[petsc-users] Semi-coarsening for GMG using DMDA?
Mark Adams mfadams at lbl.gov
Thu Mar 20 11:00:13 CDT 2025
We have worked on semi coarsening in DMPlex, but it is not finished and we
are not working on it now.
I'm not sure about how easy it would be in DMDA, but Barry is suggesting
that it is doable.
We need to wait for Matt and he is on travel so his response may be delayed.
On Thu, Mar 20, 2025 at 11:34 AM Barry Smith <bsmith at petsc.dev> wrote:
>    In theory you can do as you propose. In the context below uniform
> refinement" only means that the coordinates of the DMDA are ignored so each
> refinement. The interpolation is fine woth different refinements in the
> different coordinate directions.
>   Barry
> On Mar 20, 2025, at 5:56 AM, Joe Alexandersen via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Dear PETSc developers,
> We are working with a code that uses regular meshes (DMDA) and geometric
> multigrid. We would like to go from uniform coarsening/refinement to
> semi-coarsening/refinement, due to anisotropy in our underlying equations.
> We have tried to figure out if we can do this using built-in functions of
> PETSc, but it is unclear to us whether we can get it done relatively easily.
> It seems that we can go from the coarsest grid and refine differently in
> each direction using DMDASetRefinementFactor and then use DMRefine to
> define the finer levels. However, from the doc page for
> DMCreateInterpolation, it states that it only works for "uniform
> refinement" which to me seems to indicate it will not work with different
> refinement in each direction. But on the other hand, it states that it
> should work if using DMRefine, which I assume used the information from
> DMDASetRefinementFactor upon creation?
> So our questions are: is there are feasible and relatively simple way to
> do semi-coarsening/refinement of DMDAs for geometric multigrid hierarchies?
> Would the above work?
> Thanks in advance!
> Sincerely,
> Joe Alexandersen
> University of Southern Denmark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250320/8ef4243f/attachment.html>
