[petsc-users] Questions Regarding PETSc and Solving Constrained Structural Mechanics Problems
Mark Adams mfadams at lbl.gov
Tue Jun 17 06:05:52 CDT 2025
And don't use -pc_gamg_parallel_coarse_grid_solver
You can use that in production but for debugging use -mg_coarse_pc_type svd
Also, use -options_left and remove anything that is not used.
(I am puzzled, I see -pc_type gamg not -pc_type fieldsplit)
On Mon, Jun 16, 2025 at 6:40 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Jun 15, 2025 at 9:46 PM hexioafeng <hexiaofeng at buaa.edu.cn> wrote:
>> Hello,
>> Here are the options and outputs:
>> options:
>> -ksp_type cg -pc_type gamg -pc_gamg_parallel_coarse_grid_solver
>>  -pc_fieldsplit_detect_saddle_point  -pc_fieldsplit_type schur
>> -pc_fieldsplit_schur_precondition selfp
>> -fieldsplit_1_mat_schur_complement_ainv_type lump
>> -pc_fieldsplit_schur_fact_type full -fieldsplit_0_ksp_type preonly
>> -fieldsplit_0_pc_type gamg -fieldsplit_0_mg_coarse_pc_type_type svd
>> -fieldsplit_1_ksp_type preonly -fieldsplit_1_pc_type bjacobi
>> -fieldsplit_1_sub_pc_type sor -ksp_view  -ksp_monitor_true_residual
>>  -ksp_converged_reason  -fieldsplit_0_mg_levels_ksp_monitor_true_residual
>>  -fieldsplit_0_mg_levels_ksp_converged_reason
>>  -fieldsplit_1_ksp_monitor_true_residual
>>  -fieldsplit_1_ksp_converged_reason
> This option was wrong:
> from the output, we can see that it should have been
>   -fieldsplit_0_mg_coarse_sub_pc_type_type svd
>   THanks,
>      Matt
>> output:
>> 0 KSP unpreconditioned resid norm 2.777777777778e+01 true resid norm
>> 2.777777777778e+01 ||r(i)||/||b|| 1.000000000000e+00
>> Linear solve did not converge due to DIVERGED_PC_FAILED iterations 0
>>                PC failed due to SUBPC_ERROR
>> KSP Object: 1 MPI processes
>>   type: cg
>>   maximum iterations=200, initial guess is zero
>>   tolerances:  relative=1e-06, absolute=1e-12, divergence=1e+30
>>   left preconditioning
>>   using UNPRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>>   type: gamg
>>     type is MULTIPLICATIVE, levels=2 cycles=v
>>       Cycles per PCApply=1
>>       Using externally compute Galerkin coarse grid matrices
>>       GAMG specific options
>>         Threshold for dropping small values in graph on each level =
>>         Threshold scaling factor for each level not specified = 1.
>>         AGG specific options
>>           Symmetric graph false
>>           Number of levels to square graph 1
>>           Number smoothing steps 1
>>         Complexity:    grid = 1.00176
>>   Coarse grid solver -- level -------------------------------
>>     KSP Object: (mg_coarse_) 1 MPI processes
>>       type: preonly
>>       maximum iterations=10000, initial guess is zero
>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>       using NONE norm type for convergence test
>>     PC Object: (mg_coarse_) 1 MPI processes
>>       type: bjacobi
>>         number of blocks = 1
>>         Local solver is the same for all blocks, as in the following KSP
>> and PC objects on rank 0:
>>       KSP Object: (mg_coarse_sub_) 1 MPI processes
>>         type: preonly
>>         maximum iterations=1, initial guess is zero
>>       PC Object: (mg_coarse_sub_) 1 MPI processes
>>         type: lu
>>           out-of-place factorization
>>           tolerance for zero pivot 2.22045e-14
>>           using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>>           matrix ordering: nd
>>           factor fill ratio given 5., needed 1.
