[petsc-users] Questions Regarding PETSc and Solving Constrained Structural Mechanics Problems
Mark Adams
mfadams at lbl.gov
Thu Jun 12 07:50:51 CDT 2025
On Thu, Jun 12, 2025 at 8:44 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jun 12, 2025 at 4:58 AM Mark Adams <mfadams at lbl.gov> wrote:
>> Adding this to the PETSc mailing list,
>> On Thu, Jun 12, 2025 at 3:43 AM hexioafeng <hexiaofeng at buaa.edu.cn>
>> wrote:
>>> Dear Professor,
>>> I hope this message finds you well.
>>> I am an employee at a CAE company and a heavy user of the PETSc library.
>>> I would like to thank you for your contributions to PETSc and express my
>>> deep appreciation for your work.
>>> Recently, I encountered some difficulties when using PETSc to solve
>>> structural mechanics problems with Lagrange multiplier constraints. After
>>> searching extensively online and reviewing several papers, I found your
>>> previous paper titled "*Algebraic multigrid methods for constrained
>>> linear systems with applications to contact problems in solid mechanics*"
>>> seems to be the most relevant and helpful.
>>> The stiffness matrix I'm working with, *K*, is a block saddle-point
>>> matrix of the form (A00 A01; A10 0), where *A00 is singular*—just as
>>> described in your paper, and different from many other articles . I have a
>>> few questions regarding your work and would greatly appreciate your
>>> insights:
>>> 1. Is the *AMG/KKT* method presented in your paper available in PETSc?
>>> I tried using *CG+GAMG* directly but received a *KSP_DIVERGED_PC_FAILED*
>>> error. I also attempted to use *CG+PCFIELDSPLIT* with the following
>>> options:
>> No
>>> -pc_type fieldsplit -pc_fieldsplit_detect_saddle_point
>>> -pc_fieldsplit_type schur -pc_fieldsplit_schur_precondition selfp
>>> -pc_fieldsplit_schur_fact_type full -fieldsplit_0_ksp_type preonly
>>> -fieldsplit_0_pc_type gamg -fieldsplit_1_ksp_type preonly
>>> -fieldsplit_1_pc_type bjacobi
>>> Unfortunately, this also resulted in a *KSP_DIVERGED_PC_FAILED*
>>> error. Do you have any suggestions?
>>> 2. In your paper, you compare the method with *Uzawa*-type approaches.
>>> To my understanding, Uzawa methods typically require A00 to be invertible.
>>> How did you handle the singularity of A00 to construct an M-matrix that is
>>> invertible?
>> You add a regularization term like A01 * A10 (like springs). See the
>> paper or any reference to augmented lagrange or Uzawa
>> 3. Can i implement the AMG/KKT method in your paper using existing *AMG
>>> APIs*? Implementing a production-level AMG solver from scratch would be
>>> quite challenging for me, so I’m hoping to utilize existing AMG interfaces
>>> within PETSc or other packages.
>> You can do Uzawa and make the regularization matrix with matrix-matrix
>> products. Just use AMG for the A00 block.
>>> 4. For saddle-point systems where A00 is singular, can you recommend any
>>> more robust or efficient solutions? Alternatively, are you aware of any
>>> open-source software packages that can handle such cases out-of-the-box?
>> No, and I don't think PETSc can do this out-of-the-box, but others may be
>> able to give you a better idea of what PETSc can do.
>> I think PETSc can do Uzawa or other similar algorithms but it will not do
>> the regularization automatically (it is a bit more complicated than just
>> A01 * A10)
> One other trick you can use is to have
> -fieldsplit_0_mg_coarse_pc_type svd
> This will use SVD on the coarse grid of GAMG, which can handle the null
> space in A00 as long as the prolongation does not put it back in. I have
> used this for the Laplacian with Neumann conditions and for freely floating
> elastic problems.
Good point.
You can also use -pc_gamg_parallel_coarse_grid_solver to get GAMG to use a
on level iterative solver for the coarse grid.
> Thanks,
> Matt
>> Thanks,
>> Mark
>>> Thank you very much for taking the time to read my email. Looking
>>> forward to hearing from you.
>>> Sincerely,
>>> Xiaofeng He
>>> Research Engineer
>>> Internet Based Engineering, Beijing, China
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cOziFPTYQhj3Q2QdRoQiCJ__wU-JwGk5zFk_C1QziJVJ9_DiXgLkG5d2QpCFzatvJgHtMFVSUfYjbKrho9pJS8A$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cOziFPTYQhj3Q2QdRoQiCJ__wU-JwGk5zFk_C1QziJVJ9_DiXgLkG5d2QpCFzatvJgHtMFVSUfYjbKrh_nneKPA$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250612/99f12bdb/attachment-0001.html>
