[petsc-users] Questions Regarding PETSc and Solving Constrained Structural Mechanics Problems
Matthew Knepley
knepley at gmail.com
Thu Jun 19 07:06:46 CDT 2025
On Thu, Jun 19, 2025 at 7:59 AM hexioafeng <hexiaofeng at buaa.edu.cn> wrote:
> Hello sir,
> I remove the duplicated "_type", and get the same error and output.
The output cannot be the same. Please send it.
Matt
> Best regards,
> Xiaofeng
> On Jun 19, 2025, at 19:45, Matthew Knepley <knepley at gmail.com> wrote:
> This options is wrong
> -fieldsplit_0_mg_coarse_sub_pc_type_type svd
> Notice that "_type" is repeated.
> Thanks,
> Matt
> On Thu, Jun 19, 2025 at 7:10 AM hexioafeng <hexiaofeng at buaa.edu.cn> wrote:
>> Dear authors,
>> Here are the options passed with fieldsplit preconditioner:
>> -ksp_type cg -pc_type fieldsplit -pc_fieldsplit_detect_saddle_point
>> -pc_fieldsplit_type schur -pc_fieldsplit_schur_precondition selfp
>> -pc_fieldsplit_schur_fact_type full -fieldsplit_0_ksp_type preonly
>> -fieldsplit_0_pc_type gamg -fieldsplit_0_mg_coarse_sub_pc_type_type svd
>> -fieldsplit_1_ksp_type preonly -fieldsplit_1_pc_type bjacobi -ksp_view
>> -ksp_monitor_true_residual -ksp_converged_reason
>> -fieldsplit_0_mg_levels_ksp_monitor_true_residual
>> -fieldsplit_0_mg_levels_ksp_converged_reason
>> -fieldsplit_1_ksp_monitor_true_residual
>> -fieldsplit_1_ksp_converged_reason
>> and the output:
>> 0 KSP unpreconditioned resid norm 2.777777777778e+01 true resid norm
>> 2.777777777778e+01 ||r(i)||/||b|| 1.000000000000e+00
>> Linear fieldsplit_0_mg_levels_1_ solve converged due to CONVERGED_ITS
>> iterations 2
>> iterations 2
>> Linear fieldsplit_1_ solve did not converge due to DIVERGED_PC_FAILED
>> iterations 0
>> PC failed due to SUBPC_ERROR
>> iterations 2
>> iterations 2
>> Linear solve did not converge due to DIVERGED_PC_FAILED iterations 0
>> KSP Object: 1 MPI processes
>> type: cg
>> maximum iterations=200, initial guess is zero
>> tolerances: relative=1e-06, absolute=1e-12, divergence=1e+30
>> left preconditioning
>> using UNPRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>> type: fieldsplit
>> FieldSplit with Schur preconditioner, blocksize = 1, factorization
>> FULL
>> Preconditioner for the Schur complement formed from Sp, an assembled
>> approximation to S, which uses A00's diagonal's inverse
>> Split info:
>> Split number 0 Defined by IS
>> Split number 1 Defined by IS
>> KSP solver for A00 block
>> KSP Object: (fieldsplit_0_) 1 MPI processes
>> type: preonly
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>> using NONE norm type for convergence test
>> PC Object: (fieldsplit_0_) 1 MPI processes
>> type: gamg
>> type is MULTIPLICATIVE, levels=2 cycles=v
>> Cycles per PCApply=1
>> Using externally compute Galerkin coarse grid matrices
>> GAMG specific options
>> Threshold for dropping small values in graph on each level
>> Threshold scaling factor for each level not specified = 1.
>> AGG specific options
>> Symmetric graph false
>> Number of levels to square graph 1
>> Number smoothing steps 1
>> Complexity: grid = 1.00222
>> Coarse grid solver -- level -------------------------------
>> KSP Object: (fieldsplit_0_mg_coarse_) 1 MPI processes
>> type: preonly
>> PC Object: (fieldsplit_0_mg_coarse_) 1 MPI processes
>> type: bjacobi
>> number of blocks = 1
>> Local solver is the same for all blocks, as in the
>> following KSP and PC objects on rank 0:
>> KSP Object: (fieldsplit_0_mg_coarse_sub_) 1 MPI processes
>> type: preonly
>> maximum iterations=1, initial guess is zero
>> divergence=10000.
