[petsc-users] dmplex, triangle and generating unstructured mesh
Nicolas Barral
nicolas.barral at math.u-bordeaux.fr
Mon Jun 16 06:37:36 CDT 2025
On 14/06/2025 18:45, Steven Dargaville wrote:
> Hi, I'm just wondering if it is possible to generate a simple
> unstructured mesh in 2D with DMPlex and one of the external generators,
> like triangle?
> I'm running snes/tutorials/ex20 which uses triangle and I can only seem
> to generate structured triangular meshes. It is a simple 2D box so it
> makes sense a Delaunay might output a structured mesh in that case. I
> know I could get the DM to read in an unstructured mesh from a file that
> I have previously generated, but for ease I'm wondering if this can be
> done directly.
> I've tried a few different things to try and force an unstructured mesh
> being generated, like changing the number of faces to 1 (-
> dm_plex_box_faces 1,1) so it only sees the corners of the box domain.
> I've also tried to set some of the options to triangle with
> DMPlexTriangleSetOptions but that doesn't seem to have any effect, so
> I'm guessing I'm potentially not using it correctly (and I can't seem to
> find any examples that use this function to help).
> Anyone have any suggestions? Thanks for your help
I don't know how the mesh is generated, but a workaround would be to
generate a coarse mesh then use the adaptive remeshing functions (e.g.
with MMG) - with a uniform metric if you want a uniform mesh.
plex/tests/ex19 should show how it works.
Thanks
Nicolas
> Steven