>>             Factored matrix follows:
>>               Mat Object: 1 MPI processes
>>                 type: seqaij
>>                 rows=7, cols=7
>>                 package used to perform factorization: petsc
>>                 total: nonzeros=45, allocated nonzeros=45
>>                   using I-node routines: found 3 nodes, limit used is 5
>>         linear system matrix = precond matrix:
>>           type: seqaij
>>           rows=7, cols=7
>>           total number of mallocs used during MatSetValues calls=0
>>         type: mpiaij
>>         rows=7, cols=7
>>           using nonscalable MatPtAP() implementation
>>           using I-node (on process 0) routines: found 3 nodes, limit used
>> is 5
>>   Down solver (pre-smoother) on level 1 -------------------------------
>>     KSP Object: (mg_levels_1_) 1 MPI processes
>>       type: chebyshev
>>         eigenvalue estimates used:  min = 0., max = 0.
>>         eigenvalues estimate via gmres min 0., max 0.
>>         eigenvalues estimated using gmres with translations  [0. 0.1; 0.
>> 1.1]
>>         KSP Object: (mg_levels_1_esteig_) 1 MPI processes
>>           type: gmres
>>             restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>             happy breakdown tolerance 1e-30
>>           maximum iterations=10, initial guess is zero
>>           tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
>>           using PRECONDITIONED norm type for convergence test
>>         PC Object: (mg_levels_1_) 1 MPI processes
>>           type: sor
>>             type = local_symmetric, iterations = 1, local iterations = 1,
>> omega = 1.
>>             type: mpiaij
>>             rows=624, cols=624
>>             total: nonzeros=25536, allocated nonzeros=25536
>>               using I-node (on process 0) routines: found 336 nodes,
>> limit used is 5
>>         estimating eigenvalues using noisy right hand side
>>       maximum iterations=2, nonzero initial guess
>>       type: sor
>> omega = 1.      linear system matrix = precond matrix:
>>         type: mpiaij
>>         rows=624, cols=624
>>           using I-node (on process 0) routines: found 336 nodes, limit
>> used is 5  Up solver (post-smoother) same as down solver (pre-smoother)
>>     type: mpiaij
>>     rows=624, cols=624
>>       using I-node (on process 0) routines: found 336 nodes, limit used
>> is 5
>> Best regards,
>> Xiaofeng
>> On Jun 14, 2025, at 07:28, Barry Smith <bsmith at petsc.dev> wrote:
>>   Matt,
>>    Perhaps we should add options -ksp_monitor_debug and
>> -snes_monitor_debug that turn on all possible monitoring for the (possibly)
>> nested solvers and all of their converged reasons also? Note this is not
>> completely trivial because each preconditioner will have to supply its list
>> based on the current solver options for it.
>>    Then we won't need to constantly list a big string of problem specific
>> monitor options to ask the user to use.
>>   Barry
>> On Jun 13, 2025, at 9:09 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jun 12, 2025 at 10:55 PM hexioafeng <hexiaofeng at buaa.edu.cn>
>> wrote:
>>> Dear authors,
>>> I tried *-pc_type game -pc_gamg_parallel_coarse_grid_solver* and *-pc_type
>>> field split -pc_fieldsplit_detect_saddle_point -fieldsplit_0_ksp_type
>>> pronely -fieldsplit_0_pc_type game -fieldsplit_0_mg_coarse_pc_type sad
>>> -fieldsplit_1_ksp_type pronely -fieldsplit_1_pc_type Jacobi
>>> _fieldsplit_1_sub_pc_type for* , both options got the
>>> KSP_DIVERGE_PC_FAILED error.
>> With any question about convergence, we need to see the output of
>>   -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
>> -fieldsplit_1_ksp_monitor_true_residual -fieldsplit_1_ksp_converged_reason
>> and all the error output.
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Xiaofeng
>>> On Jun 12, 2025, at 20:50, Mark Adams <mfadams at lbl.gov> wrote:
>>> On Thu, Jun 12, 2025 at 8:44 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Jun 12, 2025 at 4:58 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> Adding this to the PETSc mailing list,
>>>>> On Thu, Jun 12, 2025 at 3:43 AM hexioafeng <hexiaofeng at buaa.edu.cn>
>>>>> wrote:
>>>>>> Dear Professor,
>>>>>> I hope this message finds you well.
>>>>>> I am an employee at a CAE company and a heavy user of the PETSc
>>>>>> library. I would like to thank you for your contributions to PETSc and
>>>>>> express my deep appreciation for your work.
