[petsc-users] Insertion mode for Scatter
SCOTTO Alexandre alexandre.scotto at irt-saintexupery.com
Mon Jun 16 01:24:50 CDT 2025
Hello Pierre,
My example is indeed not very relevant for scattering, but in practice I have vectors of same global size but distributed differently over the processes, and I need to transfer the whole data from one vector to the other.
In this case, I think that the solution below may be reasonably efficient.
Alexandre.
De : Pierre Jolivet <pierre at joliv.et>
Envoyé : vendredi 13 juin 2025 11:59
À : SCOTTO Alexandre <alexandre.scotto at irt-saintexupery.com>
Cc : petsc-users at mcs.anl.gov
Objet : Re: [petsc-users] Insertion mode for Scatter
Please always keep the list in copy.
On 13 Jun 2025, at 11:55 AM, SCOTTO Alexandre <alexandre.scotto at irt-saintexupery.com<mailto:alexandre.scotto at irt-saintexupery.com>> wrote:
Hello Pierre,
Thank you for you answer.
I think I see the subtlety here, and it makes realized that I have not properly understood yet how index sets should be manipulated, in particular whether the provided indices are local or global.
It seems that this code solves my issue:
index_set_1 = PETSc.IS().createStride(
    vec_1.local_size, first=vec_1.owner_range[0], step=1
index_set_2 = PETSc.IS().createStride(
    vec_2.local_size, first=vec_2.owner_range[0], step=1
scatter = PETSc.Scatter().create(vec_1, index_set_1, vec_2, index_set_2)
scatter.scatter(vec_1, vec_2, addv=True)
Do you think that this is a decent manner of transfering the whole content of a vector to another of same dimension?
I have a lot of this scattering to perform so if you have a better recommendation I would be pleased.
The “scattering” you are defining and using is basically a VecAXPY(), so using a scatter for such an operation is definitely _not_ the way to go.
Pierre
Best regards,
Alexandre.
De : Pierre Jolivet <pierre at joliv.et<mailto:pierre at joliv.et>>
Envoyé : vendredi 13 juin 2025 11:43
À : SCOTTO Alexandre <alexandre.scotto at irt-saintexupery.com<mailto:alexandre.scotto at irt-saintexupery.com>>
Cc : petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On 13 Jun 2025, at 11:32 AM, SCOTTO Alexandre via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Dear PETSc community,
I am currently struggling with the ADD_VALUE mode of the Scatter object. Here is a simple piece of (Python) code to illustrate the issue:
vec_1 = PETSc.Vec().createMPI(size=10)
vec_1.shift(2.0)
vec_2 = PETSc.Vec().createMPI(size=10)
vec_2.shift(1.0)
index_set = PETSc.IS().createStride(10, step=1)
scatter = PETSc.Scatter().create(vec_1, index_set, vec_2, index_set)
Vectors vec_1 and vec_2 are respectively filled-in with 2.0 and 1.0. After the scattering, I would expect to have in vec_2 the sum of the values initially in vec_2 (that is  1.0) plus the values coming from vec_1 (that is 2.0).
But instead of having vec_2 filled in with 3.0 it is filled-in with 9.0. My understanding is that the number of processes (here 4 processes) plays a role since 9.0 = 1.0 (initial value) + 2.0 (values coming from vec_1) x 4 (number of processes).
Is there a way to have simply 3.0 as a result?
With the index_set you are supplying, you are basically saying that each process should scatter the complete vector (not just its local portion).
If you use an index_set which does not induce communication (e.g., of size the local size of the Vec and with the same start as the first local row of the Vec), then you’ll get 3.0 as a result.
Pierre
Hoping to have been clear enough, best regards,
Alexandre.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250616/a3d20823/attachment-0001.html>
