[petsc-users] problem with nested logging, standalone example
Junchao Zhang
junchao.zhang at gmail.com
Tue Jul 22 15:18:22 CDT 2025
With Chris's example, I did reproduce the "MPI_ERR_BUFFER: invalid buffer
pointer" on a machine. I am looking into it.
Thanks.
--Junchao Zhang
On Tue, Jul 22, 2025 at 9:51 AM Zongze Yang <yangzongze at gmail.com> wrote:
> Hi,
> I encountered a similar issue with Firedrake when using the -log_view option
> with XML format on macOS. Below is the error message. The Firedrake code
> and the shell script used to run it are attached.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: General MPI error
> [0]PETSC ERROR: MPI error 1 MPI_ERR_BUFFER: invalid buffer pointer
> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!bitkMAVSBHfkO71IthJuocmtSkJAoWdXju0W8ra3pkNhAQ0ULGK2V2SDIVEXJTW6DekHmZoJorx9h8YpGr1EJj_T7kfT$
> <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!eiv8Wo1VhQz4c2L8MbDoPcg0KZ0loiWlwjI1MR6VEtFfLWTjZNV4UssfSUT-F9tKXb2GjX8Ar-YrWmBGIAY9ujQp$>
> for trouble shooting.
> [0]PETSC ERROR: PETSc Release Version 3.23.4, unknown
> [0]PETSC ERROR: test.py with 2 MPI process(es) and PETSC_ARCH
> arch-firedrake-default on 192.168.10.51 by zzyang Tue Jul 22 22:24:05 2025
> [0]PETSC ERROR: Configure options: PETSC_ARCH=arch-firedrake-default
> --COPTFLAGS="-O3 -march=native -mtune=native" --CXXOPTFLAGS="-O3
> -march=native -mtune=native" --FOPTFLAGS="-O3 -mtune=native"
> --with-c2html=0 --with-debugging=0 --with-fortran-bindings=0
> --with-shared-libraries=1 --with-strict-petscerrorcode --download-cmake
> --download-bison --download-fftw --download-mumps-avoid-mpi-in-place
> --with-hdf5-dir=/opt/homebrew --with-hwloc-dir=/opt/homebrew
> --download-metis --download-mumps --download-netcdf --download-pnetcdf
> --download-ptscotch --download-scalapack --download-suitesparse
> --download-superlu_dist --download-slepc --with-zlib --download-hpddm
> --download-libpng --download-ctetgen --download-tetgen --download-triangle
> --download-mmg --download-parmmg --download-p4est --download-eigen
> --download-hypre --download-pragmatic
> [0]PETSC ERROR: #1 PetscLogNestedTreePrintLine() at
> /Users/zzyang/opt/firedrake/firedrake-pip/petsc/src/sys/logging/handler/impls/nested/xmlviewer.c:289
> [0]PETSC ERROR: #2 PetscLogNestedTreePrint() at
> /Users/zzyang/opt/firedrake/firedrake-pip/petsc/src/sys/logging/handler/impls/nested/xmlviewer.c:383
> [0]PETSC ERROR: #3 PetscLogNestedTreePrint() at
> /Users/zzyang/opt/firedrake/firedrake-pip/petsc/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> [0]PETSC ERROR: #4 PetscLogNestedTreePrint() at
> [0]PETSC ERROR: #5 PetscLogNestedTreePrint() at
> [0]PETSC ERROR: #6 PetscLogNestedTreePrint() at
> [0]PETSC ERROR: #7 PetscLogNestedTreePrint() at
> [0]PETSC ERROR: #8 PetscLogNestedTreePrint() at
> [0]PETSC ERROR: #9 PetscLogNestedTreePrint() at
> [0]PETSC ERROR: #10 PetscLogNestedTreePrint() at
> [0]PETSC ERROR: #11 PetscLogNestedTreePrint() at
> [0]PETSC ERROR: #12 PetscLogNestedTreePrint() at
> [0]PETSC ERROR: #13 PetscLogNestedTreePrintTop() at
> /Users/zzyang/opt/firedrake/firedrake-pip/petsc/src/sys/logging/handler/impls/nested/xmlviewer.c:420
> [0]PETSC ERROR: #14 PetscLogHandlerView_Nested_XML() at
> /Users/zzyang/opt/firedrake/firedrake-pip/petsc/src/sys/logging/handler/impls/nested/xmlviewer.c:443
> [0]PETSC ERROR: #15 PetscLogHandlerView_Nested() at
> /Users/zzyang/opt/firedrake/firedrake-pip/petsc/src/sys/logging/handler/impls/nested/lognested.c:405
