[petsc-users] Questions Regarding PETSc and Solving Constrained Structural Mechanics Problems
Matthew Knepley
knepley at gmail.com
Fri Jun 20 06:55:33 CDT 2025
On Thu, Jun 19, 2025 at 10:49 PM hexioafeng <hexiaofeng at buaa.edu.cn> wrote:
> I tried to solve S with game and use svd on the coarse grid, then I got
> the error: Arugments are incompatible, Zero diagonal on row 0.
You should not get that error, so I suspect something is wrong with your
setup. Please always send the full output.
> In my opinion, S should be rank-efficient, but not elliptic.
Do you mean full rank? That is unlikely since A_00 is rank deficient.
Matt
> Best regards,
> Xiaofeng
> On Jun 20, 2025, at 10:07, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jun 19, 2025 at 9:18 PM hexioafeng <hexiaofeng at buaa.edu.cn> wrote:
>> Hello,
>> Here are the outputs with svd:
>> 0 KSP unpreconditioned resid norm 2.777777777778e+01 true resid norm
>> 2.777777777778e+01 ||r(i)||/||b|| 1.000000000000e+00
>> Linear fieldsplit_0_mg_levels_1_ solve converged due to
>> CONVERGED_ITS iterations 2
>> Linear fieldsplit_1_ solve did not converge due to DIVERGED_PC_FAILED
> You are running ILU(0) on your Schur complement, but it looks like it is
> rank-deficient. You will have to use something that works for that (like
> maybe GAMG again with SVD on the coarse grid). Is S elliptic?
> Thanks,
> Matt
>> iterations 0
>> PC failed due to SUBPC_ERROR
>> Linear solve did not converge due to DIVERGED_PC_FAILED iterations 0
>> KSP Object: 1 MPI processes
>> type: cg
>> maximum iterations=200, initial guess is zero
>> tolerances: relative=1e-06, absolute=1e-12, divergence=1e+30
>> left preconditioning
>> using UNPRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>> type: fieldsplit
>> FieldSplit with Schur preconditioner, blocksize = 1, factorization
>> FULL
>> Preconditioner for the Schur complement formed from Sp, an assembled
>> approximation to S, which uses A00's diagonal's inverse
>> Split info:
>> Split number 0 Defined by IS
>> Split number 1 Defined by IS
>> KSP solver for A00 block
>> KSP Object: (fieldsplit_0_) 1 MPI processes
>> type: preonly
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>> using NONE norm type for convergence test
>> PC Object: (fieldsplit_0_) 1 MPI processes
>> type: gamg
>> type is MULTIPLICATIVE, levels=2 cycles=v
>> Cycles per PCApply=1
>> Using externally compute Galerkin coarse grid matrices
>> GAMG specific options
>> Threshold for dropping small values in graph on each level
>> Threshold scaling factor for each level not specified = 1.
>> AGG specific options
>> Symmetric graph false
>> Number of levels to square graph 1
>> Number smoothing steps 1
>> Complexity: grid = 1.00222
>> Coarse grid solver -- level -------------------------------
>> KSP Object: (fieldsplit_0_mg_coarse_) 1 MPI processes
>> type: preonly
>> divergence=10000.
>> PC Object: (fieldsplit_0_mg_coarse_) 1 MPI processes
>> type: bjacobi
>> number of blocks = 1
>> Local solver is the same for all blocks, as in the
>> following KSP and PC objects on rank 0:
>> KSP Object: (fieldsplit_0_mg_coarse_sub_) 1 MPI processes
>> type: preonly
>> maximum iterations=1, initial guess is zero
>> divergence=10000.