>> PC Object: (fieldsplit_0_mg_coarse_sub_) 1 MPI processes
>> type: lu
>> out-of-place factorization
>> tolerance for zero pivot 2.22045e-14
>> using diagonal shift on blocks to prevent zero pivot
>> [INBLOCKS]
>> matrix ordering: nd
>> factor fill ratio given 5., needed 1.
>> Factored matrix follows:
>> Mat Object: 1 MPI processes
>> type: seqaij
>> rows=8, cols=8
>> package used to perform factorization: petsc
>> total: nonzeros=56, allocated nonzeros=56
>> using I-node routines: found 3 nodes, limit used
>> is 5
>> linear system matrix = precond matrix:
>> type: seqaij
>> rows=8, cols=8
>> total number of mallocs used during MatSetValues calls=0
>> using I-node routines: found 3 nodes, limit used is 5
>> type: mpiaij
>> rows=8, cols=8
>> using nonscalable MatPtAP() implementation
>> using I-node (on process 0) routines: found 3 nodes,
>> limit used is 5
>> Down solver (pre-smoother) on level 1
>> KSP Object: (fieldsplit_0_mg_levels_1_) 1 MPI processes
>> type: chebyshev
>> eigenvalue estimates used: min = 0.0998145, max = 1.09796
>> eigenvalues estimate via gmres min 0.00156735, max 0.998145
>> eigenvalues estimated using gmres with translations [0.
>> 0.1; 0. 1.1]
>> KSP Object: (fieldsplit_0_mg_levels_1_esteig_) 1 MPI
>> processes
>> type: gmres
>> restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> happy breakdown tolerance 1e-30
>> maximum iterations=10, initial guess is zero
>> tolerances: relative=1e-12, absolute=1e-50,
>> divergence=10000.
>> using PRECONDITIONED norm type for convergence test
>> estimating eigenvalues using noisy right hand side
>> maximum iterations=2, nonzero initial guess
>> PC Object: (fieldsplit_0_mg_levels_1_) 1 MPI processes
>> type: sor
>> type = local_symmetric, iterations = 1, local iterations =
>> 1, omega = 1.
>> Mat Object: (fieldsplit_0_) 1 MPI processes
>> type: mpiaij
>> rows=480, cols=480
>> total: nonzeros=25200, allocated nonzeros=25200
>> using I-node (on process 0) routines: found 160 nodes,
>> limit used is 5
>> Up solver (post-smoother) same as down solver (pre-smoother)
>> type: mpiaij
>> rows=480, cols=480
>> using I-node (on process 0) routines: found 160 nodes, limit
>> used is 5
>> KSP solver for S = A11 - A10 inv(A00) A01
>> KSP Object: (fieldsplit_1_) 1 MPI processes
>> type: preonly
>> PC Object: (fieldsplit_1_) 1 MPI processes
>> type: bjacobi
>> Local solver is the same for all blocks, as in the following
>> KSP Object: (fieldsplit_1_sub_) 1 MPI processes
>> type: preonly
>> PC Object: (fieldsplit_1_sub_) 1 MPI processes
>> type: bjacobi
>> KSP Object: (fieldsplit_1_sub_sub_)
>> 1 MPI processes
>> type: preonly
>> divergence=10000.
>> PC Object: (fieldsplit_1_sub_sub_)
>> 1 MPI processes
>> type: ilu
>> 0 levels of fill
>> matrix ordering: natural
>> factor fill ratio given 1., needed 1.
>> type: seqaij
>> rows=144, cols=144
>> total: nonzeros=240, allocated nonzeros=240
>> not using I-node routines
>> type: seqaij
>> rows=144, cols=144
>> calls=0
>> type: mpiaij
>> rows=144, cols=144
>> not using I-node (on process 0) routines
>> linear system matrix followed by preconditioner matrix:
>> Mat Object: (fieldsplit_1_) 1 MPI processes
>> type: schurcomplement
>> rows=144, cols=144
>> Schur complement A11 - A10 inv(A00) A01
>> A11
>> type: mpiaij
>> rows=144, cols=144
>> A10
>> type: mpiaij
>> rows=144, cols=480
>> total: nonzeros=48, allocated nonzeros=48
>> using I-node (on process 0) routines: found 74 nodes,
>> limit used is 5
>> KSP of A00
>> type: preonly
>> divergence=10000.
