[petsc-users] Memory leak related to MatSetValue
neil liu liufield at gmail.com
Mon Jun 9 21:48:46 CDT 2025
Thanks a lot for your information. Very helpful.
Have a good night.
On Mon, Jun 9, 2025 at 9:56 PM Barry Smith <bsmith at petsc.dev> wrote:
> src/mat/utils/matstash.c
> In MatStashBlockTypeSetUp()
>     PetscCallMPI(MPI_Type_create_resized(stype, 0, stash->blocktype_size,
> &stash->blocktype));
> In MatStashScatterDestroy_BTS(MatStash *stash)
>   if (stash->blocktype != MPI_DATATYPE_NULL)
> PetscCallMPI(MPI_Type_free(&stash->blocktype));
> So either
> 1) PETSc logic is preventing the correct MPI_Type_free() call from being
> made or
> 2) a bug has crept into MPICH that prevents the MPI_Type_free from freeing
> everything it needs to
> You can use the debugger (or even print statements inserted in the PETSc
> source) to determine in your very simple code
> that the MPI_Type_create_resized() is called exactly once and also the
> matching MPI_Type_free() to determine if the problem is PETSc logic or
> MPICH logic.
> Since we test PETSc in our CI with valgrind it is unlikely a PETSc bug
> Barry
> On Jun 9, 2025, at 7:47 PM, neil liu <liufield at gmail.com> wrote:
> Dear Petsc community,
> Recently, I encountered a memory leak while using Valgrind (3.25.1) with
> MPI (2 processes, MPICH 4.21.1) to test a PETSc-based code, which is a
> variant of the pestc's built-in example.
> *#include <petscksp.h>*
> *static char help[] = "Demonstrate PCFIELDSPLIT after MatZeroRowsColumns()
> inside PCREDISTRIBUTE";*
> *int main(int argc, char **argv)*
> *  PetscMPIInt rank, size;*
> *  Mat         A;*
> *  PetscCall(PetscInitialize(&argc, &argv, NULL, help));*
> *  PetscCallMPI(MPI_Comm_size(PETSC_COMM_WORLD, &size));*
> *  PetscCallMPI(MPI_Comm_rank(PETSC_COMM_WORLD, &rank));*
> *  PetscCheck(size == 2, PETSC_COMM_WORLD, PETSC_ERR_WRONG_MPI_SIZE, "Must
> be run with 2 MPI processes");*
> *  // Set up a small problem with 2 dofs on rank 0 and 4 on rank 1*
> *  PetscCall(MatCreate(PETSC_COMM_WORLD, &A));*
> *  PetscCall(MatSetSizes(A, !rank ? 2 : 4, !rank ? 2 : 4, PETSC_DETERMINE,
> PETSC_DETERMINE));*
> *  PetscCall(MatSetFromOptions(A));*
> *  if (rank == 0) {*
> *    PetscCall(MatSetValue(A, 0, 0, 2.0, ADD_VALUES));*
> *    PetscCall(MatSetValue(A, 0, 1, -1.0, ADD_VALUES));*
> *    PetscCall(MatSetValue(A, 1, 1, 3.0, ADD_VALUES));*
> *    PetscCall(MatSetValue(A, 1, 2, -1.0, ADD_VALUES));*
> *  } else if (rank == 1) {*
> *    PetscCall(MatSetValue(A, 1, 2, 40.0, ADD_VALUES));//Additional line
> added*
> *    PetscCall(MatSetValue(A, 2, 2, 4.0, ADD_VALUES));*
> *    PetscCall(MatSetValue(A, 2, 3, -1.0, ADD_VALUES));*
> *    PetscCall(MatSetValue(A, 3, 3, 5.0, ADD_VALUES));*
> *    PetscCall(MatSetValue(A, 3, 4, -1.0, ADD_VALUES));*
> *    PetscCall(MatSetValue(A, 4, 4, 6.0, ADD_VALUES));*
> *    PetscCall(MatSetValue(A, 4, 5, -1.0, ADD_VALUES));*
> *    PetscCall(MatSetValue(A, 5, 5, 7.0, ADD_VALUES));*
> *    PetscCall(MatSetValue(A, 5, 4, -0.5, ADD_VALUES));*
> *  PetscCall(MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY));*
> *  PetscCall(MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY));*
> *  PetscCall(MatView(A, PETSC_VIEWER_STDOUT_WORLD));*
> *  PetscCall(MatDestroy(&A));*
> *  PetscCall(PetscFinalize());*
> *  return 0;*
> Rank 0 and 1 own 2 (from 0 to 1) and 4 (from 2 to 5) local rows
> respectively.