> [0]PETSC ERROR: #16 PetscLogHandlerView() at
> /Users/zzyang/opt/firedrake/firedrake-pip/petsc/src/sys/logging/handler/interface/loghandler.c:342
> [0]PETSC ERROR: #17 PetscLogView() at
> /Users/zzyang/opt/firedrake/firedrake-pip/petsc/src/sys/logging/plog.c:2043
> [0]PETSC ERROR: #18 PetscLogViewFromOptions() at
> /Users/zzyang/opt/firedrake/firedrake-pip/petsc/src/sys/logging/plog.c:2084
> [0]PETSC ERROR: #19 PetscFinalize() at
> /Users/zzyang/opt/firedrake/firedrake-pip/petsc/src/sys/objects/pinit.c:1552
> PetscFinalize() failed [error code: 98]
> prterun has exited due to process rank 0 with PID 28986 on node
> 192.168.10.51 exiting
> improperly. There are three reasons this could occur:
> 1. this process did not call "init" before exiting, but others in the
> job did. This can cause a job to hang indefinitely while it waits for
> all processes to call "init". By rule, if one process calls "init",
> then ALL processes must call "init" prior to termination.
> 2. this process called "init", but exited without calling "finalize".
> By rule, all processes that call "init" MUST call "finalize" prior to
> exiting or it will be considered an "abnormal termination"
> 3. this process called "MPI_Abort" or "prte_abort" and the mca
> parameter prte_create_session_dirs is set to false. In this case, the
> run-time cannot detect that the abort call was an abnormal
> termination. Hence, the only error message you will receive is this
> one.
> This may have caused other processes in the application to be
> terminated by signals sent by prterun (as reported here).
> You can avoid this message by specifying -quiet on the prterun command
> line.
> Best wishes,
> Zongze
> *From: *petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Klaij,
> Christiaan via petsc-users <petsc-users at mcs.anl.gov>
> *Date: *Monday, July 14, 2025 at 15:58
> *To: *Barry Smith <bsmith at petsc.dev>
> *Cc: *PETSc users list <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] problem with nested logging, standalone
> example
> @Junchao: yes, all with my ex2f.F90 variation on two or three cores
> @Barry: it's really puzzling that you cannot reproduce. Can you try
> running it a dozen times in a row? And look at the report_performance.xml
> file? When it hangs I see some nan's, for instance here in the VecAXPY
> event:
> <events>
> <event>
> <name>VecAXPY</name>
> <time>
> <avgvalue>0.00610203</avgvalue>
> <minvalue>0.</minvalue>
> <maxvalue>0.0122041</maxvalue>
> <minloc>1</minloc>
> <maxloc>0</maxloc>
> </time>
> <ncalls>
> <avgvalue>0.5</avgvalue>
> <maxvalue>1.</maxvalue>
> <minloc>1</minloc>
> <maxloc>0</maxloc>
> </ncalls>
> </event>
> <event>
> <name>self</name>
> <time>
> <value>-nan.</value>
> </time>
> This is what I did in my latest attempt on the login node of our Rocky
> Linux 9 cluster:
> 1) download petsc-3.23.4.tar.gz from the petsc website
> 2) ./configure -prefix=~/petsc/install --with-cxx=0 --with-debugging=0
> --with-mpi-dir=/cm/shared/apps/mpich/ge/gcc/64/3.4.2
> 3) adjust my example to this version of petsc (file is attached)
> 4) make ex2f-cklaij-dbg-v2
> 5) mpirun -n 2 ./ex2f-cklaij-dbg-v2
> So the exact versions are: petsc-3.23.4, system mpich 3.4.2, system gcc
> 11.5.0
> From: Barry Smith <bsmith at petsc.dev>
> Sent: Friday, July 11, 2025 11:22 PM
> To: Klaij, Christiaan
> Cc: Junchao Zhang; PETSc users list
> Subject: Re: [petsc-users] problem with nested logging, standalone example
> And yet we cannot reproduce.