>> PC Object: (fieldsplit_0_mg_coarse_sub_) 1 MPI processes
>> type: svd
>> All singular values smaller than 1e-12 treated as zero
>> Provided essential rank of the matrix 0 (all other
>> eigenvalues are zeroed)
>> linear system matrix = precond matrix:
>> Mat Object: 1 MPI processes
>> type: seqaij
>> rows=8, cols=8
>> total: nonzeros=56, allocated nonzeros=56
>> total number of mallocs used during MatSetValues calls=0
>> using I-node routines: found 3 nodes, limit used is 5
>> type: mpiaij
>> rows=8, cols=8
>> using nonscalable MatPtAP() implementation
>> using I-node (on process 0) routines: found 3 nodes,
>> limit used is 5
>> Down solver (pre-smoother) on level 1
>> KSP Object: (fieldsplit_0_mg_levels_1_) 1 MPI processes
>> type: chebyshev
>> eigenvalue estimates used: min = 0.0998145, max = 1.09796
>> eigenvalues estimate via gmres min 0.00156735, max 0.998145
>> eigenvalues estimated using gmres with translations [0.
>> 0.1; 0. 1.1]
>> KSP Object: (fieldsplit_0_mg_levels_1_esteig_) 1 MPI
>> processes
>> type: gmres
>> restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> happy breakdown tolerance 1e-30
>> maximum iterations=10, initial guess is zero
>> tolerances: relative=1e-12, absolute=1e-50,
>> divergence=10000.
>> using PRECONDITIONED norm type for convergence test
>> estimating eigenvalues using noisy right hand side
>> maximum iterations=2, nonzero initial guess
>> divergence=10000.
>> PC Object: (fieldsplit_0_mg_levels_1_) 1 MPI processes
>> type: sor
>> type = local_symmetric, iterations = 1, local iterations =
>> 1, omega = 1.
>> Mat Object: (fieldsplit_0_) 1 MPI processes
>> type: mpiaij
>> rows=480, cols=480
>> total: nonzeros=25200, allocated nonzeros=25200
>> using I-node (on process 0) routines: found 160 nodes,
>> limit used is 5
>> Up solver (post-smoother) same as down solver (pre-smoother)
>> type: mpiaij
>> rows=480, cols=480
>> using I-node (on process 0) routines: found 160 nodes, limit
>> used is 5
>> KSP solver for S = A11 - A10 inv(A00) A01
>> KSP Object: (fieldsplit_1_) 1 MPI processes
>> type: preonly
>> PC Object: (fieldsplit_1_) 1 MPI processes
>> type: bjacobi
>> Local solver is the same for all blocks, as in the following
>> KSP Object: (fieldsplit_1_sub_) 1 MPI processes
>> type: preonly
>> PC Object: (fieldsplit_1_sub_) 1 MPI processes
>> type: bjacobi
>> KSP Object: (fieldsplit_1_sub_sub_)
>> 1 MPI processes
>> type: preonly
>> divergence=10000.
>> PC Object: (fieldsplit_1_sub_sub_)
>> 1 MPI processes
>> type: ilu
>> out-of-place factorization
>> 0 levels of fill
>> tolerance for zero pivot 2.22045e-14
>> matrix ordering: natural
>> factor fill ratio given 1., needed 1.
>> Factored matrix follows:
>> type: seqaij
>> rows=144, cols=144
>> package used to perform factorization:
>> petsc
>> total: nonzeros=240, allocated nonzeros=240
>> not using I-node routines
>> type: seqaij
>> rows=144, cols=144
>> calls=0
>> type: mpiaij
>> rows=144, cols=144
>> not using I-node (on process 0) routines
>> linear system matrix followed by preconditioner matrix:
>> Mat Object: (fieldsplit_1_) 1 MPI processes
>> type: schurcomplement
>> rows=144, cols=144
>> Schur complement A11 - A10 inv(A00) A01
>> A11
>> type: mpiaij
>> rows=144, cols=144
>> A10
>> type: mpiaij
>> rows=144, cols=480
>> total: nonzeros=48, allocated nonzeros=48
>> using I-node (on process 0) routines: found 74 nodes,
>> limit used is 5
>> KSP of A00
>> type: preonly
>> divergence=10000.
>> type: gamg
>> matrices
>> each level =
>> specified = 1.
