTERN void  matheaderreplace_(Mat A,Mat *C, int *ierr)
PetscBool C_null = !*(void**) C ? PETSC_TRUE : PETSC_FALSE;
CHKFORTRANNULLOBJECT(C);
*ierr = MatHeaderReplace(
	(Mat)PetscToPointer((A) ),C);
if (! C_null && !*(void**) C) * (void **) C = (void *)-2;
PETSC_EXTERN void  matbindtocpu_(Mat A,PetscBool *flg, int *ierr)
*ierr = MatBindToCPU(
	(Mat)PetscToPointer((A) ),*flg);
PETSC_EXTERN void  matboundtocpu_(Mat A,PetscBool *flg, int *ierr)
*ierr = MatBoundToCPU(
	(Mat)PetscToPointer((A) ),flg);
PETSC_EXTERN void  matsetvaluescoo_(Mat A, PetscScalar coo_v[],InsertMode *imode, int *ierr)
CHKFORTRANNULLSCALAR(coo_v);
*ierr = MatSetValuesCOO(
	(Mat)PetscToPointer((A) ),coo_v,*imode);
PETSC_EXTERN void  matsetbindingpropagates_(Mat A,PetscBool *flg, int *ierr)
*ierr = MatSetBindingPropagates(
PETSC_EXTERN void  matgetbindingpropagates_(Mat A,PetscBool *flg, int *ierr)
*ierr = MatGetBindingPropagates(
#endif