>> type: gamg
>> each level =
>> specified = 1.
>> type: preonly
>> divergence=10000.
>> type: bjacobi
>> processes
>> type: preonly
>> divergence=10000.
>> processes
>> type: lu
>> pivot [INBLOCKS]
>> matrix ordering: nd
>> type: seqaij
>> rows=8, cols=8
>> limit used is 5
>> type: seqaij
>> rows=8, cols=8
>> calls=0
>> used is 5
>> type: mpiaij
>> rows=8, cols=8
>> calls=0
>> type: chebyshev
>> 1.09796
>> 0.998145
>> [0. 0.1; 0. 1.1]
>> MPI processes
>> type: gmres
>> Gram-Schmidt Orthogonalization with no iterative refinement
>> divergence=10000.
>> test
>> divergence=10000.
>> type: sor
>> iterations = 1, omega = 1.
>> type: mpiaij
>> rows=480, cols=480
>> calls=0
>> (pre-smoother)
>> type: mpiaij
>> rows=480, cols=480
>> A01
>> type: mpiaij
>> rows=480, cols=144
>> using I-node (on process 0) routines: found 135 nodes,
>> limit used is 5
>> type: mpiaij
>> rows=144, cols=144
>> type: mpiaij
>> rows=624, cols=624
>> total: nonzeros=25536, allocated nonzeros=25536
>> using I-node (on process 0) routines: found 336 nodes, limit used
>> is 5
>> Thanks,
>> Xiaofeng
>> On Jun 17, 2025, at 19:05, Mark Adams <mfadams at lbl.gov> wrote:
>> And don't use -pc_gamg_parallel_coarse_grid_solver
>> You can use that in production but for debugging use -mg_coarse_pc_type
>> svd
>> Also, use -options_left and remove anything that is not used.
>> (I am puzzled, I see -pc_type gamg not -pc_type fieldsplit)
>> Mark
>> On Mon, Jun 16, 2025 at 6:40 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sun, Jun 15, 2025 at 9:46 PM hexioafeng <hexiaofeng at buaa.edu.cn>
>>> wrote:
>>>> Hello,
>>>> Here are the options and outputs:
>>>> options:
>>>> -ksp_type cg -pc_type gamg -pc_gamg_parallel_coarse_grid_solver
>>>> -pc_fieldsplit_detect_saddle_point -pc_fieldsplit_type schur
>>>> -fieldsplit_1_mat_schur_complement_ainv_type lump
>>>> -fieldsplit_0_pc_type gamg -fieldsplit_0_mg_coarse_pc_type_type svd
>>>> -fieldsplit_1_sub_pc_type sor -ksp_view -ksp_monitor_true_residual
>>>> -ksp_converged_reason -fieldsplit_0_mg_levels_ksp_monitor_true_residual
>>> This option was wrong:
>>> from the output, we can see that it should have been
>>> THanks,
>>> Matt
>>>> output:
>>>> type: cg
>>>> type: gamg
>>>> Threshold for dropping small values in graph on each level =
>>>> Complexity: grid = 1.00176
>>>> KSP Object: (mg_coarse_) 1 MPI processes
>>>> type: preonly
>>>> PC Object: (mg_coarse_) 1 MPI processes
>>>> type: bjacobi
>>>> KSP Object: (mg_coarse_sub_) 1 MPI processes
>>>> type: preonly
>>>> PC Object: (mg_coarse_sub_) 1 MPI processes
>>>> type: lu
>>>> [INBLOCKS]
>>>> matrix ordering: nd
>>>> type: seqaij
>>>> rows=7, cols=7
>>>> total: nonzeros=45, allocated nonzeros=45
>>>> type: seqaij
>>>> rows=7, cols=7
>>>> type: mpiaij
>>>> rows=7, cols=7
>>>> using I-node (on process 0) routines: found 3 nodes, limit
>>>> used is 5
>>>> Down solver (pre-smoother) on level 1 -------------------------------
>>>> KSP Object: (mg_levels_1_) 1 MPI processes
>>>> type: chebyshev
>>>> eigenvalue estimates used: min = 0., max = 0.