>> type: preonly
>> divergence=10000.
>> type: bjacobi
>> processes
>> type: preonly
>> divergence=10000.
>> processes
>> type: svd
>> as zero
>> other eigenvalues are zeroed)
>> type: seqaij
>> rows=8, cols=8
>> calls=0
>> used is 5
>> type: mpiaij
>> rows=8, cols=8
>> calls=0
>> type: chebyshev
>> 1.09796
>> 0.998145
>> translations [0. 0.1; 0. 1.1]
>> MPI processes
>> type: gmres
>> Gram-Schmidt Orthogonalization with no iterative refinement
>> divergence=10000.
>> test
>> divergence=10000.
>> type: sor
>> iterations = 1, omega = 1.
>> type: mpiaij
>> rows=480, cols=480
>> calls=0
>> (pre-smoother)
>> type: mpiaij
>> rows=480, cols=480
>> calls=0
>> A01
>> type: mpiaij
>> rows=480, cols=144
>> using I-node (on process 0) routines: found 135 nodes,
>> limit used is 5
>> type: mpiaij
>> rows=144, cols=144
>> type: mpiaij
>> rows=624, cols=624
>> total: nonzeros=25536, allocated nonzeros=25536
>> using I-node (on process 0) routines: found 336 nodes, limit used
>> is 5
>> Thanks,
>> Xiaofeng
>> On Jun 20, 2025, at 00:56, Mark Adams <mfadams at lbl.gov> wrote:
>> This is what Matt is looking at:
>> type: lu
>> This should be svd, not lu
>> If you had used -options_left you would have caught this mistake(s)
>> On Thu, Jun 19, 2025 at 8:06 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Thu, Jun 19, 2025 at 7:59 AM hexioafeng <hexiaofeng at buaa.edu.cn>
>>> wrote:
>>>> Hello sir,
>>>> I remove the duplicated "_type", and get the same error and output.
>>> The output cannot be the same. Please send it.
>>> Thanks,
>>> Matt
>>>> Best regards,
>>>> Xiaofeng
>>>> On Jun 19, 2025, at 19:45, Matthew Knepley <knepley at gmail.com> wrote:
>>>> This options is wrong
>>>> -fieldsplit_0_mg_coarse_sub_pc_type_type svd
>>>> Notice that "_type" is repeated.
>>>> Thanks,
>>>> Matt
>>>> On Thu, Jun 19, 2025 at 7:10 AM hexioafeng <hexiaofeng at buaa.edu.cn>
>>>> wrote:
>>>>> Dear authors,
>>>>> Here are the options passed with fieldsplit preconditioner:
>>>>> -ksp_type cg -pc_type fieldsplit -pc_fieldsplit_detect_saddle_point
>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_schur_precondition selfp
>>>>> -pc_fieldsplit_schur_fact_type full -fieldsplit_0_ksp_type preonly
>>>>> -fieldsplit_0_pc_type gamg -fieldsplit_0_mg_coarse_sub_pc_type_type svd
>>>>> -fieldsplit_1_ksp_type preonly -fieldsplit_1_pc_type bjacobi -ksp_view
>>>>> -ksp_monitor_true_residual -ksp_converged_reason
>>>>> -fieldsplit_0_mg_levels_ksp_monitor_true_residual
>>>>> -fieldsplit_0_mg_levels_ksp_converged_reason
>>>>> -fieldsplit_1_ksp_monitor_true_residual
>>>>> -fieldsplit_1_ksp_converged_reason
>>>>> and the output:
>>>>> type: cg
>>>>> type: fieldsplit
>>>>> factorization FULL
>>>>> assembled approximation to S, which uses A00's diagonal's inverse
>>>>> Split info:
>>>>> type: preonly
>>>>> type: gamg
>>>>> level =
>>>>> 1.
>>>>> type: preonly
>>>>> divergence=10000.
>>>>> type: bjacobi
>>>>> type: preonly
>>>>> divergence=10000.
