[petsc-users] Questions Regarding PETSc and Solving Constrained Structural Mechanics Problems
Thu Jun 19 21:07:28 CDT 2025
On Thu, Jun 19, 2025 at 9:18 PM hexioafeng <hexiaofeng at buaa.edu.cn> wrote:
> Hello,
> Here are the outputs with svd:
> 0 KSP unpreconditioned resid norm 2.777777777778e+01 true resid norm
> 2.777777777778e+01 ||r(i)||/||b|| 1.000000000000e+00
>     Linear fieldsplit_0_mg_levels_1_ solve converged due to CONVERGED_ITS
> iterations 2
> iterations 2
>   Linear fieldsplit_1_ solve did not converge due to DIVERGED_PC_FAILED
You are running ILU(0) on your Schur complement, but it looks like it is
rank-deficient. You will have to use something that works for that (like
maybe GAMG again with SVD on the coarse grid). Is S elliptic?
     Matt
> iterations 0
>                  PC failed due to SUBPC_ERROR
> iterations 2
> iterations 2
> Linear solve did not converge due to DIVERGED_PC_FAILED iterations 0
> KSP Object: 1 MPI processes
>   type: cg
>   maximum iterations=200, initial guess is zero
>   tolerances:  relative=1e-06, absolute=1e-12, divergence=1e+30
>   left preconditioning
>   using UNPRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, blocksize = 1, factorization FULL
>     Preconditioner for the Schur complement formed from Sp, an assembled
> approximation to S, which uses A00's diagonal's inverse
>     Split info:
>     Split number 0 Defined by IS
>     Split number 1 Defined by IS
>     KSP solver for A00 block
>       KSP Object: (fieldsplit_0_) 1 MPI processes
>         type: preonly
>         maximum iterations=10000, initial guess is zero
>         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>         using NONE norm type for convergence test
>       PC Object: (fieldsplit_0_) 1 MPI processes
>         type: gamg
>           type is MULTIPLICATIVE, levels=2 cycles=v
>             Cycles per PCApply=1
>             Using externally compute Galerkin coarse grid matrices
>             GAMG specific options
>               Threshold for dropping small values in graph on each level =
>               Threshold scaling factor for each level not specified = 1.
>               AGG specific options
>                 Symmetric graph false
>                 Number of levels to square graph 1
>                 Number smoothing steps 1
>               Complexity:    grid = 1.00222
>         Coarse grid solver -- level -------------------------------
>           KSP Object: (fieldsplit_0_mg_coarse_) 1 MPI processes
>             type: preonly
>           PC Object: (fieldsplit_0_mg_coarse_) 1 MPI processes
>             type: bjacobi
>               number of blocks = 1
>               Local solver is the same for all blocks, as in the following
> KSP and PC objects on rank 0:
>             KSP Object: (fieldsplit_0_mg_coarse_sub_) 1 MPI processes
>               type: preonly
>               maximum iterations=1, initial guess is zero
> divergence=10000.
>             PC Object: (fieldsplit_0_mg_coarse_sub_) 1 MPI processes
>               type: svd
>                 All singular values smaller than 1e-12 treated as zero
>                 Provided essential rank of the matrix 0 (all other
> eigenvalues are zeroed)
>               linear system matrix = precond matrix:
>               Mat Object: 1 MPI processes
>                 type: seqaij
>                 rows=8, cols=8
>                 total: nonzeros=56, allocated nonzeros=56
>                 total number of mallocs used during MatSetValues calls=0
>                   using I-node routines: found 3 nodes, limit used is 5
>               type: mpiaij
>               rows=8, cols=8
>                 using nonscalable MatPtAP() implementation
>                 using I-node (on process 0) routines: found 3 nodes, limit
> used is 5
>         Down solver (pre-smoother) on level 1
>           KSP Object: (fieldsplit_0_mg_levels_1_) 1 MPI processes
>             type: chebyshev
>               eigenvalue estimates used:  min = 0.0998145, max = 1.09796
>               eigenvalues estimate via gmres min 0.00156735, max 0.998145
>               eigenvalues estimated using gmres with translations  [0.
> 0.1; 0. 1.1]
>               KSP Object: (fieldsplit_0_mg_levels_1_esteig_) 1 MPI
> processes
>                 type: gmres
>                   restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>                   happy breakdown tolerance 1e-30
>                 maximum iterations=10, initial guess is zero
>                 tolerances:  relative=1e-12, absolute=1e-50,
> divergence=10000.
