[petsc-users] Error installing PETSc with --download-f2cblaslapack
Barry Smith bsmith at petsc.dev
Fri Jun 6 18:27:41 CDT 2025
you forgot configure.log
> On Jun 6, 2025, at 7:19 PM, Blondel, Sophie <sblondel at utk.edu> wrote:
> Correct, I tried a few different python versions and mpi versions, conda is providing the external dependencies. Maybe it wrongly points to some base builds instead of the specific environment I set up.
> Best,
> Sophie
> On Jun 6, 2025 7:12 PM, Barry Smith <bsmith at petsc.dev> wrote:
>   Send configure.log
>   I assume you tried rerunning a few times? It seems like possibly a flaky filesystem problem.
>   Barry
>> On Jun 6, 2025, at 6:56 PM, Blondel, Sophie via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Hi,
>> I am getting an error when trying to install PETSc with --download-f2cblaslapack on Linux:
>>                    Installing F2CBLASLAPACK; this may take several minutes
>>            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
>>   Error moving
>>   /home/sophie/Workspace/xolotl-stable-source/external/petsc/arch-linux-c-opt/externalpackages/f2cblaslapack-3.8.0.q2
>>   libraries
>> With the error in configure.log (which is accurate, the file is not present in the folder):
>> Executing: ['mkdir', '-p', '/home/sophie/Workspace/xolotl-stable-build/external/petsc_install/lib']
>> Executing: ['cp', '-f', 'libf2clapack.a', 'libf2cblas.a', '/home/sophie/Workspace/xolotl-stable-build/external/petsc_install/lib']
>> stdout: cp: cannot stat 'libf2clapack.a': No such file or directory
>>                     Error moving /home/sophie/Workspace/xolotl-stable-source/external/petsc/arch-linux-c-opt/externalpackages/f2cblaslapack-3.8.0.q2 libraries: Could not execute "[['mkdir', '-p', '/home/sophie/Workspace/xolotl-stable-build/external/petsc_install/lib'], ['cp', '-f', 'libf2clapack.a', 'libf2cblas.a', '/home/sophie/Workspace/xolotl-stable-build/external/petsc_install/lib']]":
>> The configure command is:
>> ./configure --prefix=/home/sophie/Workspace/xolotl-stable-build/external/petsc_install --with-fc=0 --with-cuda=0 --with-mpi --with-openmp=0 --with-debugging=0 --with-shared-libraries --with-64-bit-indices --download-kokkos --download-kokkos-kernels --download-hdf5 --download-hdf5-configure-arguments=--enable-parallel --download-boost --download-f2cblaslapack --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3
>> The version of PETSc you are using is out-of-date, we recommend updating to the new release
>>  Available Version: 3.23.3   Installed Version: 3.22.2
>> Let me know what additional information I can provide to help identify the issue.
>> Best,
>> Sophie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250606/3456e605/attachment.html>