>>>>>> Recently, I encountered some difficulties when using PETSc to solve
>>>>>> structural mechanics problems with Lagrange multiplier constraints. After
>>>>>> searching extensively online and reviewing several papers, I found your
>>>>>> previous paper titled "*Algebraic multigrid methods for constrained
>>>>>> linear systems with applications to contact problems in solid mechanics*"
>>>>>> seems to be the most relevant and helpful.
>>>>>> The stiffness matrix I'm working with, *K*, is a block saddle-point
>>>>>> matrix of the form (A00 A01; A10 0), where *A00 is singular*—just as
>>>>>> described in your paper, and different from many other articles . I have a
>>>>>> few questions regarding your work and would greatly appreciate your
>>>>>> insights:
>>>>>> 1. Is the *AMG/KKT* method presented in your paper available in
>>>>>> PETSc? I tried using *CG+GAMG* directly but received a
>>>>>> *KSP_DIVERGED_PC_FAILED* error. I also attempted to use
>>>>>> *CG+PCFIELDSPLIT* with the following options:
>>>>> No
>>>>>>     -pc_type fieldsplit -pc_fieldsplit_detect_saddle_point
>>>>>> -pc_fieldsplit_type schur -pc_fieldsplit_schur_precondition selfp
>>>>>> -fieldsplit_0_pc_type gamg -fieldsplit_1_ksp_type preonly
>>>>>>    Unfortunately, this also resulted in a *KSP_DIVERGED_PC_FAILED* error.
>>>>>> Do you have any suggestions?
>>>>>> 2. In your paper, you compare the method with *Uzawa*-type
>>>>>> approaches. To my understanding, Uzawa methods typically require A00 to be
>>>>>> invertible. How did you handle the singularity of A00 to construct an
>>>>>> M-matrix that is invertible?
>>>>> You add a regularization term like A01 * A10 (like springs). See the
>>>>> paper or any reference to augmented lagrange or Uzawa
>>>>> 3. Can i implement the AMG/KKT method in your paper using existing *AMG
>>>>>> APIs*? Implementing a production-level AMG solver from scratch would
>>>>>> be quite challenging for me, so I’m hoping to utilize existing AMG
>>>>>> interfaces within PETSc or other packages.
>>>>> You can do Uzawa and make the regularization matrix with matrix-matrix
>>>>> products. Just use AMG for the A00 block.
>>>>>> 4. For saddle-point systems where A00 is singular, can you recommend
>>>>>> any more robust or efficient solutions? Alternatively, are you aware of any
>>>>>> open-source software packages that can handle such cases out-of-the-box?
>>>>> No, and I don't think PETSc can do this out-of-the-box, but others may
>>>>> be able to give you a better idea of what PETSc can do.
>>>>> I think PETSc can do Uzawa or other similar algorithms but it will not
>>>>> do the regularization automatically (it is a bit more complicated than just
>>>>> A01 * A10)
>>>> One other trick you can use is to have
>>>>   -fieldsplit_0_mg_coarse_pc_type svd
>>>> This will use SVD on the coarse grid of GAMG, which can handle the null
>>>> space in A00 as long as the prolongation does not put it back in. I have
>>>> used this for the Laplacian with Neumann conditions and for freely floating
>>>> elastic problems.
>>> Good point.
>>> You can also use -pc_gamg_parallel_coarse_grid_solver to get GAMG to use
>>> a on level iterative solver for the coarse grid.
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks,
>>>>> Mark
>>>>>> Thank you very much for taking the time to read my email. Looking
>>>>>> forward to hearing from you.
>>>>>> Sincerely,
>>>>>> Xiaofeng He
>>>>>> Research Engineer
>>>>>> Internet Based Engineering, Beijing, China
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fyBp94uNH39ug71rmxdPNy-fg09OxzGTv8H1_ulFiPksc9CZAblBrgYK7D2QWSJMYv-jihmxWTifwLLc1Sn2DSo$
>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!f-YJSzthRa7atIa1xs1GPHW53hGIqSenvp1eO2kDsSyf4jv1_Vp0kL9Lg8pyyPeG8al4Im8XlLqGRHw1FxYh$>
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dYETsi-moODALE1tmLrk5pxFKF9l552nNiC0cBgsCQ9ebugJWHtsNYa0QBS5Gmws9J_VC_Iec3Nx0c1FgNl1$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250617/0b72f4dc/attachment-0001.html>