>                 using PRECONDITIONED norm type for convergence test
>               estimating eigenvalues using noisy right hand side
>             maximum iterations=2, nonzero initial guess
>           PC Object: (fieldsplit_0_mg_levels_1_) 1 MPI processes
>             type: sor
>               type = local_symmetric, iterations = 1, local iterations =
> 1, omega = 1.
>             Mat Object: (fieldsplit_0_) 1 MPI processes
>               type: mpiaij
>               rows=480, cols=480
>               total: nonzeros=25200, allocated nonzeros=25200
>                 using I-node (on process 0) routines: found 160 nodes,
> limit used is 5
>         Up solver (post-smoother) same as down solver (pre-smoother)
>           type: mpiaij
>           rows=480, cols=480
>             using I-node (on process 0) routines: found 160 nodes, limit
> used is 5
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object: (fieldsplit_1_) 1 MPI processes
>         type: preonly
>       PC Object: (fieldsplit_1_) 1 MPI processes
>         type: bjacobi
>           Local solver is the same for all blocks, as in the following KSP
>         KSP Object: (fieldsplit_1_sub_) 1 MPI processes
>           type: preonly
>         PC Object: (fieldsplit_1_sub_) 1 MPI processes
>           type: bjacobi
>                     KSP Object:           (fieldsplit_1_sub_sub_)
>   1 MPI processes
>                       type: preonly
> divergence=10000.
>                     PC Object:           (fieldsplit_1_sub_sub_)
> 1 MPI processes
>                       type: ilu
>                         out-of-place factorization
>                         0 levels of fill
>                         tolerance for zero pivot 2.22045e-14
>                         matrix ordering: natural
>                         factor fill ratio given 1., needed 1.
>                           Factored matrix follows:
>                               type: seqaij
>                               rows=144, cols=144
>                               package used to perform factorization: petsc
>                               total: nonzeros=240, allocated nonzeros=240
>                                 not using I-node routines
>                         type: seqaij
>                         rows=144, cols=144
> calls=0
>             type: mpiaij
>             rows=144, cols=144
>               not using I-node (on process 0) routines
>         linear system matrix followed by preconditioner matrix:
>         Mat Object: (fieldsplit_1_) 1 MPI processes
>           type: schurcomplement
>           rows=144, cols=144
>             Schur complement A11 - A10 inv(A00) A01
>             A11
>                 type: mpiaij
>                 rows=144, cols=144
>             A10
>                 type: mpiaij
>                 rows=144, cols=480
>                 total: nonzeros=48, allocated nonzeros=48
>                   using I-node (on process 0) routines: found 74 nodes,
> limit used is 5
>             KSP of A00
>                 type: preonly
> divergence=10000.
>                 type: gamg
> level =
> specified = 1.
>                     type: preonly
> divergence=10000.
>                     type: bjacobi
> following KSP and PC objects on rank 0:
> processes
>                       type: preonly
> divergence=10000.
> processes
>                       type: svd
> zero
>                         type: seqaij
>                         rows=8, cols=8
> calls=0
> is 5
>                       type: mpiaij
>                       rows=8, cols=8
> calls=0
>                     type: chebyshev
> 1.09796
> 0.998145
>  [0. 0.1; 0. 1.1]
> processes
>                         type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
> divergence=10000.
> divergence=10000.
>                     type: sor
> iterations = 1, omega = 1.
>                       type: mpiaij
>                       rows=480, cols=480
> calls=0
> (pre-smoother)
>                   type: mpiaij
>                   rows=480, cols=480
> limit used is 5
>             A01
>                 type: mpiaij
>                 rows=480, cols=144
>                   using I-node (on process 0) routines: found 135 nodes,
> limit used is 5
>           type: mpiaij
>           rows=144, cols=144
>     type: mpiaij
>     rows=624, cols=624
>     total: nonzeros=25536, allocated nonzeros=25536
>       using I-node (on process 0) routines: found 336 nodes, limit used is
> 5
> Thanks,
> Xiaofeng
> On Jun 20, 2025, at 00:56, Mark Adams <mfadams at lbl.gov> wrote:
> This is what Matt is looking at:
>                       type: lu
> This should be svd, not lu
> If you had used -options_left you would have caught this mistake(s)
> On Thu, Jun 19, 2025 at 8:06 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jun 19, 2025 at 7:59 AM hexioafeng <hexiaofeng at buaa.edu.cn>
>> wrote:
>>> Hello sir,
>>> I remove the duplicated "_type", and get the same error and output.
