[petsc-users] PetscPythonInitialize, KSPPYTHON, PCPYTHON, etc
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Fri Mar 14 11:53:11 CDT 2025
Thanks Matthew!
I hope you're doing well.
I have a question regarding a change I did on our code: I modified the
code to call |PetscPythonInitialize(PETSC_NULLPTR, PETSC_NULLPTR)| after
|SlepcInitialize|.
Our CI ran successfully across 20 different environments (including
Valgrind), but we encountered a segmentation fault on Ubuntu 24.04 when
calling |PetscPythonInitialize| within our Python module (built using
Pybind11 bindings).
On Ubuntu, calling |PetscPythonInitialize| from within our Python 3
module results in a segfault with the following backtrace:
Thread 1 "python3" received signal SIGSEGV, Segmentation fault.
0x00001555339b372ain PyList_New() from
/lib/x86_64-linux-gnu/libpython3.12.so.1.0
(gdb) bt
#0 0x00001555339b372ain PyList_New() from
#1 0x0000155533ad89d7in PyImport_Import() from
#2 0x0000155533ad8c80in PyImport_ImportModule() from
#3 0x000015553f437c0cin PetscPythonInitialize(pyexe=0x0, pylib=0x0) at
/tmp/build_openmpi-4.1.6-opt/petsc-3.21.6-debug/src/sys/python/pythonsys.c:242
I am puzzled by this segfault...
Some relevant details:
grep -r PETSC_PYTHON_EXE /opt/petsc-3.21.6_debug_openmpi-4.1.6/include/
/opt/petsc-3.21.6_debug_openmpi-4.1.6/include/petscconf.h:#define
PETSC_PYTHON_EXE"/usr/bin/python3"
ls -la /lib/x86_64-linux-gnu/libpython3.12*
lrwxrwxrwx 1 root root 58 Feb 4 09:48
/lib/x86_64-linux-gnu/libpython3.12.a ->
../python3.12/config-3.12-x86_64-linux-gnu/libpython3.12.a
lrwxrwxrwx 1 root root 60 Feb 4 09:48
/lib/x86_64-linux-gnu/libpython3.12d.a ->
../python3.12/config-3.12d-x86_64-linux-gnu/libpython3.12d.a
lrwxrwxrwx 1 root root 19 Feb 4 09:48
/lib/x86_64-linux-gnu/libpython3.12d.so -> libpython3.12d.so.1
lrwxrwxrwx 1 root root 21 Feb 4 09:48
/lib/x86_64-linux-gnu/libpython3.12d.so.1 -> libpython3.12d.so.1.0
-rw-r--r-- 1 root root 34018416 Feb 4 09:48
/lib/x86_64-linux-gnu/libpython3.12d.so.1.0
lrwxrwxrwx 1 root root 18 Feb 4 09:48
/lib/x86_64-linux-gnu/libpython3.12.so -> libpython3.12.so.1
lrwxrwxrwx 1 root root 20 Feb 4 09:48
/lib/x86_64-linux-gnu/libpython3.12.so.1 -> libpython3.12.so.1.0
-rw-r--r-- 1 root root 9055112 Feb 4 09:48
(I installed the debug ("d") versions to get debug symbols, but the
segfault occurs even without them.)
Interestingly, on the same Ubuntu setup, calling |PetscPythonInitialize|
within our /pure C++/ code works fine, and the |"pc_type python"|
example runs successfully.
This issue only occurs when calling |PetscPythonInitialize| from our
/Python module/.
Any ideas?
Could this be something that has already been fixed in PETSc 3.22.x?
Eric
On 2025-03-12 16:48, Matthew Knepley wrote:
> On Wed, Mar 12, 2025 at 4:34 PM Eric Chamberland via petsc-users
> <petsc-users at mcs.anl.gov> wrote:
> Hi,
> just a naive question: looking at KSPPYTHON and PCPYTHON, we saw that
> there is only 1 example available.
> We are asking ourself: is it still supported and can we start
> developping ou PCs and KSPs on top of it?
> Or is there a "new" replacement for these?
> I think the reason that there are so few examples is that many
> examples exist in other packages, such as Firedrake, and they are the
> main consumers. KSPPYTHON is a way to write KSPSHELL using Python
> rather than C, and we mostly write C.
> I will say that recently we fixed everything so that PETSc errors and
> Python exceptions are passed correctly up the stack, and debugging
> these things should be easy. I have been debugging the
> PyVista visualization, and I can change the Python in one window and
> run in the other. It is easy.
> Thanks,
> Matt
> Thanks,
> Eric
> Eric Chamberland, ing., M. Ing
> Professionnel de recherche
> GIREF/Université Laval
> (418) 656-2131 poste 41 22 42
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eq26UN2CarzUz7T9WGteIHDXqp5w7VVjasgK6Vd1QKhEZ2DgW9eB1ibuO_ba7ZyquQVtToW81IARavsFIj_RRgdYXowj80Dz3tMpJzHH$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eq26UN2CarzUz7T9WGteIHDXqp5w7VVjasgK6Vd1QKhEZ2DgW9eB1ibuO_ba7ZyquQVtToW81IARavsFIj_RRgdYXowj80Dz3rS6d7R8$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250314/c0d14495/attachment-0001.html>
