[petsc-users] Nodes added to Vertex Set
Noam T. dontbugthedevs at proton.me
Thu Jun 12 16:19:40 CDT 2025
I might be able to answer myself.
in the $Nodes section, the mid-face nodes are included with dimension 2 a.k.a faces; e.g. the ninth node
2 6 0 1 <-- 2 is the element dimension, 6 is the tag
9
0.5 0.5 1.0
So when creating groups for the surfaces, these nodes are also included into their own physical groups, which PETSc adds into Vertex Sets.
I don't quite get why these nodes have dimension 2, but that's probably a gmsh-related question.
On Thursday, June 12th, 2025 at 7:08 PM, Noam T. <dontbugthedevs at proton.me> wrote:
> Hello,
> In the mesh attached, a 1x1x1 cube with 8 nodes, physical groups are defined for the 6 bounding faces only. According to the GUI, and looking at the MSH file in $Entities, there are no physical groups for nodes.
> Using the following code:
> #include <stdio.h>
> #include <petscdmplex.h>
> int main(int argc, char *argv[]) {
> DM dm;
> PetscInt v;
> PetscCall(PetscInitialize(&argc, &argv, NULL, NULL));
> PetscCall(PetscOptionsInsertString(NULL, " -dm_plex_gmsh_mark_vertices "));
> PetscCall(DMPlexCreateFromFile(PETSC_COMM_WORLD, "mesh.msh", "test", PETSC_TRUE, &dm));
> PetscCall(DMGetLabelSize(dm, "Vertex Sets", &v));
> printf("\nVertex set size %d\n", v);
> PetscCall(PetscFinalize());
> it says "Vertex Sets" has size 6, with IS [1, 2, 3, 4, 5, 6]. Is that intended behavior? Up until now I relied on having an empty set whenever physical tags where not explicitly defined, but this one mesh seems to be an exception.
> Thanks.
> Noam
> PS: The size is v = 0 when removing the flag "-dm_plex_gmsh_mark_vertices".
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250612/de09fc93/attachment.html>