>> The output cannot be the same. Please send it.
>>   Thanks,
>>      Matt
>>> Best regards,
>>> Xiaofeng
>>> On Jun 19, 2025, at 19:45, Matthew Knepley <knepley at gmail.com> wrote:
>>> This options is wrong
>>>   -fieldsplit_0_mg_coarse_sub_pc_type_type svd
>>> Notice that "_type" is repeated.
>>>   Thanks,
>>>       Matt
>>> On Thu, Jun 19, 2025 at 7:10 AM hexioafeng <hexiaofeng at buaa.edu.cn>
>>> wrote:
>>>> Dear authors,
>>>> Here are the options passed with fieldsplit preconditioner:
>>>> -ksp_type cg -pc_type fieldsplit -pc_fieldsplit_detect_saddle_point
>>>>  -pc_fieldsplit_type schur -pc_fieldsplit_schur_precondition selfp
>>>> -pc_fieldsplit_schur_fact_type full -fieldsplit_0_ksp_type preonly
>>>> -fieldsplit_0_pc_type gamg -fieldsplit_0_mg_coarse_sub_pc_type_type svd
>>>> -fieldsplit_1_ksp_type preonly -fieldsplit_1_pc_type bjacobi -ksp_view
>>>>  -ksp_monitor_true_residual  -ksp_converged_reason
>>>>  -fieldsplit_0_mg_levels_ksp_monitor_true_residual
>>>>  -fieldsplit_0_mg_levels_ksp_converged_reason
>>>>  -fieldsplit_1_ksp_monitor_true_residual
>>>>  -fieldsplit_1_ksp_converged_reason
>>>> and the output:
>>>> CONVERGED_ITS iterations 2
>>>> iterations 0
>>>>   type: cg
>>>>   type: fieldsplit
>>>> FULL
>>>> assembled approximation to S, which uses A00's diagonal's inverse
>>>>     Split info:
>>>>         type: preonly
>>>>         type: gamg
>>>> level =
>>>>             type: preonly
>>>> divergence=10000.
>>>>             type: bjacobi
>>>>               type: preonly
>>>> divergence=10000.
>>>>               type: lu
>>>>                 using diagonal shift on blocks to prevent zero pivot
>>>> [INBLOCKS]
>>>>                 matrix ordering: nd
>>>>                 factor fill ratio given 5., needed 1.
>>>>                       type: seqaij
>>>>                       rows=8, cols=8
>>>> used is 5
>>>>                 type: seqaij
>>>>                 rows=8, cols=8
>>>>               type: mpiaij
>>>>               rows=8, cols=8
>>>> limit used is 5
>>>>             type: chebyshev
>>>> 0.998145
>>>> 0.1; 0. 1.1]
>>>> processes
>>>>                 type: gmres
>>>> divergence=10000.
>>>> divergence=10000.
>>>>             type: sor
>>>> = 1, omega = 1.
>>>>               type: mpiaij
>>>>               rows=480, cols=480
>>>> limit used is 5
>>>>           type: mpiaij
>>>>           rows=480, cols=480
>>>> limit used is 5
>>>>         type: preonly
>>>>         type: bjacobi
>>>>           type: preonly
>>>>           type: bjacobi
>>>>     1 MPI processes
>>>>                       type: preonly
>>>> divergence=10000.
>>>>     1 MPI processes
>>>>                       type: ilu
>>>>                         0 levels of fill
>>>>                               type: seqaij
>>>>                               rows=144, cols=144
>>>> petsc
>>>> nonzeros=240
>>>>                         type: seqaij
>>>>                         rows=144, cols=144
>>>>             type: mpiaij
>>>>             rows=144, cols=144
>>>>           rows=144, cols=144
>>>>             A11
>>>>                 type: mpiaij
>>>>                 rows=144, cols=144
>>>>             A10
>>>>                 type: mpiaij
>>>>                 rows=144, cols=480
>>>> limit used is 5
>>>>             KSP of A00
>>>>                 type: preonly
>>>> divergence=10000.
>>>>                 type: gamg
>>>> matrices
>>>> each level =
>>>> specified = 1.
>>>>                     type: preonly
>>>> divergence=10000.
>>>>                     type: bjacobi
>>>> the following KSP and PC objects on rank 0:
>>>> processes
>>>>                       type: preonly
>>>> divergence=10000.