>>>>> type: lu
>>>>> using diagonal shift on blocks to prevent zero pivot
>>>>> [INBLOCKS]
>>>>> matrix ordering: nd
>>>>> factor fill ratio given 5., needed 1.
>>>>> type: seqaij
>>>>> rows=8, cols=8
>>>>> package used to perform factorization: petsc
>>>>> used is 5
>>>>> type: seqaij
>>>>> rows=8, cols=8
>>>>> calls=0
>>>>> 5
>>>>> type: mpiaij
>>>>> rows=8, cols=8
>>>>> limit used is 5
>>>>> type: chebyshev
>>>>> 1.09796
>>>>> 0.998145
>>>>> [0. 0.1; 0. 1.1]
>>>>> processes
>>>>> type: gmres
>>>>> divergence=10000.
>>>>> divergence=10000.
>>>>> type: sor
>>>>> type: mpiaij
>>>>> rows=480, cols=480
>>>>> type: mpiaij
>>>>> rows=480, cols=480
>>>>> limit used is 5
>>>>> type: preonly
>>>>> type: bjacobi
>>>>> type: preonly
>>>>> divergence=10000.
>>>>> type: bjacobi
>>>>> 1 MPI processes
>>>>> type: preonly
>>>>> divergence=10000.
>>>>> 1 MPI processes
>>>>> type: ilu
>>>>> 0 levels of fill
>>>>> type: seqaij
>>>>> rows=144, cols=144
>>>>> petsc
>>>>> nonzeros=240
>>>>> type: seqaij
>>>>> rows=144, cols=144
>>>>> type: mpiaij
>>>>> rows=144, cols=144
>>>>> rows=144, cols=144
>>>>> A11
>>>>> type: mpiaij
>>>>> rows=144, cols=144
>>>>> calls=0
>>>>> A10
>>>>> type: mpiaij
>>>>> rows=144, cols=480
>>>>> calls=0
>>>>> KSP of A00
>>>>> type: preonly
>>>>> divergence=10000.
>>>>> type: gamg
>>>>> matrices
>>>>> each level =
>>>>> specified = 1.
>>>>> processes
>>>>> type: preonly
>>>>> divergence=10000.
>>>>> type: bjacobi
>>>>> the following KSP and PC objects on rank 0:
>>>>> processes
>>>>> type: preonly
>>>>> divergence=10000.
>>>>> processes
>>>>> type: lu
>>>>> zero pivot [INBLOCKS]
>>>>> matrix ordering: nd
>>>>> type: seqaij
>>>>> rows=8, cols=8
>>>>> petsc
>>>>> nonzeros=56
>>>>> limit used is 5
>>>>> type: seqaij
>>>>> rows=8, cols=8
>>>>> used is 5
>>>>> type: mpiaij
>>>>> rows=8, cols=8
>>>>> processes
>>>>> type: chebyshev
>>>>> max = 1.09796
>>>>> max 0.998145
>>>>> 1 MPI processes
>>>>> type: gmres
>>>>> divergence=10000.
>>>>> convergence test
>>>>> side
>>>>> divergence=10000.
>>>>> processes
>>>>> type: sor
>>>>> type: mpiaij
>>>>> rows=480, cols=480
>>>>> 160 nodes, limit used is 5
>>>>> (pre-smoother)
>>>>> type: mpiaij
>>>>> rows=480, cols=480
>>>>> calls=0
>>>>> A01
>>>>> type: mpiaij
>>>>> rows=480, cols=144
>>>>> calls=0
>>>>> type: mpiaij
>>>>> rows=144, cols=144
>>>>> type: mpiaij
>>>>> rows=624, cols=624
>>>>> used is 5
>>>>> Thanks,
>>>>> Xiaofeng
>>>>> On Jun 17, 2025, at 19:05, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> And don't use -pc_gamg_parallel_coarse_grid_solver
>>>>> You can use that in production but for debugging use
>>>>> -mg_coarse_pc_type svd
>>>>> Also, use -options_left and remove anything that is not used.
