[petsc-users] Element connectivity of a DMPlex
Matthew Knepley
knepley at gmail.com
Sun Jun 22 20:35:05 CDT 2025
On Sun, Jun 22, 2025 at 8:46 PM Noam T. <dontbugthedevs at proton.me> wrote:
> On Friday, June 20th, 2025 at 9:37 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> I do have this implemented. If you give -dm_plex_high_order_view, it will
> refine the grid and project into the linear space.
> You can see that the code is pretty simple:
> Thanks ,that will be handy. Perhaps this whole idea of using higher-order
> elements will offer no benefit for visualization and we;ll end up using
> linear elements only.
> wrote:
> Yes. The idea is to think of coordinates as a discretized field on the
> mesh, exactly as the solution field. Thus if you want higher order
> coordinates, you choose a higher order coordinate space. I give the
> coordinate space prefix cdm_, so you could say
> -cdm_petscspace_degree 2
> The use of the flag "-..._petscspace_degree N" for higher order
> approximation space is indeed something we use. However, you mention this
> being a field, which is the part confusing me; I am not quite sure how to
> get coordinates values form it; I am only aware of functions such as where
> DMGetCoordinates / DMPlexGetCellCoordinates, which won't do the job here.
1. You could get the values the same way you get values from a higher order
solution field. That would probably use DMGetCoordinates() and the
coordinate Section.
2. You could call DMPlexGetCellCoordinates(), which will mess around and
give you the coordinates on the closure of the cell.
Matt
> The higher order space is indeed created, as shown with -dm_petscds_view
> Discrete System with 1 fields
> cell total dim 6 total comp 1
> Field P2 FEM 1 component (implicit) (Nq 6 Nqc 1) 1-jet
> PetscFE Object: P2 (cdm_) 1 MPI process
> type: basic
> Basic Finite Element in 2 dimensions with 1 components
> PetscSpace Object: P2 (cdm_) 1 MPI process
> type: poly
> Space in 2 variables with 1 components, size 6
> Polynomial space of degree 2
> PetscDualSpace Object: P2 (cdm_) 1 MPI process
> type: lagrange
> Dual space with 1 components, size 6
> Continuous Lagrange dual space
> Quadrature on a triangle of order 4 on 6 points (dim 2)
> Weak Form System with 1 fields
> Thanks,
> Noam
> wrote:
> On Fri, Jun 20, 2025 at 5:14 PM Noam T. <dontbugthedevs at proton.me> wrote:
>> Thank you once again, the code provides exactly what needed.
>> An alternative for the VTK use was subdividing cells using corner nodes
>> and integration points, such that all cells were first order. Any "better"
>> alternative format/visualization software for this purpose?
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/plex.c?ref_type=heads*L2021__;Iw!!G_uCfscf7eWS!dp4Qq6UBZAvh4t0Grm8-HusDmQH03-Azcq6ZI_rLYL-jWzYxJO2Hydno1EYzrv9yjLb7YEUrBkc9OwL-_rO_$
> It uses DMPlexInterpolate() to connect the spaces.
>> Possibly the last question in relation to this matter. We use first order
>> meshes only, as you suggest, and let PETSc handle everything high-order
>> through the approximation space. Hence, when retrieving node coordinates
>> with DMGetCoordinates(Local) or DMPlexGetCellCoordinates, one gets the
>> corner nodes only.
>> Is the list of additional, high-order nodes coordinates readily available
>> (stored) somewhere to be retrieved?
> to get quadratic coordinates. There are some tests in Plex tests ex33.c
> Thanks,
> Matt
>> They can be computed (e.g. using DMPlexReferenceToCoordinates knowing
>> their position in the reference cell; or using corner nodes coordinates),
>> but this will result in shared nodes being computed possibly several times;
>> the large the mesh, the worse.
>> E.g. in the example of the image attached before, DMPlexGetClosureIndices
>> returns
>> [4, 5, 6, 0, 1, 3] for the first cell
>> [7, 8, 5, 1, 2, 3] for the second cell
>> so that 3 nodes (5, 1, 3) will be computed twice if done naively, cell by
>> cell.