>>>> processes
>>>>                       type: lu
>>>> pivot [INBLOCKS]
>>>>                         matrix ordering: nd
>>>>                               type: seqaij
>>>>                               rows=8, cols=8
>>>> petsc
>>>> limit used is 5
>>>>                         type: seqaij
>>>>                         rows=8, cols=8
>>>> used is 5
>>>>                       type: mpiaij
>>>>                       rows=8, cols=8
>>>> calls=0
>>>> processes
>>>>                     type: chebyshev
>>>> = 1.09796
>>>> max 0.998145
>>>> translations  [0. 0.1; 0. 1.1]
>>>> MPI processes
>>>>                         type: gmres
>>>> divergence=10000.
>>>> test
>>>> divergence=10000.
>>>>                     type: sor
>>>>                       type: mpiaij
>>>>                       rows=480, cols=480
>>>> calls=0
>>>> (pre-smoother)
>>>>                   type: mpiaij
>>>>                   rows=480, cols=480
>>>> calls=0
>>>>             A01
>>>>                 type: mpiaij
>>>>                 rows=480, cols=144
>>>>           type: mpiaij
>>>>           rows=144, cols=144
>>>>     type: mpiaij
>>>>     rows=624, cols=624
>>>> is 5
>>>> Thanks,
>>>> Xiaofeng
>>>> On Jun 17, 2025, at 19:05, Mark Adams <mfadams at lbl.gov> wrote:
>>>> And don't use -pc_gamg_parallel_coarse_grid_solver
>>>> You can use that in production but for debugging use -mg_coarse_pc_type
>>>> svd
>>>> Also, use -options_left and remove anything that is not used.
>>>> (I am puzzled, I see -pc_type gamg not -pc_type fieldsplit)
>>>> Mark
>>>> On Mon, Jun 16, 2025 at 6:40 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Sun, Jun 15, 2025 at 9:46 PM hexioafeng <hexiaofeng at buaa.edu.cn>
>>>>> wrote:
>>>>>> Hello,
>>>>>> Here are the options and outputs:
>>>>>> options:
>>>>>> -ksp_type cg -pc_type gamg -pc_gamg_parallel_coarse_grid_solver
>>>>>>  -pc_fieldsplit_detect_saddle_point  -pc_fieldsplit_type schur
>>>>>> -fieldsplit_1_mat_schur_complement_ainv_type lump
>>>>>> -fieldsplit_0_pc_type gamg -fieldsplit_0_mg_coarse_pc_type_type svd
>>>>>> -fieldsplit_1_sub_pc_type sor -ksp_view  -ksp_monitor_true_residual
>>>>>>  -ksp_converged_reason  -fieldsplit_0_mg_levels_ksp_monitor_true_residual
>>>>> This option was wrong:
>>>>> from the output, we can see that it should have been
>>>>>   THanks,
>>>>>      Matt
>>>>>> output:
>>>>>>   type: cg
>>>>>>   type: gamg
>>>>>>         Complexity:    grid = 1.00176
>>>>>>     KSP Object: (mg_coarse_) 1 MPI processes
>>>>>>       type: preonly
>>>>>>     PC Object: (mg_coarse_) 1 MPI processes
>>>>>>       type: bjacobi
>>>>>>       KSP Object: (mg_coarse_sub_) 1 MPI processes
>>>>>>         type: preonly
>>>>>>       PC Object: (mg_coarse_sub_) 1 MPI processes
>>>>>>         type: lu
>>>>>> [INBLOCKS]
>>>>>>           matrix ordering: nd
>>>>>>                 type: seqaij
>>>>>>                 rows=7, cols=7
>>>>>>                 total: nonzeros=45, allocated nonzeros=45
>>>>>> 5
>>>>>>           type: seqaij
>>>>>>           rows=7, cols=7
>>>>>>         type: mpiaij
>>>>>>         rows=7, cols=7
>>>>>> used is 5
>>>>>>     KSP Object: (mg_levels_1_) 1 MPI processes
>>>>>>       type: chebyshev
>>>>>>         eigenvalue estimates used:  min = 0., max = 0.
>>>>>>         eigenvalues estimate via gmres min 0., max 0.
>>>>>>         eigenvalues estimated using gmres with translations  [0. 0.1;
>>>>>> 0. 1.1]
>>>>>>         KSP Object: (mg_levels_1_esteig_) 1 MPI processes
>>>>>>           type: gmres
>>>>>> divergence=10000.