> Please tell us the exact PETSc version and MPI implementation versions.
> And reattach your reproducing example. And exactly how you run it.
> Can you reproduce it on an "ordinary" machine, say a Mac or Linux
> laptop.
> Barry
> If I could reproduce the problem here is how I would debug. I put use
> -start_in_debugger and then put break points in places which it seem
> problematic. Presumably I would end up with a hang with each MPI process in
> a "different place" and from that I may be able to determine how that
> happened.
> > On Jul 11, 2025, at 7:58 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> > In summary for future reference:
> > - tested 3 different machines, two at Marin, one at the national HPC
> > - tested 3 different mpi implementation (intelmpi, openmpi and mpich)
> > - tested openmpi in both release and debug
> > - tested 2 different compilers (intel and gnu), both older and very
> recent versions
> > - tested with the most basic config (./configure --with-cxx=0
> --with-debugging=0 --download-mpich)
> > All of these test either segfault, or hang or error-out at the call to
> PetscLogView.
> > Chris
> > From: Klaij, Christiaan <C.Klaij at marin.nl>
> > Sent: Friday, July 11, 2025 10:10 AM
> > To: Barry Smith; Junchao Zhang
> > Cc: PETSc users list
> example
> > @Matt: no MPI errors indeed. I've tried with MPICH and I get the same
> hanging.
> > @Barry: both stack traces aren't exactly the same, see a sample with
> MPICH below.
> > If it cannot be reproduced at your side, I'm afraid this is another dead
> end. Thanks anyway, I really appreciate all your help.
> > Chris
> > (gdb) bt
> > #0 0x000015555033bc2e in
> MPIDI_POSIX_mpi_release_gather_gather.constprop.0 ()
> > from /cm/shared/apps/mpich/ge/gcc/64/3.4.2/lib/libmpi.so.12
> > #1 0x000015555033db8a in MPIDI_POSIX_mpi_allreduce_release_gather ()
> > #2 0x000015555033e70f in MPIR_Allreduce ()
> > #3 0x000015555033f22e in PMPI_Allreduce ()
> > #4 0x0000155553f85d69 in MPIU_Allreduce_Count (comm=-2080374782,
> > op=1476395020, dtype=1275072547, count=1, outbuf=0x7fffffffac70,
> > inbuf=0x7fffffffac60)
> > at /home/cklaij/petsc/petsc-3.23.4/src/sys/objects/pinit.c:1839
> > #5 MPIU_Allreduce_Private (inbuf=inbuf at entry=0x7fffffffac60,
> > outbuf=outbuf at entry=0x7fffffffac70, count=count at entry=1,
> > dtype=dtype at entry=1275072547, op=op at entry=1476395020,
> comm=-2080374782)
> > at /home/cklaij/petsc/petsc-3.23.4/src/sys/objects/pinit.c:1869
> > #6 0x0000155553f33dbe in PetscPrintXMLNestedLinePerfResults (
> > viewer=viewer at entry=0x458890, name=name at entry=0x155554ef6a0d
> 'mbps\000',
> > value=<optimized out>, minthreshold=minthreshold at entry=0,
> > maxthreshold=maxthreshold at entry=0.01,
> > minmaxtreshold=minmaxtreshold at entry=1.05)
> > at
> /home/cklaij/petsc/petsc-3.23.4/src/sys/logging/handler/impls/nested/xmlviewer.c:255
> > (gdb) bt
> > #0 0x000015554fed3b17 in clock_gettime at GLIBC_2.2.5 () from
> /lib64/libc.so.6
> > #1 0x0000155550b0de71 in ofi_gettime_ns ()
> > #2 0x0000155550b0dec9 in ofi_gettime_ms ()
> > #3 0x0000155550b2fab5 in sock_cq_sreadfrom ()
> > #4 0x00001555505ca6f7 in MPIDI_OFI_progress ()
> > #5 0x0000155550591fe9 in progress_test ()
> > #6 0x00001555505924a3 in MPID_Progress_wait ()
> > #7 0x000015555043463e in MPIR_Wait_state ()
> > #8 0x000015555052ec49 in MPIC_Wait ()
> > #9 0x000015555053093e in MPIC_Sendrecv ()
> > #10 0x00001555504bf674 in MPIR_Allreduce_intra_recursive_doubling ()