>> Thank you,
>> Noam
>> On Thursday, June 19th, 2025 at 12:43 AM, Matthew Knepley <
>> knepley at gmail.com> wrote:
>> On Wed, Jun 18, 2025 at 6:49 PM Noam T. <dontbugthedevs at proton.me> wrote:
>>> See image attached.
>>> Connectivity of the top mesh (first order triangle), can be obtained
>>> with the code shared before.
>>> Connectivity of the bottom mesh (second order triangle) is what I would
>>> be interested in obtaining.
>>> However, given your clarification on what the Plex and the PetscSection
>>> handle, it might not work; I am trying to get form the Plex what's only
>>> available from the PetscSection.
>>> The purpose of this extended connectivity is plotting; in particular,
>>> using VTU files, where the "connectivity" of cells is required, and the
>>> extra nodes would be needed when using higher-order elements (e.g.
>>> VTK_QUADRATIC_TRIANGLE, VTK_QUADRATIC_QUAD, etc).
>> Oh yes. VTK does this in a particularly ugly and backward way. Sigh.
>> There is nothing we can do about this now, but someone should replace VTK
>> with a proper interface at some point.
>> So I understand why you want it and it is a defensible case, so here is
>> how you get that (with some explanation). Those locations, I think, should
>> not be understood as topological things, but rather as the locations of
>> point evaluation functionals constituting a basis for the dual space (to
>> your approximation space). I would call DMPlexGetClosureIndices() (
>> https://urldefense.us/v3/__https://petsc.org/main/manualpages/DMPlex/DMPlexGetClosureIndices/__;!!G_uCfscf7eWS!dp4Qq6UBZAvh4t0Grm8-HusDmQH03-Azcq6ZI_rLYL-jWzYxJO2Hydno1EYzrv9yjLb7YEUrBkc9O6jYpeQt$ ) with
>> a Section having the layout of P2 or Q2. This is the easy way to make that
>> PetscSection gs;
>> PetscFE fe;
>> DMPolytopeType ct;
>> PetscInt dim, cStart;
>> PetscCall(DMGetDimension(dm, &dim));
>> PetscCall(DMPlexGetHeightStratum(dm, 0, &cStart, NULL));
>> PetscCall(DMPlexGetCellType(dm, cStart, &ct));
>> PetscCall(PetscFECreateLagrangeByCell(PETSC_COMM_SELF, dim, 1, ct, 2,
>> PETSC_DETERMINE, &fe));
>> PetscCall(DMSetField(dm, 0, NULL, (PetscObject)fe));
>> PetscCall(PetscFEDestroy(&fe));
>> PetscCall(DMCreateDS(dm));
>> PetscCall(DMGetGlobalSection(dm, &gs));
>> PetscInt *indices = NULL;
>> PetscInt Nidx;
>> PetscCall(DMPlexGetClosureIndices(dm, gs, gs, cell, PETSC_TRUE, &Nidx,
>> &indices, NULL, NULL));
>> Thanks,
>> MAtt
>>> Perhaps I am over complicating things, and all this information can be
>>> obtained in a different, simpler way.
>>> Thanks.
>>> Noam
>>> On Tuesday, June 17th, 2025 at 5:42 PM, Matthew Knepley <
>>> On Tue, Jun 17, 2025 at 12:43 PM Noam T. <dontbugthedevs at proton.me>
>>> wrote:
>>>> Thank you. For now, I am dealing with vertices only.
>>>> Perhaps I did not explain myself properly, or I misunderstood your
>>>> response.
>>>> What I meant to say is, given an element of order higher than one, the
>>>> connectivity matrix I obtain this way only contains as many entries as the
>>>> first order element: 3 for a triangle, 4 for a tetrahedron, etc.