>>>> eigenvalues estimate via gmres min 0., max 0.
>>>> eigenvalues estimated using gmres with translations [0. 0.1;
>>>> 0. 1.1]
>>>> KSP Object: (mg_levels_1_esteig_) 1 MPI processes
>>>> type: gmres
>>>> tolerances: relative=1e-12, absolute=1e-50, divergence=10000.
>>>> PC Object: (mg_levels_1_) 1 MPI processes
>>>> type: sor
>>>> 1, omega = 1.
>>>> type: mpiaij
>>>> rows=624, cols=624
>>>> limit used is 5
>>>> type: sor
>>>> type = local_symmetric, iterations = 1, local iterations = 1,
>>>> omega = 1. linear system matrix = precond matrix:
>>>> type: mpiaij
>>>> rows=624, cols=624
>>>> used is 5 Up solver (post-smoother) same as down solver (pre-smoother)
>>>> type: mpiaij
>>>> rows=624, cols=624
>>>> is 5
>>>> Best regards,
>>>> Xiaofeng
>>>> On Jun 14, 2025, at 07:28, Barry Smith <bsmith at petsc.dev> wrote:
>>>> Matt,
>>>> Perhaps we should add options -ksp_monitor_debug and
>>>> -snes_monitor_debug that turn on all possible monitoring for the (possibly)
>>>> nested solvers and all of their converged reasons also? Note this is not
>>>> completely trivial because each preconditioner will have to supply its list
>>>> based on the current solver options for it.
>>>> Then we won't need to constantly list a big string of problem
>>>> specific monitor options to ask the user to use.
>>>> Barry
>>>> On Jun 13, 2025, at 9:09 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Thu, Jun 12, 2025 at 10:55 PM hexioafeng <hexiaofeng at buaa.edu.cn>
>>>> wrote:
>>>>> Dear authors,
>>>>> I tried *-pc_type game -pc_gamg_parallel_coarse_grid_solver* and *-pc_type
>>>>> field split -pc_fieldsplit_detect_saddle_point -fieldsplit_0_ksp_type
>>>>> pronely -fieldsplit_0_pc_type game -fieldsplit_0_mg_coarse_pc_type sad
>>>>> -fieldsplit_1_ksp_type pronely -fieldsplit_1_pc_type Jacobi
>>>>> _fieldsplit_1_sub_pc_type for* , both options got the
>>>>> KSP_DIVERGE_PC_FAILED error.
>>>> With any question about convergence, we need to see the output of
>>>> -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
>>>> -fieldsplit_1_ksp_monitor_true_residual -fieldsplit_1_ksp_converged_reason
>>>> and all the error output.
>>>> Thanks,
>>>> Matt
>>>>> Thanks,
>>>>> Xiaofeng
>>>>> On Jun 12, 2025, at 20:50, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> On Thu, Jun 12, 2025 at 8:44 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Thu, Jun 12, 2025 at 4:58 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> Adding this to the PETSc mailing list,
>>>>>>> On Thu, Jun 12, 2025 at 3:43 AM hexioafeng <hexiaofeng at buaa.edu.cn>
>>>>>>> wrote:
>>>>>>>> Dear Professor,
>>>>>>>> I hope this message finds you well.
>>>>>>>> I am an employee at a CAE company and a heavy user of the PETSc
>>>>>>>> library. I would like to thank you for your contributions to PETSc and
>>>>>>>> express my deep appreciation for your work.
>>>>>>>> Recently, I encountered some difficulties when using PETSc to solve
>>>>>>>> structural mechanics problems with Lagrange multiplier constraints. After
>>>>>>>> searching extensively online and reviewing several papers, I found your
>>>>>>>> previous paper titled "*Algebraic multigrid methods for
>>>>>>>> constrained linear systems with applications to contact problems in solid
>>>>>>>> mechanics*" seems to be the most relevant and helpful.