> > #11 0x00001555505b61de in MPIDI_OFI_mpi_finalize_hook ()
> > Sent: Thursday, July 10, 2025 11:10 PM
> > To: Junchao Zhang
> > Cc: Klaij, Christiaan; PETSc users list
> example
> > I cannot reproduce
> > On Jul 10, 2025, at 3:46 PM, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> > Adding -mca coll_hcoll_enable 0 didn't change anything at my end.
> Strange.
> > --Junchao Zhang
> > On Thu, Jul 10, 2025 at 3:39 AM Klaij, Christiaan <C.Klaij at marin.nl
> <mailto:C.Klaij at marin.nl>> wrote:
> > An additional clue perhaps: with the option
> OMPI_MCA_coll_hcoll_enable=0, the code does not hang but gives the error
> below.
> > Chris
> > $ mpirun -mca coll_hcoll_enable 0 -n 2 ./ex2f-cklaij-dbg -pc_type jacobi
> -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always
> > 0 KSP Residual norm 1.11803
> > 1 KSP Residual norm 0.591608
> > 2 KSP Residual norm 0.316228
> > 3 KSP Residual norm < 1.e-11
> > 0 KSP Residual norm 0.707107
> > 1 KSP Residual norm 0.408248
> > 2 KSP Residual norm < 1.e-11
> > Norm of error < 1.e-12 iterations 3
> > [1]PETSC ERROR: --------------------- Error Message
> > [1]PETSC ERROR: General MPI error
> > [1]PETSC ERROR: MPI error 1 MPI_ERR_BUFFER: invalid buffer pointer
> > [1]PETSC ERROR: See
> https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!dcT9AzbxDJMLIie0NhYIw4YU2TObPM3WHhzR-HlzrpfbjPd6sgsPX009yFy1lw_eLLu2WprNwYRABMK43J9p4SM$
> https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJjkYxsN9$>
> > [1]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
> > [1]PETSC ERROR: ./ex2f-cklaij-dbg with 2 MPI process(es) and PETSC_ARCH
> on login1 by cklaij Thu Jul 10 10:33:33 2025
> > [1]PETSC ERROR: Configure options:
> --prefix=/home/cklaij/ReFRESCO/trunk/install/extLibs
> --with-mpi-dir=/cm/shared/apps/openmpi/gcc/5.0.6-debug --with-x=0
> --with-mpe=0 --with-debugging=0 --download-superlu_dist=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!dcT9AzbxDJMLIie0NhYIw4YU2TObPM3WHhzR-HlzrpfbjPd6sgsPX009yFy1lw_eLLu2WprNwYRABMK4VVy6P4U$
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJkouVHb2$>
> --with-blaslapack-dir=/cm/shared/apps/oneapi/2024.2.1/mkl/2024.2
> --download-parmetis=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!dcT9AzbxDJMLIie0NhYIw4YU2TObPM3WHhzR-HlzrpfbjPd6sgsPX009yFy1lw_eLLu2WprNwYRABMK4-9b1K84$
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJrjo6-SP$>
> --download-metis=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!dcT9AzbxDJMLIie0NhYIw4YU2TObPM3WHhzR-HlzrpfbjPd6sgsPX009yFy1lw_eLLu2WprNwYRABMK4Y9uaqiQ$
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJhCc9MRE$>
> --with-packages-build-dir=/home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild
> --with-ssl=0 --with-shared-libraries=1 CFLAGS="-std=gnu11 -Wall
> -funroll-all-loops -O3 -DNDEBUG" CXXFLAGS="-std=gnu++14 -Wall
> -funroll-all-loops -O3 -DNDEBUG " COPTFLAGS="-std=gnu11 -Wall
> -funroll-all-loops -O3 -DNDEBUG" CXXOPTFLAGS="-std=gnu++14 -Wall
> -funroll-all-loops -O3 -DNDEBUG " FCFLAGS="-Wall -funroll-all-loops
> -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime
> -Wno-unused-function -O3 -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops
> -Wno-unused-function -O3 -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops
> > [1]PETSC ERROR: #1 PetscLogNestedTreePrintLine() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:289
> > [1]PETSC ERROR: #2 PetscLogNestedTreePrint() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:377