>>>>> (I am puzzled, I see -pc_type gamg not -pc_type fieldsplit)
>>>>> Mark
>>>>> On Mon, Jun 16, 2025 at 6:40 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Sun, Jun 15, 2025 at 9:46 PM hexioafeng <hexiaofeng at buaa.edu.cn>
>>>>>> wrote:
>>>>>>> Hello,
>>>>>>> Here are the options and outputs:
>>>>>>> options:
>>>>>>> -ksp_type cg -pc_type gamg -pc_gamg_parallel_coarse_grid_solver
>>>>>>> -pc_fieldsplit_detect_saddle_point -pc_fieldsplit_type schur
>>>>>>> -fieldsplit_1_mat_schur_complement_ainv_type lump
>>>>>>> -fieldsplit_0_pc_type gamg -fieldsplit_0_mg_coarse_pc_type_type svd
>>>>>>> -fieldsplit_1_sub_pc_type sor -ksp_view -ksp_monitor_true_residual
>>>>>>> -ksp_converged_reason -fieldsplit_0_mg_levels_ksp_monitor_true_residual
>>>>>> This option was wrong:
>>>>>> from the output, we can see that it should have been
>>>>>> THanks,
>>>>>> Matt
>>>>>>> output:
>>>>>>> type: cg
>>>>>>> type: gamg
>>>>>>> Threshold for dropping small values in graph on each level =
>>>>>>> Complexity: grid = 1.00176
>>>>>>> KSP Object: (mg_coarse_) 1 MPI processes
>>>>>>> type: preonly
>>>>>>> PC Object: (mg_coarse_) 1 MPI processes
>>>>>>> type: bjacobi
>>>>>>> KSP Object: (mg_coarse_sub_) 1 MPI processes
>>>>>>> type: preonly
>>>>>>> divergence=10000.
>>>>>>> PC Object: (mg_coarse_sub_) 1 MPI processes
>>>>>>> type: lu
>>>>>>> [INBLOCKS]
>>>>>>> matrix ordering: nd
>>>>>>> type: seqaij
>>>>>>> rows=7, cols=7
>>>>>>> total: nonzeros=45, allocated nonzeros=45
>>>>>>> is 5
>>>>>>> type: seqaij
>>>>>>> rows=7, cols=7
>>>>>>> type: mpiaij
>>>>>>> rows=7, cols=7
>>>>>>> limit used is 5
>>>>>>> KSP Object: (mg_levels_1_) 1 MPI processes
>>>>>>> type: chebyshev
>>>>>>> eigenvalue estimates used: min = 0., max = 0.
>>>>>>> eigenvalues estimate via gmres min 0., max 0.
>>>>>>> 0.1; 0. 1.1]
>>>>>>> KSP Object: (mg_levels_1_esteig_) 1 MPI processes
>>>>>>> type: gmres
>>>>>>> divergence=10000.
>>>>>>> PC Object: (mg_levels_1_) 1 MPI processes
>>>>>>> type: sor
>>>>>>> type: mpiaij
>>>>>>> rows=624, cols=624
>>>>>>> type: sor
>>>>>>> 1, omega = 1. linear system matrix = precond matrix:
>>>>>>> type: mpiaij
>>>>>>> rows=624, cols=624
>>>>>>> limit used is 5 Up solver (post-smoother) same as down solver
>>>>>>> (pre-smoother)
>>>>>>> type: mpiaij
>>>>>>> rows=624, cols=624
>>>>>>> used is 5
>>>>>>> Best regards,
>>>>>>> Xiaofeng
>>>>>>> On Jun 14, 2025, at 07:28, Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>> Matt,
>>>>>>> Perhaps we should add options -ksp_monitor_debug and
>>>>>>> -snes_monitor_debug that turn on all possible monitoring for the (possibly)
>>>>>>> nested solvers and all of their converged reasons also? Note this is not
>>>>>>> completely trivial because each preconditioner will have to supply its list
>>>>>>> based on the current solver options for it.