>>>>>>>> The stiffness matrix I'm working with, *K*, is a block
>>>>>>>> saddle-point matrix of the form (A00 A01; A10 0), where *A00 is
>>>>>>>> singular*—just as described in your paper, and different from many
>>>>>>>> other articles . I have a few questions regarding your work and would
>>>>>>>> greatly appreciate your insights:
>>>>>>>> 1. Is the *AMG/KKT* method presented in your paper available in
>>>>>>>> PETSc? I tried using *CG+GAMG* directly but received a
>>>>>>>> *KSP_DIVERGED_PC_FAILED* error. I also attempted to use
>>>>>>>> *CG+PCFIELDSPLIT* with the following options:
>>>>>>> No
>>>>>>>> -fieldsplit_0_pc_type gamg -fieldsplit_1_ksp_type preonly
>>>>>>>> Unfortunately, this also resulted in a *KSP_DIVERGED_PC_FAILED* error.
>>>>>>>> Do you have any suggestions?
>>>>>>>> 2. In your paper, you compare the method with *Uzawa*-type
>>>>>>>> approaches. To my understanding, Uzawa methods typically require A00 to be
>>>>>>>> invertible. How did you handle the singularity of A00 to construct an
>>>>>>>> M-matrix that is invertible?
>>>>>>> You add a regularization term like A01 * A10 (like springs). See the
>>>>>>> paper or any reference to augmented lagrange or Uzawa
>>>>>>> 3. Can i implement the AMG/KKT method in your paper using existing *AMG
>>>>>>>> APIs*? Implementing a production-level AMG solver from scratch
>>>>>>>> would be quite challenging for me, so I’m hoping to utilize existing AMG
>>>>>>>> interfaces within PETSc or other packages.
>>>>>>> You can do Uzawa and make the regularization matrix with
>>>>>>> matrix-matrix products. Just use AMG for the A00 block.
>>>>>>>> 4. For saddle-point systems where A00 is singular, can you
>>>>>>>> recommend any more robust or efficient solutions? Alternatively, are you
>>>>>>>> aware of any open-source software packages that can handle such cases
>>>>>>>> out-of-the-box?
>>>>>>> No, and I don't think PETSc can do this out-of-the-box, but others
>>>>>>> may be able to give you a better idea of what PETSc can do.
>>>>>>> I think PETSc can do Uzawa or other similar algorithms but it will
>>>>>>> not do the regularization automatically (it is a bit more complicated than
>>>>>>> just A01 * A10)
>>>>>> One other trick you can use is to have
>>>>>> -fieldsplit_0_mg_coarse_pc_type svd
>>>>>> This will use SVD on the coarse grid of GAMG, which can handle the
>>>>>> null space in A00 as long as the prolongation does not put it back in. I
>>>>>> have used this for the Laplacian with Neumann conditions and for freely
>>>>>> floating elastic problems.
>>>>> Good point.
>>>>> You can also use -pc_gamg_parallel_coarse_grid_solver to get GAMG to
>>>>> use a on level iterative solver for the coarse grid.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Thanks,
>>>>>>> Mark
>>>>>>>> Thank you very much for taking the time to read my email. Looking
>>>>>>>> forward to hearing from you.
>>>>>>>> Sincerely,
>>>>>>>> Xiaofeng He
>>>>>>>> Research Engineer
>>>>>>>> Internet Based Engineering, Beijing, China
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!b073klPm2VmdcoyZSanTzrb7QKM0FLY76BIb6aSF6UzIRqOnap2eiE5edCKKSGWHd5jcpBqQi9rBidaVTxD5$
>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!f-YJSzthRa7atIa1xs1GPHW53hGIqSenvp1eO2kDsSyf4jv1_Vp0kL9Lg8pyyPeG8al4Im8XlLqGRHw1FxYh$>
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dYETsi-moODALE1tmLrk5pxFKF9l552nNiC0cBgsCQ9ebugJWHtsNYa0QBS5Gmws9J_VC_Iec3Nx0c1FgNl1$>
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!b073klPm2VmdcoyZSanTzrb7QKM0FLY76BIb6aSF6UzIRqOnap2eiE5edCKKSGWHd5jcpBqQi9rBiVLBZdhs$ >
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!b073klPm2VmdcoyZSanTzrb7QKM0FLY76BIb6aSF6UzIRqOnap2eiE5edCKKSGWHd5jcpBqQi9rBidaVTxD5$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!b073klPm2VmdcoyZSanTzrb7QKM0FLY76BIb6aSF6UzIRqOnap2eiE5edCKKSGWHd5jcpBqQi9rBiVLBZdhs$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250619/07651414/attachment-0001.html>