> > [1]PETSC ERROR: #3 PetscLogNestedTreePrint() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> > [1]PETSC ERROR: #4 PetscLogNestedTreePrintTop() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
> > [1]PETSC ERROR: #5 PetscLogHandlerView_Nested_XML() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
> > [1]PETSC ERROR: #6 PetscLogHandlerView_Nested() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
> > [1]PETSC ERROR: #7 PetscLogHandlerView() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
> > [1]PETSC ERROR: #8 PetscLogView() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/plog.c:2040
> > [1]PETSC ERROR: #9 ex2f-cklaij-dbg.F90:301
> > MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
> > Proc: [[55228,1],1]
> > Errorcode: 98
> > NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> > You may or may not see output from other processes, depending on
> > exactly when Open MPI kills them.
> > prterun has exited due to process rank 1 with PID 0 on node login1
> calling
> > "abort". This may have caused other processes in the application to be
> > <image198746.png>
> > dr. ir. Christiaan Klaij | senior researcher
> > Research & Development | CFD Development
> > T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> |
> https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!dcT9AzbxDJMLIie0NhYIw4YU2TObPM3WHhzR-HlzrpfbjPd6sgsPX009yFy1lw_eLLu2WprNwYRABMK4BUEn1h8$
> https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJrOqapgp$
> > <image542473.png><
> https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJoD4fuV7$
> > <image555176.png><
> https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJospHf95$
> > <image269837.png><
> https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJrpsjB_W$
> > From: Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>
> > Sent: Thursday, July 10, 2025 10:15 AM
> > To: Junchao Zhang
> example
> > Hi Junchao,
> > Thanks for testing. I've fixed the error but unfortunately that doesn't
> change the behavior, the code still hangs as before, with the same stack
> trace...
> > Chris
> > From: Junchao Zhang <junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com>>
> > Sent: Tuesday, July 8, 2025 10:58 PM
> example
> > Hi, Chris,
> > First, I had to fix an error in your test by adding "
> PetscCallA(MatSetFromOptions(AA,ierr))" at line 254.
> > [0]PETSC ERROR: Object is in wrong state
> > [0]PETSC ERROR: Mat object's type is not set: Argument # 1
> > [0]PETSC ERROR: #1 MatSetValues() at
> /scratch/jczhang/petsc/src/mat/interface/matrix.c:1503
> > [0]PETSC ERROR: #2 ex2f.F90:258
> > Then I could ran the test without problems
> > mpirun -n 2 ./ex2f -pc_type jacobi -ksp_monitor_short
> > I used petsc-3.22.4, gcc-11.3, openmpi-5.0.6 and configured with
> > ./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> --download-openmpi --with-ssl=0 --with-shared-libraries=1
> CFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG"
> CXXFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG "
> COPTFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG"
> CXXOPTFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG "
> FCFLAGS="-Wall -funroll-all-loops -ffree-line-length-0
> -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3
> -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops -ffree-line-length-0
> -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops -ffree-line-length-0
> -DNDEBUG"
> > Could you fix the error and retry?
