[petsc-users] PETSc unable to find cuda
Blondel, Sophie
sblondel at utk.edu
Wed Jul 23 14:36:26 CDT 2025
Thank you both for your reply,
Changing the gcc version fixed this issue. I will try with PETSc latest release now.
Best,
Sophie
Sent: Wednesday, July 23, 2025 12:09
To: Matthew Knepley <knepley at gmail.com>
Cc: Blondel, Sophie <sblondel at utk.edu>; PETSc users list <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] PETSc unable to find cuda
[You don't often get email from balay.anl at fastmail.org. Learn why this is important at https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!d017XOnXyQPKwAOyowyrrMSKBNTMI5wjlOdK84apvit3ZqHGOFCysvlQkl5EWnaiBbOwHM90BQfZDHh7GhvZg-yk$ ]
Executing: mpicc --version
stdout:
x86_64-conda-linux-gnu-cc (conda-forge gcc 13.3.0-2) 13.3.0
Executing: mpicc -o /tmp/petsc-q3as9pdp/config.libraries/conftest -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -fstack-protector -fvisibility=hidden -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -fstack-protector -fvisibility=hidden -O3 /tmp/petsc-q3as9pdp/config.libraries/conftest.o -Wl,-rpath,/usr/local/cuda-11.8/lib64 -L/usr/local/cuda-11.8/lib64 -lcudart -lnvToolsExt -lcufft -lcublas -lcusparse -lcusolver -lcurand -L/usr/local/cuda-11.8/lib64/stubs -lcuda -lquadmath
stdout:
/home/sophie/miniforge/envs/release/bin/../lib/gcc/x86_64-conda-linux-gnu/13.3.0/../../../../x86_64-conda-linux-gnu/bin/ld: warning: libstdc++.so.6, needed by /usr/local/cuda-11.8/lib64/libnvToolsExt.so, not found (try using -rpath or -rpath-link)
/home/sophie/miniforge/envs/release/bin/../lib/gcc/x86_64-conda-linux-gnu/13.3.0/../../../../x86_64-conda-linux-gnu/bin/ld: /home/sophie/miniforge/envs/release/lib/./././libicuuc.so.73: undefined reference to `std::condition_variable::notify_all()@GLIBCXX_3.4.11'
/home/sophie/miniforge/envs/release/bin/../lib/gcc/x86_64-conda-linux-gnu/13.3.0/../../../../x86_64-conda-linux-gnu/bin/ld: /home/sophie/miniforge/envs/release/lib/./././libicui18n.so.73: undefined reference to `__cxa_guard_acquire at CXXABI_1.3'
/home/sophie/miniforge/envs/release/bin/../lib/gcc/x86_64-conda-linux-gnu/13.3.0/../../../../x86_64-conda-linux-gnu/bin/ld: /home/sophie/miniforge/envs/release/lib/./././libicui18n.so.73: undefined reference to `operator delete(void*)@GLIBCXX_3.4'
/home/sophie/miniforge/envs/release/bin/../lib/gcc/x86_64-conda-linux-gnu/13.3.0/../../../../x86_64-conda-linux-gnu/bin/ld: /home/sophie/miniforge/envs/release/lib/./././libicuuc.so.73: undefined reference to `std::__once_call at GLIBCXX_3.4.11'
/home/sophie/miniforge/envs/release/bin/../lib/gcc/x86_64-conda-linux-gnu/13.3.0/../../../../x86_64-conda-linux-gnu/bin/ld: /home/sophie/miniforge/envs/release/lib/./././libicui18n.so.73: undefined reference to `vtable for __cxxabiv1::__si_class_type_info at CXXABI_1.3'
Likely you need gcc/g++-11 for this version of cuda. [or install/use a newer version of cuda]. And best if you can use latest petsc release.
Satish
On Wed, 23 Jul 2025, Matthew Knepley wrote:
> On Wed, Jul 23, 2025 at 11:49 AM Blondel, Sophie via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hi,
> > I am trying to install PETSc (3.22.2) with Kokkos and cuda support on an
> > Ubuntu laptop with dependencies loaded with Conda.
> You are likely to have to turn off Conda before configuring. It messes up
> paths for Python and other things.
> Thanks,
> Matt
> > The configure line is: ./configure
> > PETSC_DIR=/home/sophie/Workspace/xolotl-develop-source/external/petsc
> > PETSC_ARCH=rel-cuda
> > --prefix=/home/sophie/Workspace/xolotl-develop-cuda/external/petsc_install
> > --with-fc=0 --with-cuda=1 --with-mpi --with-openmp=0 --with-debugging=0
> > --with-shared-libraries --with-64-bit-indices --download-kokkos
> > --download-kokkos-kernels --download-hdf5
> > --download-hdf5-configure-arguments=--enable-parallel --COPTFLAGS=-O3
> > --CXXOPTFLAGS=-O3 --with-cuda-arch=86 --CUDAOPTFLAGS=-O3
> > And the configure.log is attached. Let me know if I can provide additional
> > information.
> > Best,
> > Sophie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250723/00a30229/attachment.html>
