[petsc-users] Doubts on direct solver with mumps
Barry Smith
bsmith at petsc.dev
Tue Mar 4 17:04:34 CST 2025
> On Mar 4, 2025, at 5:17 PM, Emmanuel Ayala <juaneah at gmail.com> wrote:
> Well, I just tested the configuration with --download-f2cblaslapack --download-blis and the direct solver cholesky with mumps becomes 10x faster :D
> Thanks!
> El mar, 4 mar 2025 a la(s) 3:21 p.m., Emmanuel Ayala (juaneah at gmail.com <mailto:juaneah at gmail.com>) escribió:
>> Thanks for the notes.
>> El mar, 4 mar 2025 a la(s) 2:22 p.m., Barry Smith (bsmith at petsc.dev <mailto:bsmith at petsc.dev>) escribió:
>>> > On Mar 4, 2025, at 2:02 PM, Emmanuel Ayala <juaneah at gmail.com <mailto:juaneah at gmail.com>> wrote:
>>> > Hello everyone.
>>> > I'm trying to solve a linear system (which comes from 3D FEM with structured DM mesh) with a direct solver. I configured petsc installation with mumps (–download-mumps –download-scalapack –download-parmetis –download-metis, --download-hwloc, without ptscotch) and I have the following functions:
>>> > // K is the stiffness matrix, assembly correctly
>>> > // U is the solution vector
>>> > // RHS is the right hand side of the linear equation
>>> > Mat Kfactor;
>>> > ierr = MatGetFactor(K,MATSOLVERMUMPS, MAT_FACTOR_CHOLESKY, &Kfactor); CHKERRQ(ierr);
>>> > ierr = MatCholeskyFactorSymbolic(Kfactor,K,0,0); CHKERRQ(ierr);
>>> > ierr = MatCholeskyFactorNumeric(Kfactor,K,0); CHKERRQ(ierr);
>>> > ierr = MatSolve(Kfactor,RHS,U);
>>> Note 1) these four lines of code above are not needed if you use are using KSPSolve to solve the system. The options below will trigger this.
>>> > and run with options:
>>> > -pc_type cholesky -pc_factor_mat_solver_type mumps -mat_mumps_icntl_1 1 -mat_mumps_icntl_13 0 -mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2
>> OK. I'm solving sepparetelly the direct solver and the iterative one.
>>> Note 2) it is imperative you use a good BLAS library and optimization when using mumps. Do not use --download-blaslapack (or friends) and use --with-debugging=0 in the configure option).
>> Right. I configured it with --with-debugging=0 and --download-fblaslapack. So, which is a good BLAS library? from petsc: ...One can use --download-f2cblaslapack --download-blis...
>>> Note 3) If you are running sequentially (no MPI) then also ensure you have --with-openmp in your configure options and set an appropriate value for the number of OpenMP threads when you run your program.
>> I'm running with MPI .
>> Regards.
>>> > PROBLEM:
>>> > I got the correct solution, but the function MatCholeskyFactorNumeric( ) takes too much time to be completed. MatCholeskyFactorSymbolic() and MatSolve() are very fast. The test uses a square K matrix of 700k dofs, and the MatCholeskyFactorNumeric() takes around 14 minutes, while an iterative solver (KSPCG/PCJACOBI) takes 5 seconds to get the solution. Any suggestions?
>>> > Thanks in advance.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250304/a67fd2b2/attachment.html>