>>>>>>         PC Object: (mg_levels_1_) 1 MPI processes
>>>>>>           type: sor
>>>>>> = 1, omega = 1.
>>>>>>             type: mpiaij
>>>>>>             rows=624, cols=624
>>>>>> limit used is 5
>>>>>>       type: sor
>>>>>>         type = local_symmetric, iterations = 1, local iterations = 1,
>>>>>> omega = 1.      linear system matrix = precond matrix:
>>>>>>         type: mpiaij
>>>>>>         rows=624, cols=624
>>>>>> limit used is 5  Up solver (post-smoother) same as down solver
>>>>>> (pre-smoother)
>>>>>>     type: mpiaij
>>>>>>     rows=624, cols=624
>>>>>> used is 5
>>>>>> Best regards,
>>>>>> Xiaofeng
>>>>>> On Jun 14, 2025, at 07:28, Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>   Matt,
>>>>>>    Perhaps we should add options -ksp_monitor_debug and
>>>>>> -snes_monitor_debug that turn on all possible monitoring for the (possibly)
>>>>>> nested solvers and all of their converged reasons also? Note this is not
>>>>>> completely trivial because each preconditioner will have to supply its list
>>>>>> based on the current solver options for it.
>>>>>>    Then we won't need to constantly list a big string of problem
>>>>>> specific monitor options to ask the user to use.
>>>>>>   Barry
>>>>>> On Jun 13, 2025, at 9:09 AM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>> On Thu, Jun 12, 2025 at 10:55 PM hexioafeng <hexiaofeng at buaa.edu.cn>
>>>>>> wrote:
>>>>>>> Dear authors,
>>>>>>> I tried *-pc_type game -pc_gamg_parallel_coarse_grid_solver* and *-pc_type
>>>>>>> field split -pc_fieldsplit_detect_saddle_point -fieldsplit_0_ksp_type
>>>>>>> pronely -fieldsplit_0_pc_type game -fieldsplit_0_mg_coarse_pc_type sad
>>>>>>> -fieldsplit_1_ksp_type pronely -fieldsplit_1_pc_type Jacobi
>>>>>>> _fieldsplit_1_sub_pc_type for* , both options got the
>>>>>>> KSP_DIVERGE_PC_FAILED error.
>>>>>> With any question about convergence, we need to see the output of
>>>>>>   -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
>>>>>> -fieldsplit_1_ksp_monitor_true_residual -fieldsplit_1_ksp_converged_reason
>>>>>> and all the error output.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Thanks,
>>>>>>> Xiaofeng
>>>>>>> On Jun 12, 2025, at 20:50, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> On Thu, Jun 12, 2025 at 8:44 AM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Thu, Jun 12, 2025 at 4:58 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>> Adding this to the PETSc mailing list,
>>>>>>>>> On Thu, Jun 12, 2025 at 3:43 AM hexioafeng <hexiaofeng at buaa.edu.cn>
>>>>>>>>> wrote:
>>>>>>>>>> Dear Professor,
>>>>>>>>>> I hope this message finds you well.
>>>>>>>>>> I am an employee at a CAE company and a heavy user of the PETSc
>>>>>>>>>> library. I would like to thank you for your contributions to PETSc and
>>>>>>>>>> express my deep appreciation for your work.
>>>>>>>>>> Recently, I encountered some difficulties when using PETSc to
>>>>>>>>>> solve structural mechanics problems with Lagrange multiplier constraints.
>>>>>>>>>> After searching extensively online and reviewing several papers, I found
>>>>>>>>>> your previous paper titled "*Algebraic multigrid methods for
>>>>>>>>>> constrained linear systems with applications to contact problems in solid
>>>>>>>>>> mechanics*" seems to be the most relevant and helpful.
>>>>>>>>>> The stiffness matrix I'm working with, *K*, is a block
>>>>>>>>>> saddle-point matrix of the form (A00 A01; A10 0), where *A00 is
>>>>>>>>>> singular*—just as described in your paper, and different from
>>>>>>>>>> many other articles . I have a few questions regarding your work and would
>>>>>>>>>> greatly appreciate your insights:
>>>>>>>>>> 1. Is the *AMG/KKT* method presented in your paper available in
>>>>>>>>>> PETSc? I tried using *CG+GAMG* directly but received a
>>>>>>>>>> *KSP_DIVERGED_PC_FAILED* error. I also attempted to use
>>>>>>>>>> *CG+PCFIELDSPLIT* with the following options:
>>>>>>>>> No
>>>>>>>>>> -fieldsplit_0_pc_type gamg -fieldsplit_1_ksp_type preonly
>>>>>>>>>>    Unfortunately, this also resulted in a
>>>>>>>>>> *KSP_DIVERGED_PC_FAILED* error. Do you have any suggestions?
