[petsc-users] DOF projection after dmforest adaption
Matthew Knepley
knepley at gmail.com
Fri Mar 14 12:04:18 CDT 2025
On Fri, Mar 14, 2025 at 12:15 PM Preda Silvia via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> We are having a hard time understanding how the degrees of freedom are
> projected after a dmforest adaption. Having used before the P4EST library
> directly, we recall that there, a index mapping from quadrants present in
> the grid before and after adaption (1 to 1, 1 to many, many to 1, for
> unaltered, refined, coarsened quadrants, respectively) was available. Would
> it be possible to access the same information for a dmforest?
> Thank you for all the suggestion!
I do not understand exactly what you want yet.
A projection of the dofs would necessarily depend on the function space you
are using to represent the field.
So you might instead be asking, can I get the refinement pattern like the
parent of a given cell. You can get this
https://urldefense.us/v3/__https://petsc.org/main/manualpages/DMPlex/DMPlexGetTreeParent/__;!!G_uCfscf7eWS!aAk0LSbDAPHyCjCzQ3Fa3FjQxqV-5Cx8PkJvYW2BWAfdWeBJcXe9U9MriWyHncDo0mnS_NKfIJJCq7vFlz-x$
There are few users (except us), so we would be happy to listen to
interface suggestions. I will also note that Toby is
the expert, and I am an amateur.
Matt
> Silvia
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aAk0LSbDAPHyCjCzQ3Fa3FjQxqV-5Cx8PkJvYW2BWAfdWeBJcXe9U9MriWyHncDo0mnS_NKfIJJCq_i0Ymri$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aAk0LSbDAPHyCjCzQ3Fa3FjQxqV-5Cx8PkJvYW2BWAfdWeBJcXe9U9MriWyHncDo0mnS_NKfIJJCq5ohAd9A$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250314/8052418e/attachment.html>