>>>>>>> Then we won't need to constantly list a big string of problem
>>>>>>> specific monitor options to ask the user to use.
>>>>>>> Barry
>>>>>>> On Jun 13, 2025, at 9:09 AM, Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>> On Thu, Jun 12, 2025 at 10:55 PM hexioafeng <hexiaofeng at buaa.edu.cn>
>>>>>>> wrote:
>>>>>>>> Dear authors,
>>>>>>>> I tried *-pc_type game -pc_gamg_parallel_coarse_grid_solver* and *-pc_type
>>>>>>>> field split -pc_fieldsplit_detect_saddle_point -fieldsplit_0_ksp_type
>>>>>>>> pronely -fieldsplit_0_pc_type game -fieldsplit_0_mg_coarse_pc_type sad
>>>>>>>> -fieldsplit_1_ksp_type pronely -fieldsplit_1_pc_type Jacobi
>>>>>>>> _fieldsplit_1_sub_pc_type for* , both options got the
>>>>>>>> KSP_DIVERGE_PC_FAILED error.
>>>>>>> With any question about convergence, we need to see the output of
>>>>>>> -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
>>>>>>> -fieldsplit_1_ksp_monitor_true_residual -fieldsplit_1_ksp_converged_reason
>>>>>>> and all the error output.
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> Thanks,
>>>>>>>> Xiaofeng
>>>>>>>> On Jun 12, 2025, at 20:50, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> On Thu, Jun 12, 2025 at 8:44 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Thu, Jun 12, 2025 at 4:58 AM Mark Adams <mfadams at lbl.gov>
>>>>>>>>> wrote:
>>>>>>>>>> Adding this to the PETSc mailing list,
>>>>>>>>>> On Thu, Jun 12, 2025 at 3:43 AM hexioafeng <
>>>>>>>>>>> Dear Professor,
>>>>>>>>>>> I hope this message finds you well.
>>>>>>>>>>> I am an employee at a CAE company and a heavy user of the PETSc
>>>>>>>>>>> library. I would like to thank you for your contributions to PETSc and
>>>>>>>>>>> express my deep appreciation for your work.
>>>>>>>>>>> Recently, I encountered some difficulties when using PETSc to
>>>>>>>>>>> solve structural mechanics problems with Lagrange multiplier constraints.
>>>>>>>>>>> After searching extensively online and reviewing several papers, I found
>>>>>>>>>>> your previous paper titled "*Algebraic multigrid methods for
>>>>>>>>>>> constrained linear systems with applications to contact problems in solid
>>>>>>>>>>> mechanics*" seems to be the most relevant and helpful.
>>>>>>>>>>> The stiffness matrix I'm working with, *K*, is a block
>>>>>>>>>>> saddle-point matrix of the form (A00 A01; A10 0), where *A00 is
>>>>>>>>>>> singular*—just as described in your paper, and different from
>>>>>>>>>>> many other articles . I have a few questions regarding your work and would
>>>>>>>>>>> greatly appreciate your insights:
>>>>>>>>>>> 1. Is the *AMG/KKT* method presented in your paper available in
>>>>>>>>>>> PETSc? I tried using *CG+GAMG* directly but received a
>>>>>>>>>>> *KSP_DIVERGED_PC_FAILED* error. I also attempted to use
>>>>>>>>>>> *CG+PCFIELDSPLIT* with the following options:
>>>>>>>>>> No
>>>>>>>>>>> -fieldsplit_0_pc_type gamg -fieldsplit_1_ksp_type preonly
>>>>>>>>>>> Unfortunately, this also resulted in a
>>>>>>>>>>> *KSP_DIVERGED_PC_FAILED* error. Do you have any suggestions?