>>>>>>>>>> 2. In your paper, you compare the method with *Uzawa*-type
>>>>>>>>>> approaches. To my understanding, Uzawa methods typically require A00 to be
>>>>>>>>>> invertible. How did you handle the singularity of A00 to construct an
>>>>>>>>>> M-matrix that is invertible?
>>>>>>>>> You add a regularization term like A01 * A10 (like springs). See
>>>>>>>>> the paper or any reference to augmented lagrange or Uzawa
>>>>>>>>> 3. Can i implement the AMG/KKT method in your paper using existing
>>>>>>>>>>  *AMG APIs*? Implementing a production-level AMG solver from
>>>>>>>>>> scratch would be quite challenging for me, so I’m hoping to utilize
>>>>>>>>>> existing AMG interfaces within PETSc or other packages.
>>>>>>>>> You can do Uzawa and make the regularization matrix with
>>>>>>>>> matrix-matrix products. Just use AMG for the A00 block.
>>>>>>>>>> 4. For saddle-point systems where A00 is singular, can you
>>>>>>>>>> recommend any more robust or efficient solutions? Alternatively, are you
>>>>>>>>>> aware of any open-source software packages that can handle such cases
>>>>>>>>>> out-of-the-box?
>>>>>>>>> No, and I don't think PETSc can do this out-of-the-box, but others
>>>>>>>>> may be able to give you a better idea of what PETSc can do.
>>>>>>>>> I think PETSc can do Uzawa or other similar algorithms but it will
>>>>>>>>> not do the regularization automatically (it is a bit more complicated than
>>>>>>>>> just A01 * A10)
>>>>>>>> One other trick you can use is to have
>>>>>>>>   -fieldsplit_0_mg_coarse_pc_type svd
>>>>>>>> This will use SVD on the coarse grid of GAMG, which can handle the
>>>>>>>> null space in A00 as long as the prolongation does not put it back in. I
>>>>>>>> have used this for the Laplacian with Neumann conditions and for freely
>>>>>>>> floating elastic problems.
>>>>>>> Good point.
>>>>>>> You can also use -pc_gamg_parallel_coarse_grid_solver to get GAMG to
>>>>>>> use a on level iterative solver for the coarse grid.
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Thanks,
>>>>>>>>> Mark
>>>>>>>>>> Thank you very much for taking the time to read my email. Looking
>>>>>>>>>> forward to hearing from you.
>>>>>>>>>> Sincerely,
>>>>>>>>>> Xiaofeng He
>>>>>>>>>> Research Engineer
>>>>>>>>>> Internet Based Engineering, Beijing, China
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bCEQ75t2tb346ZO4z8MiHCNG9f8IWujBRyEK8EbJqLTQfpfGIn5H_0ZXA_V7K7Y7Csps7k35GiSVrqnpTYvh$
>>>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!f-YJSzthRa7atIa1xs1GPHW53hGIqSenvp1eO2kDsSyf4jv1_Vp0kL9Lg8pyyPeG8al4Im8XlLqGRHw1FxYh$>
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dYETsi-moODALE1tmLrk5pxFKF9l552nNiC0cBgsCQ9ebugJWHtsNYa0QBS5Gmws9J_VC_Iec3Nx0c1FgNl1$>
>>> experiments lead.
>>> -- Norbert Wiener
>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bCEQ75t2tb346ZO4z8MiHCNG9f8IWujBRyEK8EbJqLTQfpfGIn5H_0ZXA_V7K7Y7Csps7k35GiSVro8L1MVr$ >
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bCEQ75t2tb346ZO4z8MiHCNG9f8IWujBRyEK8EbJqLTQfpfGIn5H_0ZXA_V7K7Y7Csps7k35GiSVrqnpTYvh$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bCEQ75t2tb346ZO4z8MiHCNG9f8IWujBRyEK8EbJqLTQfpfGIn5H_0ZXA_V7K7Y7Csps7k35GiSVro8L1MVr$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250619/a31c1362/attachment-0001.html>