>>>> Looking at the closure of any cell in the mesh, this is also the
>>>> case.However, the nodes are definitely present; e.g. from
>>>> DMPlexGetCellCoordinates(dm, cell, NULL, nc, NULL, NULL)
>>>> nc returns the expected value (12 for a 2nd order 6-node planar
>>>> triangle, 30 for a 2nd order 10-node tetrahedron, etc).
>>>> The question is, are the indices of these extra nodes obtainable in a
>>>> similar way as with the code shared before? So that one can have e.g. [0,
>>>> 1, 2, 3, 4, 5] for a second order triangle, not just [0, 1, 2].
>>> I am having a hard time understanding what you are after. I think this
>>> is because many FEM approaches confuse topology with analysis.
>>> The Plex stores topology, and you can retrieve adjacencies between any
>>> two mesh points.
>>> The PetscSection maps mesh points (cells, faces, edges , vertices) to
>>> sets of dofs. This is how higher order elements are implemented. Thus, we
>>> do not have to change topology to get different function spaces.
>>> The intended interface is for you to call DMPlexVecGetClosure() to get
>>> the closure of a cell (or face, or edge). You can also call
>>> DMPlexGetClosureIndices(), but index wrangling is what I intended to
>>> eliminate.
>>> What exactly are you looking for here?
>>> Thanks,
>>> Matt
>>>> Thank you.
>>>> Noam
>>>> On Friday, June 13th, 2025 at 3:05 PM, Matthew Knepley <
>>>> On Thu, Jun 12, 2025 at 4:26 PM Noam T. <dontbugthedevs at proton.me>
>>>> wrote:
>>>>> Thank you for the code; it provides exactly what I was looking for.
>>>>> Following up on this matter, does this method not work for higher
>>>>> order elements? For example, using an 8-node quadrilateral, exporting to a
>>>>> PETSC_VIEWER_HDF5_VIZ viewer provides the correct matrix of node
>>>>> coordinates in geometry/vertices
>>>> If you wanted to include edges/faces, you could do it. First, you would
>>>> need to decide how you would number things For example, would you number
>>>> all points contiguously, or separately number cells, vertices, faces and
>>>> edges. Second, you would check for faces/edges in the closure loop. Right
>>>> now, we only check for vertices.
>>>> I would say that this is what convinced me not to do FEM this way.
>>>> Thanks,
>>>> Matt
>>>>> (here a quadrilateral in [0, 10])
>>>>> 5.0, 5.0
>>>>> 0.0, 0.0
>>>>> 10.0, 0.0
>>>>> 10.0, 10.0
>>>>> 0.0, 10.0
>>>>> 5.0, 0.0
>>>>> 10.0, 5.0
>>>>> 5.0, 10.0
>>>>> 0.0, 5.0
>>>>> but the connectivity in viz/topology is
>>>>> 0 1 2 3
>>>>> which are likely the corner nodes of the initial, first-order element,
>>>>> before adding extra nodes for the higher degree element.
>>>>> This connectivity values [0, 1, 2, 3, ...] are always the same,
>>>>> including for other elements, whereas the coordinates are correct
>>>>> E.g. for 3rd order triangle in [0, 1], coordinates are given left to
>>>>> right, bottom to top
>>>>> 0, 0
>>>>> 1/3, 0,
>>>>> 2/3, 0,
>>>>> 1, 0
>>>>> 0, 1/3
>>>>> 1/3, 1/3
>>>>> 2/3, 1/3
>>>>> 0, 2/3,
>>>>> 1/3, 2/3
>>>>> 0, 1
>>>>> but the connectivity (viz/topology/cells) is [0, 1, 2].
>>>>> Test meshes were created with gmsh from the python API, using
>>>>> gmsh.option.setNumber("Mesh.ElementOrder", n), for n = 1, 2, 3, ...
>>>>> Thank you.
>>>>> Noam
>>>>> On Friday, May 23rd, 2025 at 12:56 AM, Matthew Knepley <
>>>>> On Thu, May 22, 2025 at 12:25 PM Noam T. <dontbugthedevs at proton.me>
>>>>> wrote:
>>>>>> Hello,
>>>>>> Thank you the various options.