> I tried to add
> *    PetscCall(MatSetValue(A, 1, 2, 40.0, ADD_VALUES));*
> for rank 1. //1 is owned by rank 0 only but is also modified in rank 1
> now.
> After adding this line, a memory leak occurred. Does this imply that we
> cannot assign values to entries owned by other processors? In my case, I am
> assembling a global matrix from a DMPlex. With overlap=0, it seems
> necessary to use MatSetValues for rows owned by other processes. I'm not
> certain whether these two scenarios are equivalent, but they both appear to
> trigger the same memory leak.
> Did I miss something?
> Thanks a lot,
> Xiaodong
> ==3932339== 96 bytes in 1 blocks are definitely lost in loss record 2 of 3
> ==3932339==    at 0x4C392E1: malloc (vg_replace_malloc.c:446)
> ==3932339==    by 0xA267A97: MPL_malloc (mpl_trmem.h:373)
> ==3932339==    by 0xA267CE4: MPIR_Datatype_set_contents
> (mpir_datatype.h:420)
> ==3932339==    by 0xA26E26E: MPIR_Type_create_struct_impl
> (type_create.c:919)
> ==3932339==    by 0xA068F45: internal_Type_create_struct
> (c_binding.c:36491)
> ==3932339==    by 0xA06911F: PMPI_Type_create_struct (c_binding.c:36551)
> ==3932339==    by 0x4E78222: PMPI_Type_create_struct (libmpiwrap.c:2752)
> ==3932339==    by 0x6F5C7D6: MatStashBlockTypeSetUp (matstash.c:772)
> ==3932339==    by 0x6F61162: MatStashScatterBegin_BTS (matstash.c:838)
> ==3932339==    by 0x6F54511: MatStashScatterBegin_Private (matstash.c:437)
> ==3932339==    by 0x60BA9BD: MatAssemblyBegin_MPI_Hash (mpihashmat.h:59)
> ==3932339==    by 0x6E8D3AE: MatAssemblyBegin (matrix.c:5749)
> ==3932339==
> ==3932339== 96 bytes in 1 blocks are definitely lost in loss record 3 of 3
> ==3932339==    by 0xA2385FF: MPL_malloc (mpl_trmem.h:373)
> ==3932339==    by 0xA2395F8: MPII_Dataloop_alloc_and_copy (dataloop.c:400)
> ==3932339==    by 0xA2393DC: MPII_Dataloop_alloc (dataloop.c:319)
> ==3932339==    by 0xA23B239: MPIR_Dataloop_create_contiguous
> (dataloop_create_contig.c:56)
> ==3932339==    by 0xA23BFF9: MPIR_Dataloop_create_indexed
> (dataloop_create_indexed.c:89)
> ==3932339==    by 0xA23D5DC: create_basic_all_bytes_struct
> (dataloop_create_struct.c:252)
> ==3932339==    by 0xA23D178: MPIR_Dataloop_create_struct
> (dataloop_create_struct.c:146)
> ==3932339==    by 0xA25D4DB: MPIR_Typerep_commit
> (typerep_dataloop_commit.c:284)
> ==3932339==    by 0xA261549: MPIR_Type_commit_impl (datatype_impl.c:185)
> ==3932339==    by 0xA0624CA: internal_Type_commit (c_binding.c:34506)
> ==3932339==    by 0xA062679: PMPI_Type_commit (c_binding.c:34553)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250609/5bb861aa/attachment-0001.html>