>>>>>>>>>>> 2. In your paper, you compare the method with *Uzawa*-type
>>>>>>>>>>> approaches. To my understanding, Uzawa methods typically require A00 to be
>>>>>>>>>>> invertible. How did you handle the singularity of A00 to construct an
>>>>>>>>>>> M-matrix that is invertible?
>>>>>>>>>> You add a regularization term like A01 * A10 (like springs). See
>>>>>>>>>> the paper or any reference to augmented lagrange or Uzawa
>>>>>>>>>> 3. Can i implement the AMG/KKT method in your paper using existing
>>>>>>>>>>> *AMG APIs*? Implementing a production-level AMG solver from
>>>>>>>>>>> scratch would be quite challenging for me, so I’m hoping to utilize
>>>>>>>>>>> existing AMG interfaces within PETSc or other packages.
>>>>>>>>>> You can do Uzawa and make the regularization matrix with
>>>>>>>>>> matrix-matrix products. Just use AMG for the A00 block.
>>>>>>>>>>> 4. For saddle-point systems where A00 is singular, can you
>>>>>>>>>>> recommend any more robust or efficient solutions? Alternatively, are you
>>>>>>>>>>> aware of any open-source software packages that can handle such cases
>>>>>>>>>>> out-of-the-box?
>>>>>>>>>> No, and I don't think PETSc can do this out-of-the-box, but
>>>>>>>>>> others may be able to give you a better idea of what PETSc can do.
>>>>>>>>>> I think PETSc can do Uzawa or other similar algorithms but it
>>>>>>>>>> will not do the regularization automatically (it is a bit more complicated
>>>>>>>>>> than just A01 * A10)
>>>>>>>>> One other trick you can use is to have
>>>>>>>>> -fieldsplit_0_mg_coarse_pc_type svd
>>>>>>>>> This will use SVD on the coarse grid of GAMG, which can handle the
>>>>>>>>> null space in A00 as long as the prolongation does not put it back in. I
>>>>>>>>> have used this for the Laplacian with Neumann conditions and for freely
>>>>>>>>> floating elastic problems.
>>>>>>>> Good point.
>>>>>>>> You can also use -pc_gamg_parallel_coarse_grid_solver to get GAMG
>>>>>>>> to use a on level iterative solver for the coarse grid.
>>>>>>>>> Thanks,
>>>>>>>>> Matt
>>>>>>>>>> Thanks,
>>>>>>>>>> Mark
>>>>>>>>>>> Thank you very much for taking the time to read my email.
>>>>>>>>>>> Looking forward to hearing from you.
>>>>>>>>>>> Sincerely,
>>>>>>>>>>> Xiaofeng He
>>>>>>>>>>> Research Engineer
>>>>>>>>>>> Internet Based Engineering, Beijing, China
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bau_jDLNP3cONGtpUOuWfnaKXWFEHxy4m79iA3uPSfuIiIK0MstOrmbKllq58EumfsF7a8pP4SX-onxxySnZ$
>>>>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!f-YJSzthRa7atIa1xs1GPHW53hGIqSenvp1eO2kDsSyf4jv1_Vp0kL9Lg8pyyPeG8al4Im8XlLqGRHw1FxYh$>
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dYETsi-moODALE1tmLrk5pxFKF9l552nNiC0cBgsCQ9ebugJWHtsNYa0QBS5Gmws9J_VC_Iec3Nx0c1FgNl1$>
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bau_jDLNP3cONGtpUOuWfnaKXWFEHxy4m79iA3uPSfuIiIK0MstOrmbKllq58EumfsF7a8pP4SX-ok1EOJPY$ >
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bau_jDLNP3cONGtpUOuWfnaKXWFEHxy4m79iA3uPSfuIiIK0MstOrmbKllq58EumfsF7a8pP4SX-onxxySnZ$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bau_jDLNP3cONGtpUOuWfnaKXWFEHxy4m79iA3uPSfuIiIK0MstOrmbKllq58EumfsF7a8pP4SX-ok1EOJPY$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250620/84e57902/attachment-0001.html>