>>>>>> Use case here would be obtaining the exact output generated by option
>>>>>> 1), DMView() with PETSC_VIEWER_HDF5_VIZ; in particular, the matrix
>>>>>> generated under /viz/topology/cells.
>>>>>> There are several ways you might do this. It helps to know what you
>>>>>> are aiming for.
>>>>>> 1) If you just want this output, it might be easier to just DMView()
>>>>>> with the PETSC_VIEWER_HDF5_VIZ format, since that just outputs the
>>>>>> cell-vertex topology and coordinates
>>>>>> Is it possible to get this information in memory, onto a Mat, Vec or
>>>>>> some other Int array object directly? it would be handy to have it in order
>>>>>> to manipulate it and/or save it to a different format/file. Saving to an
>>>>>> HDF5 and loading it again seems redundant.
>>>>>> 2) You can call DMPlexUninterpolate() to produce a mesh with just
>>>>>> cells and vertices, and output it in any format.
>>>>>> 3) If you want it in memory, but still with global indices (I don't
>>>>>> understand this use case), then you can use DMPlexCreatePointNumbering()
>>>>>> for an overall global numbering, or DMPlexCreateCellNumbering() and
>>>>>> DMPlexCreateVertexNumbering() for separate global numberings.
>>>>>> Perhaps I missed it, but getting the connectivity matrix in
>>>>>> /viz/topology/cells/ did not seem directly trivial to me from the list of
>>>>>> global indices returned by DMPlexGetCell/Point/VertexNumbering() (i.e. I
>>>>>> assume all the operations done when calling DMView()).
>>>>> Something like
>>>>> DMPlexGetHeightStratum(dm, 0, &cStart, &cEnd);
>>>>> DMPlexGetDepthStratum(dm, 0, &vStart, &vEnd);
>>>>> DMPlexGetVertexNumbering(dm, &globalVertexNumbers);
>>>>> ISGetIndices(globalVertexNumbers, &gv);
>>>>> for (PetscInt c = cStart; c < cEnd; ++c) {
>>>>> PetscInt *closure = NULL;
>>>>> DMPlexGetTransitiveClosure(dm, c, PETSC_TRUE, &Ncl, &closure);
>>>>> for (PetscInt cl = 0; c < Ncl * 2; cl += 2) {
>>>>> if (closure[cl] < vStart || closure[cl] >= vEnd) continue;
>>>>> const PetscInt v = gv[closure[cl]] < 0 ? -(gv[closure[cl]] + 1) :
>>>>> gv[closure[cl]];
>>>>> // Do something with v
>>>>> DMPlexRestoreTransitiveClosure(dm, c, PETSC_TRUE, &Ncl, &closure);
>>>>> ISRestoreIndices(globalVertexNumbers, &gv);
>>>>> ISDestroy(&globalVertexNumbers);
>>>>> Thanks,
>>>>> Matt
>>>>> Thanks,
>>>>>> Noam.
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dp4Qq6UBZAvh4t0Grm8-HusDmQH03-Azcq6ZI_rLYL-jWzYxJO2Hydno1EYzrv9yjLb7YEUrBkc9O2GHzuqj$
>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dp4Qq6UBZAvh4t0Grm8-HusDmQH03-Azcq6ZI_rLYL-jWzYxJO2Hydno1EYzrv9yjLb7YEUrBkc9O19Mw2-Q$ >
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dp4Qq6UBZAvh4t0Grm8-HusDmQH03-Azcq6ZI_rLYL-jWzYxJO2Hydno1EYzrv9yjLb7YEUrBkc9O2GHzuqj$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dp4Qq6UBZAvh4t0Grm8-HusDmQH03-Azcq6ZI_rLYL-jWzYxJO2Hydno1EYzrv9yjLb7YEUrBkc9O19Mw2-Q$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250622/2cf9f828/attachment-0001.html>
