[petsc-users] Doubts on direct solver with mumps
Emmanuel Ayala juaneah at gmail.com
Tue Mar 4 16:17:43 CST 2025
Well, I just tested the configuration with --download-f2cblaslapack
--download-blis
and the direct solver cholesky with mumps becomes 10x faster :D
Thanks!
El mar, 4 mar 2025 a la(s) 3:21 p.m., Emmanuel Ayala (juaneah at gmail.com)
escribió:
> Thanks for the notes.
> El mar, 4 mar 2025 a la(s) 2:22 p.m., Barry Smith (bsmith at petsc.dev)
> escribió:
>> > On Mar 4, 2025, at 2:02 PM, Emmanuel Ayala <juaneah at gmail.com> wrote:
>> > Hello everyone.
>> > I'm trying to solve a linear system (which comes from 3D FEM with
>> structured DM mesh) with a direct solver. I configured petsc installation
>> with mumps (–download-mumps –download-scalapack –download-parmetis
>> –download-metis, --download-hwloc, without ptscotch) and I have the
>> following functions:
>> >     // K is the stiffness matrix, assembly correctly
>> >     // U is the solution vector
>> >     // RHS is the right hand side of the linear equation
>> >     Mat Kfactor;
>> >     ierr = MatGetFactor(K,MATSOLVERMUMPS, MAT_FACTOR_CHOLESKY,
>> &Kfactor); CHKERRQ(ierr);
>> >     ierr = MatCholeskyFactorSymbolic(Kfactor,K,0,0); CHKERRQ(ierr);
>> >     ierr = MatCholeskyFactorNumeric(Kfactor,K,0); CHKERRQ(ierr);
>> >     ierr = MatSolve(Kfactor,RHS,U);
>> Note 1)  these four lines of code above are not needed if you use are
>> using KSPSolve to solve the system. The options below will trigger this.
>> >     and run with options:
>> >     -pc_type cholesky -pc_factor_mat_solver_type mumps
>> -mat_mumps_icntl_1 1 -mat_mumps_icntl_13 0 -mat_mumps_icntl_28 2
>> -mat_mumps_icntl_29 2
> OK. I'm solving sepparetelly the direct solver and the iterative one.
>> Note 2) it is imperative you use a good BLAS library and optimization
>> when using mumps. Do not use --download-blaslapack (or friends) and use
>> --with-debugging=0 in the configure option).
> Right. I configured it with --with-debugging=0 and --download-fblaslapack. *So,
> which is a good BLAS library?* from petsc: ...One can use
> --download-f2cblaslapack --download-blis...
>> Note 3) If you are running sequentially (no MPI) then also ensure you
>> have --with-openmp in your configure options and set an appropriate value
>> for the number of OpenMP threads when you run your program.
> I'm running with MPI .
> Regards.
>> > PROBLEM:
>> > I got the correct solution, but the function MatCholeskyFactorNumeric(
>> ) takes too much time to be completed. MatCholeskyFactorSymbolic() and
>> MatSolve() are very fast. The test uses a square K matrix of 700k dofs, and
>> the MatCholeskyFactorNumeric() takes around 14 minutes, while an iterative
>> solver (KSPCG/PCJACOBI) takes 5 seconds to get the solution. Any
>> suggestions?
>> > Thanks in advance.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250304/2124186c/attachment-0001.html>