> > --Junchao Zhang
> > On Sun, Jul 6, 2025 at 12:57 PM Klaij, Christiaan via petsc-users <
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>> wrote:
> > Attached is a standalone example of the issue described in the
> > earlier thread "problem with nested logging". The issue appeared
> > somewhere between petsc 3.19.4 and 3.23.4.
> > The example is a variation of ../ksp/tutorials/ex2f.F90, where
> > I've added the nested log viewer with one event as well as the
> > solution of a small system on rank zero.
> > When running on mulitple procs the example hangs during
> > PetscLogView with the backtrace below. The configure.log is also
> > attached in the hope that you can replicate the issue.
> > Chris
> > #0 0x000015554c84ea9e in mca_pml_ucx_recv (buf=0x7fffffff9e30, count=1,
> > datatype=0x15554c9ef900 <ompi_mpi_2dblprec>, src=1, tag=-12,
> > comm=0x7f1e30, mpi_status=0x0) at pml_ucx.c:700
> > #1 0x000015554c65baff in
> ompi_coll_base_allreduce_intra_recursivedoubling (
> > sbuf=0x7fffffff9e20, rbuf=0x7fffffff9e30, count=1,
> > dtype=0x15554c9ef900 <ompi_mpi_2dblprec>,
> > op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaec630)
> > at base/coll_base_allreduce.c:247
> > #2 0x000015554c6a7e40 in ompi_coll_tuned_allreduce_intra_do_this (
> > op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaec630,
> > algorithm=3, faninout=0, segsize=0) at
> coll_tuned_allreduce_decision.c:142
> > #3 0x000015554c6a054f in ompi_coll_tuned_allreduce_intra_dec_fixed (
> > at coll_tuned_decision_fixed.c:216
> > #4 0x000015554c68e160 in mca_coll_hcoll_allreduce (sbuf=0x7fffffff9e20,
> > rbuf=0x7fffffff9e30, count=1, dtype=0x15554c9ef900 <ompi_mpi_2dblprec>,
> > op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaecb80)
> > at coll_hcoll_ops.c:217
> > #5 0x000015554c59811a in PMPI_Allreduce (sendbuf=0x7fffffff9e20,
> > recvbuf=0x7fffffff9e30, count=1, datatype=0x15554c9ef900
> <ompi_mpi_2dblprec>, op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30)
> at allreduce.c:123
> > #6 0x0000155553eabede in MPIU_Allreduce_Private () from
> /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> > #7 0x0000155553e50d08 in PetscPrintXMLNestedLinePerfResults () from
> > #8 0x0000155553e5123e in PetscLogNestedTreePrintLine () from
> > #9 0x0000155553e51f3a in PetscLogNestedTreePrint () from
> > #10 0x0000155553e51e96 in PetscLogNestedTreePrint () from
> > #11 0x0000155553e51e96 in PetscLogNestedTreePrint () from
> > #12 0x0000155553e52142 in PetscLogNestedTreePrintTop () from
> > #13 0x0000155553e5257b in PetscLogHandlerView_Nested_XML () from
> > #14 0x0000155553e4e5a0 in PetscLogHandlerView_Nested () from
> > #15 0x0000155553e56232 in PetscLogHandlerView () from
> > #16 0x0000155553e588c3 in PetscLogView () from
> > #17 0x0000155553e40eb5 in petsclogview_ () from
> > #18 0x0000000000402c8b in MAIN__ ()
> > #19 0x00000000004023df in main ()
> > [cid:ii_197ebccaa1d27ee6ef21]
> https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJhphmV4x$><https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imk4ivm_tE$
> > [Facebook]<
> https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkLNCvsiI$
> > [LinkedIn]<
> https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkrb79Ay4$
> > [YouTube]<
> https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkJiCoeLw$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250722/b4fa559d/attachment-0001.html>
